Which Gooseneck Trailer?
/ Which Gooseneck Trailer? #21
I don't like the "pop up dovetail" like some manufacturers have. I prefer the adjustable dovetail where the entire tail will level out greatly reducing the tail dragging coming out of fields!
/ Which Gooseneck Trailer? #22
Yep, tail dragging, had one that did that on the terraces in the hay field. Ordered this this Delta with a 4' pop up dovetail instead of 5' and no more tail dragging. :thumbsup:
Out of curiosity, how important do you feel a torque tube is on a gooseneck trailer? I keep hearing how important they are but I can't say that I have ever seen one on a semi trailer, so I would think that it would be more important for the frame of the trailer to be built stout. Thoughts?
/ Which Gooseneck Trailer? #24
Blowing one tire on single wheel tandems does not put more load on the surviving tire, as is the case for duals. Many trailers in the oil patch run 17.5 tires so they don't have to deal with the hassle of mud and rocks between the duals. Many hotshot outfits are running them, as well. When I was still working, I never saw a problem obtaining them, but supplies in your area may be different.
How can you say it doesn't put more weight? I'm talking singles here. If you have 14K on the axles that's 7K per axle, 3.5K per tire. If you blow on it now transfers it's weight to the tire on the same side.
Chris
/ Which Gooseneck Trailer? #25
Chris
I can say that because that's how it works. That's what the equalizer on Dexter suspension is designed to do. If a tire goes flat, it is still carrying the weight. It's just flat. The exception would be if you are running torsion axles. But, I don't know why you would on a big trailer unless it was strictly used on the highway.
The tractor the OP is wanting to haul would be fine on a tandem 7K axle trailer. The first thing I did when I bought the trailer I have now was to get rid of the ST tires and replace with LT Michelin XPS Rib tires. That will save a lot of blowouts. I don't have a need for a heavier trailer anymore, but would upgrade to 8K axles and 17.5 tires if I needed more capacity.
/ Which Gooseneck Trailer? #26
While I don't have a trailer with duel tires right now, I've pulled quite a few of them and can say the difference is significant in how well they pull. Just like going from a single axle to a double, going to duel tires is even more stable. There is nothing I hate more when pulling a trailer then having it wobble, or move from side to side from wind, or bad roads.
/ Which Gooseneck Trailer? #27
I think some trailers come wi th 4' tails instead of 5'. Iirc my FIL had a quality trailer that had a 4 foot tail. I didn't care for the trailer much, but I'll still take the adjustable tail to have a completely flat deck for hay or bulk material hauling and drop the tail for loading rolling loads. The pop up tails looked to be alot lighter in construction to me. I don't know that it matters a whole lot, just personal preference. When I get a bigger GN, it will be a tandem dual with a hydraulic tail.
/ Which Gooseneck Trailer? #28
I would love to have one with a hydraulic tail. Especially hauling hay. And sometimes when hauling my equipment, I have to get creative with the ramps! LUTT
/ Which Gooseneck Trailer? #29
I agree. Loading cars can be a creative endeavor! If we are really dreaming I want to get air ride too!!
Apparently no one has any knowledge or opinions on a torque tube, I was hoping for some info as I am probably going to order a trailer tomorrow, and I know very little about them, anyhow thank's for all the replies. Charlie.
/ Which Gooseneck Trailer? #31
Charlie, how long of a trailer are you looking at? The dealer I bought my trailer from didn't think I needed it for a 20+5 trailer and for the most part I agree, If I was going over 25' of main deck (minus the tail), I'd seriously consider it. IF you ever get into a situation where you would be hauling off balanced loads, I'd def opt for it.
/ Which Gooseneck Trailer? #32
Right, no experience with the center tube construction.
My trailer is just over 9 years old, 18' plus the 4' dovetail, faded but not twisted. :thumbsup:
/ Which Gooseneck Trailer? #33
Unless your trailer is over 25' long I don't think a torque tube does anything but add weight. I have never has a trailer with one and I have had a lot of trailers in the 20-30' range.
If you look at big Tex for example which is arguably one of the nations largest trailer manufacturers they build trailers under 28' without the tube and over 28' have it. When you look at these 40' long 10 ton trailers there has to be some crazy twisting forces at work.
If you are getting a 20+5 or a 25+5 I wouldn't worry about the tube.
