Buying Advice 1510D Advice
/ 1510D Advice #1
tums20
Member
Nor Cal
Kubota B6100
I originally put this in the General Forum, it was suggested I move it here.
Just got roughly 2 acres to landscape and garden
Looking at a Yanmar 1510D with tiller, scraper box, and loader. They are asking $6,500
Tractor started right up and sounded good.....
It was on the small side but tiller looked like it was a good size for my needs and having a small front loader would be nice
This price seem acceptable on the left coast?
He said he rebuilt the steering column and it is the John Deere green, not red like most pictures I have found
Anything to look for? Common issues?
Hour meter shows 700 but I know that could easily be 2700 since only 3 places
Thanks
/ 1510D Advice #2
Better snatch it if in decent condition. That is a buyers price for sure.
Was it cranked when cold or already warmed up when you got there. Low compression or worn engines can be hard to crank when cold. They might crank right up when already warmed. Any excess smoke? Any blowby out the crankcase vent? All gears work? 4 wheel drive work?
/ 1510D Advice
I saw it at night so did not get to test drive it yet. He says the 4x4 works. It was a cold night and fired right up, no clue though if he had started it before I got there. No more smoke out of the exhaust than I would have guessed from a diesel. Looked pretty good, will probably go inspect it more this weekend in the daytime.
Any ideas why it's green and not red? They make them like that from the factory?
/ 1510D Advice #4
No green in the 1510's that I am aware of. There was a company that I believe refurbished and painted some green several years ago. Might ask the owner if he knows how it became green.
/ 1510D Advice #5
I'm a few miles west of you and bought one similar (YM186D, the US version) except I already had the tiller. That replaced a YM186D that lacked a loader ... So I'm familiar with two of them. I had to replace the steering box on the first one, and found I wasn't the first person to have the box apart. Rain can go down the steering column and rust the steering bearings, so this damage isn't unusual for these.
That's full price, but not unreasonable if the condition justifies it. If it looks solid and original you will get many years service from these. These are Yanmar's smallest model with Powershift and I found that feature makes it near an equal to my larger YM240 (YM2000).
These don't appear in the market very often in condition that justifies that price. If this one is excellent, jump on it.
/ 1510D Advice #6
As far as I know that US (Canada?) company that reconditioned imported Yanmars and painted them green was doing quality work, in contrast to the more recent VN reconditioning that for example buried Tractor Masters of Sacramento due to their failures during the warranty period.
If this one has run several years since it arrived, that's an excellent sign that it should run many more years.
/ 1510D Advice
Thank you for the information. Is there any way to tell when it was potentially reconditioned? Unit looked like it had been green and yellow for some time.
/ 1510D Advice #8
That's a good sign, about the only thing to watch out for on older Yanmars is a 'reconditioning' that consists of a museum quality paint job over a tractor assembled from unrelated junkyard parts, after a first lifetime in Japan then a second lifetime in the paddies of VN. If you don't see any evidence of that, then these things are near indestructible and will run for years with normal maintenance.
It sounds like this one has been in ordinary use for some years, that's a good sign that it won't surprise you. I think that the guy who painted his imports green had real pride in importing used-but-not-abused rigs from Japan, as I recall that his website declared. 10~20 years ago there were lots of good used tractors in Japan suitable to import and put in service here after just ordinary maintenance.
You still need to look it over carefully, ask questions, etc to verify it is what it appears to be. Take along someone with similar farm-tractor experience if possible. And test all the gears, lighting and charge systems, hydraulics, etc. None of the components that can wear out over decades - alternator etc, are hard to find or particularly expensive, for example a starter for my YM240 was $99, so you should discount the price for deficiencies but they shouldn't be deal-breakers if the tractor is fundamentally sound.
But that seller is asking a price that belongs with a top-condition tractor. My YM186D, US version of same tractor, was $4500 then reduced to $3500 when the seller was desperate to sell it for money to fix his work truck and get back to earning a living. It looks shabby, most of its life was operation by careless casual laborers of a landscape contractor. Aside from weathered paint and somewhat thrashed appearance, it is all original and seems like it should run a few more decades given decent maintenance. You should expect proportionally better condition than this for the price your seller is asking.
Photo - $4500/$3500 YM186D w loader, and behind it the one I sold without loader, for $2500 - for an idea of the condition you find at lesser price levels.
/ 1510D Advice #9
Finding any kind of 4 wheel drive tractor with a loader in East Texas for less than $6000 is rare. I never see tillers for less than $600, most for considerable more. Box blades on the other hand are numerous and sometimes sell as low as 2 to $300. No doubt, condition is important.
/ 1510D Advice #10
Yea those til lets around here are never less than $450ish and seems like there always $600. There not as common and cheap as they use to be!
/ 1510D Advice #11
Thanks
If the seller is happy with the price the buyer paid too much.
/ 1510D Advice #12
Good little tractor.....just check it out before you buy. Lots of good advice above. Check out the Hoye Tractor site......lots of good info on your potential tractor. If you do buy.....Hoye has most parts you might need. Good luck.
/ 1510D Advice #13
I was on craigs list last night.. Fredricks is listing a refurbed RS 1400 5 ft tiller for $795....RS1200 4FT for $600
/ 1510D Advice #14
IMHO. I would have thought the RS 1400 would cost a lot more. I gave Fredricks 675.00$ with basicly just new Tines in 09. It sure done a nice job for the time I owned it. If I was in the Market for a tiller I would have to check into that. I Sold it in 2 days on CL. for what I gave for it 3-4 yrs. later.
/ 1510D Advice #15
@tums20- I posted this reply in your original post, but copied it here so others can see the opinion of a fairly recent Yanmar owner. Short version is that's more than I'd be willing to pay in my area.
