BX25D and UnderArmor
/ BX25D and UnderArmor #21
That doesn't sound right. Are you sure you used the correct mounting hole for the bolt? Here is an under armor installation video. Might be worth double checking. Mine U-A rides high and tight.
It should be the correct holes. I read the manual and then looked at another Youtuber and my front brackets were in the same location. Rears can only go in onle place IIRC.
/ BX25D and UnderArmor #22
Only other thing I can think of is that your rear bracket is not lifting up as high as it should. The first time I raised mine, it actually went up so far it got stuck. I had to jiggle things a bit to get it to release. I don't have a MMM, but did you set the height knob to "TOP" position when you installed the UA?
/ BX25D and UnderArmor #23
Yes. However, I had to adjust the bolt behind the wheel just as mentioned in the manual. I just had to turn it more times than they mentioned.
(3) HERCULES H-903 (A62131)
(3) HERCULES H-903...
Adkins Service Bed (A61165)
Adkins Service Bed...
UNUSED JCT QUICK ATTACH 60" PALLET FORKS (A62131)
UNUSED JCT QUICK...
UNUSED SDLANCH DIAMOND PLATED PLASTIC MATS (A62131)
UNUSED SDLANCH...
2021 John Deere 3046R Tractor Loader (A63116)
2021 John Deere...
2017 Bad Boy Outlaw XP 61in. Zero Turn Commercial Mower (A61567)
2017 Bad Boy...
