What is the Easiest way to move 330 yards of pit run gravel?
   / What is the Easiest way to move 330 yards of pit run gravel? #1
WilliamBos
Super Member
Innisfil, Ontario, Canada
MF 1635 12x12 Powershuttle
Came across this thread on another forum...
What is the Easiest way to move 330 yards of pit run gravel? Well, its easier than you think, especially when a tight area is the destination.
A B2620, a Polaris Sportsman 500HO and a Polaris trailer, some time and you are all set.
Enjoy. :)
   / What is the Easiest way to move 330 yards of pit run gravel? #2
Pit run must be what we call crusher run. Names change from place to place.
   / What is the Easiest way to move 330 yards of pit run gravel? #3
I moved 300 with my little BX23 one summer...
Just as soon as I had cleared 20 yards at a little more than a 1/4 yard at a time the next showed up...
Hey... it beat using a wheelbarrow!
Looking good!
   / What is the Easiest way to move 330 yards of pit run gravel? #4
I will raise you an RTV with a dump bed.
Around here Pit Run is straight rock from the pit that is blasted and fractured or some places ripped with a cat and not run through a crusher.
David
   / What is the Easiest way to move 330 yards of pit run gravel? #5
Unless I messed up the math, 330 cubic yards works out to 445 tons or over 20 loads at 20 tons each. That would be a lot of material to handle.
   / What is the Easiest way to move 330 yards of pit run gravel? #6
I'm guessing he's retired
   / What is the Easiest way to move 330 yards of pit run gravel? #7
No, I wish I was retired. Just play on the weekends. Used this to haul it all home. Legal for 42 tonnes.
You found my pics eh Will? Thanks for posting. I like to show that you don't need a big tractor to get stuff done.
   / What is the Easiest way to move 330 yards of pit run gravel? #8
Here's a few pics during the road work. The little B pulls a loaded 60" box blade up the hills no problem and medium range.
   / What is the Easiest way to move 330 yards of pit run gravel? #9
David
I would love to have an RTV with hydraulic dump. I was going to buy a Weber Lane Super Tilt hydraulic dump trailer and run it off the rear remote on my Kubota, but now I'm thinking about a tandem axle MUT's so I can pull and dump with my Polaris.
Up here we are legal to gross 63,500kg/140,000 pounds. It does not take too long. See Star pic above.
Scag Mower (A50324)
Scag Mower (A50324)
2020 Ram 1500 Classic 4x4 Crew Cab Pickup Truck (A51692)
2020 Ram 1500...
Pallet Fees (A50775)
2006 FORD F250 SERVICE TRUCK (A53426)
2006 FORD F250...
2001 International 4700 Dump Truck (A51691)
2001 International...
MAJOR LOT NUMBER 260 (A53084)
MAJOR LOT NUMBER...