You may get more comments by posting in the Yanmar specific forum. There are a number of super helpful fellows over there and they know these old tractors in and out.
I'm new to the Yanmar owner's group having bought a YM240D a few months ago. It's the first tractor I've ever purchased though I've been around tractors for a long time. My experience is they are very well built and very durable. Mine was clearly well used but it still runs well provided I don't over do it. I'm used to larger tractors but this is what I could afford. I paid $2300 for mine so I'd say your price seems a bit high. Though the condition of mine certainly brought down the value some.
Having a front loader is super handy and I really think it's worth having. Once you have one you'll find all sorts of uses for it. I wouldn't overvalue the box scraper. Around here they are pretty easy to get for only a few hundred bucks. I don't know much about tillers but I wouldn't think it's worth more than a $1000. Where I am I think a 1510D in good shape with loader would get something like $4000. Add in the tiller and box blade and I'd think $5500 or less.
Do you have any photos? When I posted photos of the one I was considering I got lots of helpful comments- from likely year to the front tires being mounted backwards. Gave me some knowledge and bargaining leverage when I went to go see/buy it.
Too bad you weren't shopping a bit earlier this summer. A fellow on here had a YM186- a really nice machine- for sale. I think he ended up selling it for around $2000. Although not normally recommended for cost reasons, you could have added a loader if you'd wanted and still been under $4000. And the 186 is a nicer machine in my opinion.
Depending on how eager you are to buy, I'd keep looking, or offer $4000 and see where it goes. But to me $6500 is too much.
/ 1510D Advice #16
Mine? I mentioned it in the last paragraph of post #8 above (with photo), its also the YM186D in my sig photo below this post. Here's a longwinded thread where I asked here for advice on how to make it more presentable. Summary - it took a frustrating year to get anyone to come look at it then it sold to the first person who saw it.
/ 1510D Advice
Thank you for all the information. I am going to see it this weekend, I will try to get pics.
If it changes anything, the tiller it comes with is a Yanmar. He mentioned you didn't need the 3 pt to hook up the Yanmar tiller, but three point connections come with the scraper box.
I will try to get pics. By the outward appearance it was in better shape than yours California
Looks like overall they are good little tractors, probably about perfect for my use on 2 acres. Hopefully driving it and seeing it in the sunshine, not by flashlight, will help. Not many smaller tractors available at moment. A lot of Ford 8 and 9Ns but I do not want to go too big. There is a 2x4 JD 650 w/ tiller but no front loader offered at $4800 and a 650 4x4 with tiller and loader at $6500, though add says hydraulic leak. First timer, do not want to drop a load of money on a POS :)
I'll keep you posted thank you all again
/ 1510D Advice #18
I was thinking of your machine :). In fact there was a short while back when I was hunting for a tractor that I considered buying it and having it shipped. The shipping quotations quickly dispelled that idea. But I was convinced it was a great machine, well cared for, and honestly presented. But thankfully that headache is over for you.
/ 1510D Advice #19
Sounds like your market is a bit higher than around here. On my local craigslist there have been any number of YM1500D (without FELs) that were up for sale when I was looking several months ago. They are listed at $4500 and come with box scrapers, tillers, 4' brush hogs, etc. Very few have sold at that price. The one I purchased was only on craigslist for a day (YM240D with FEL for $2500). I guess my point is those are asking prices and if they were in a hurry to sell, they'd have lower prices.
If you're able test drive it, check the fluids, and post some pics back to this thread you'll get lots of comments.
Here's a thread you might look over if you've got the time.
http://www.tractorbynet.com/forums/yanmar/343391-looking-first-yanmar.html
The one I actually purchased for $2300 is here. Might be useful as a reference point.
The fluids on mine all checked out and it sounded good and no smoke. The aspect that I was underprepared to evaluate was the loader. It had one very leaky cylinder, which I figured wasn't a big deal. Knowing what I know now, I think I would have pressed him a bit harder on price (he was asking $2500). The loader really lacked strength, wouldn't lift the front of the tractor off the ground, had very poor curl (which I attributed to the oversized bucket), and had very slow rise. I figured all that would be solved by replacing that single cylinder. There's a whole other saga on here about my FEL troubles, but in the end I followed the advice on here and rebuilt them which didn't cost much (~$40 to redo all 4), but did take some time and running around but it was worth it just to learn how to do it. They are much better now, but not perfect. However, I've still got problems with the loader and I've purchased (but not yet installed) a new loader control valve.
My point is to check out the loader as well as the tractor. Get a load in it and lift, dump, etc. I knew my tractor would need some work at the price I paid. I'd hope at these asking prices, you won't need to do this stuff. Although I'd be tempted to change fluids unless the owner can convince you all that's been done recently.
/ 1510D Advice #20
Hydro leak can be as simple as a bad hose which is like $30-50 or could be a cylinder that needs repacking and those parts are like $20 plus your time.
I would not really want a ford N tractor for what you want. They dont really bushhog that well or do that. They can and will and lots do but on small areas as small as you i would want a smaller more nimble and efecient tractor.
2012 MCLAUGLIN/VERMEER V800AWXT VACUUM EXCAVATOR (A57880)
2012...
2008 FORD F-350 SUPER DUTY (A60736)
2008 FORD F-350...
2017 Ford F-150 Pickup Truck, VIN # 1FTEW1C85HFB72710 (A61165)
2017 Ford F-150...
2019 Chevrolet Cruz Sedan (A60352)
2019 Chevrolet...
2008 Lexus IS250 Sedan (A61569)
2008 Lexus IS250...
2003 International 9200I (A53317)
2003 International...
