BX25D and UnderArmor
/ BX25D and UnderArmor #21
That doesn't sound right. Are you sure you used the correct mounting hole for the bolt? Here is an under armor installation video. Might be worth double checking. Mine U-A rides high and tight.
It should be the correct holes. I read the manual and then looked at another Youtuber and my front brackets were in the same location. Rears can only go in onle place IIRC.
/ BX25D and UnderArmor #22
Only other thing I can think of is that your rear bracket is not lifting up as high as it should. The first time I raised mine, it actually went up so far it got stuck. I had to jiggle things a bit to get it to release. I don't have a MMM, but did you set the height knob to "TOP" position when you installed the UA?
/ BX25D and UnderArmor #23
Yes. However, I had to adjust the bolt behind the wheel just as mentioned in the manual. I just had to turn it more times than they mentioned.
2021 HYUNDAI HX220L EXCAVATOR (A60429)
2021 HYUNDAI...
UNUSED SDLANCH REMOTE CONTROLLED DUMPER TRUCK (A62130)
UNUSED SDLANCH...
2014 Cadillac ATS Sedan (A59231)
2014 Cadillac ATS...
(1) New 7ft Chain Sling (A61166)
(1) New 7ft Chain...
Bomag BW172 PDB-2 Compactor (A61166)
Bomag BW172 PDB-2...
2002 CHEVROLET 3500 FLATBED TRUCK (A60430)
2002 CHEVROLET...