I'm probably going to order a Gatormade trailer, they have a Workhorse series that is not quite as fancy as their top of the line but still well built with the main frame being built out of 14" I beam and it does not come standard with a torque tube, I am also going with the tandem 10k super single axles with 17.5 tires and the length will be 25 plus 5 for a total of 30' of deck with the mega ramps layed down flat, so if something doesn't change my mind I'm ordering in the morning, thank you all for the advice and opinions. Charlie.
/ Which Gooseneck Trailer? #35
I know you said you have a CDL but what are you going to be hauling on it?
Are you a carrier or do you have the CDL for your work? Reason I ask is unless you qualify for some type of ag exemption you will need to go all the way with the DOT stuff on that trailer. Really in the eyes of the law it is no different than an 18 wheeler meaning unless you fall into a loophole you are going to have a ton of red tape to go through.
Apparently none of that goes on down here, everybody and there brother has big gooseneck trailers and most don't even have a CDL, but I do have a farm and will be using it on the farm some, it is probably more trailer than I need tonnage wise but I think the length will be just right, and it should be stout enough to haul anything I ever need to.
/ Which Gooseneck Trailer? #37
I think that is only true if you are not hauling your own stuff....IE for "profit" which could mean ANY compensation.
/ Which Gooseneck Trailer? #38
I agree. And an extra plus is a blowout, since everyone is talking about that. I've blown a tire on my dual trailer. I drove an additional 6 miles to the next exit and then stopped to put on the spare. You are not going to do that with singles.
/ Which Gooseneck Trailer? #39
Oh I agree 100% you can never have too much trailer as long as you are good to haul it legally which is pretty easy to accomplish with ag exemptions. I was at a trailer dealership a few weeks ago and they had a one week old used trailer for sale. It was a tandem dual gooseneck a guy bought to haul his skid steer and construction materials on. Evidently the second day he had it the dot popped him and he found it easier and less costly to trade it in at a loss and get something smaller than do everything required to be compliant. I just didn't want you to be that guy.
I have a CDL, dot number, mc number, interstate operating authority, etc. We have two pickups hauling goosenecks, a peterbilt tractor trailer, and a tandem dump truck. I probably spend close to 10k a year on the required insurance, various fees, registrations, inspections, drug testing programs, etc. It also takes a ton of time dealing with it all.
As to the 17.5's I love them. I have not replaced tandem duals with them as singles but I put them on my 14k trailers just as an added safety margin. They seem to last forever and blowouts are a thing of the past.
Keep in mind with a 3/4 ton tow vehicle you are going to be pretty limited on what you can haul on a tandem dual without overloading the rear axle and tires on the pickup. Every time the DOT has stopped me they weigh each axle and make sure we are under each axle rating and tire ratings. I don't know exactly what your truck is rated at but I am guessing the rear axle rating is somewhere around 6500lb and it probably has over 4000 on it empty which doesn't leave you much room for pin weight on a heavy duty trailer.
Just last week I ran up to Missouri from Texas and back. I saw five DOT guys with people pulled over during my trip. One had a 18 wheeler the other four had pickups pulling tandem duals. The dot knows that most semis are legal and that the vast majority of gooseneck guys just hook on and go and it is an easy revenue stream for them.
/ Which Gooseneck Trailer? #40
I have a Gatormade GN 20' + 5' deck over. It weighs 5700# and grosses at 16000#. I have a Ferguson To-35 with a Howse 5' bush hog, front end loader, and loaded tires. I tow with a 2012 Ford F-350 ccsb 4x4 6.7l diesel srw. The total combined weight full of fuel is 21750#. You won't win any drag races but it handles it easily. The reason I went with Gatormade was the ramp design. I previously owned another brand with a torque tube and fixed positioned ridged ramps. The ramps were 8' long and hinged at the outside edges of the trailer. They were super heavy, and half the time were in the wrong place to load what we were hauling. The other thing that presented itself was the ramps chasing me across any kind surface other than concrete or pavement. Why did we buy that rig in the first place? It was the cheapest one we could find. The suck age lasted WAY past the savings
2020 BOBCAT MT55 STAND ON SKID STEER (A63276)
2020 BOBCAT MT55...
Challenger 65D/75D/85D Tractor Parts and Service Manuals (A63117)
Challenger...
2001 Ford F-650 18ft Rollback Truck (A61573)
2001 Ford F-650...
1947 Chevrolet Panel (A62613)
1947 Chevrolet...
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
2022 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Mack Anthem...
