water well drilling info
/ water well drilling info #21
If you are running a lot of water, like three sprinklers on new sod for two hours, the pump only starts one time. :thumbsup:
Ha! I can vouch for that on my system. Or, in my case, running 3 sprinklers on new grass for 8-10 hours. The pressure holds at a certain level and the pump never stops. And the electric meter spins really fast! :)
/ water well drilling info #22
Actually the meter only spins fast enough to run the pump at the flow required.
/ water well drilling info #23
We have a similar well to the OP - 410' with 10GPM recovery rate, static water level is 80' normally but will drop to 110-120' in a dry summer.
The pump is set at 370-380', and it's a 1.5HP Gould 10GPM Model 10GS15 which is about the size you will want to generate 10-12 GPM which is enough to run irrigation and also your house.
I would also go for 3 Wire pump (10 gauge wire in the well) as 90% of the time its motor failure, so get the starting components above ground will save you $. Typically its $1500+ to replace the pump by the well co. So I just keep complete spare on hand ($700 range) ready to go and they charge about $4-500 to pull and replace in about 3 hours time.
On tanks as others have said, get the biggest or install two tanks for a long drawdown to eliminate cycling of the pump. The tank sizes can be confusing - meaning a 52 gallon tank with a bladder, the actual drawdown on 40-60 PSI setting is around 14 gallons so two in series gets you 28 gallons. Also on the switch, have them put in a low pressure cut out type - so if the well does run out of water the pump shuts down at 18 PSI protecting the pump.
Pipe size 1" 200PSI pipe should be fine - this is the heavy wall - comes in 500' rolls, the 1.25" should not be needed unless you intend to use this commercially and need high flow.
Torque arrestors - at 400' I would use three of them spaced every 100 feet to keep the wire from abraiding on the well casing.
/ water well drilling info #24
Hmmm, are the pumps variable? I was under the impression that it was either on or off. I guess some are variable, just not sure of whether mine is or not.
/ water well drilling info #25
The cycle stop valve sets the max pressure, the pump motor turns fast enough to supply the flow required: Cycle Stop Valves, Inc.
/ water well drilling info #26
About 7 or 8 yrs. ago a family I built a house for installed the on demand pump in this link and it certainly impressed me how well it worked. He recently sold the home and saw it was working as good as ever. Watered a few acres and the house hole use. This is my only experience with this system.
Goulds Constant Pressure Systems
/ water well drilling info #27
I install lawn sprinklers , I do a lot of well systems . When the customer has the constant pressure system , they work great . The customer can even shower while the irrigation is on with no pressure loss . Its the way to go
/ water well drilling info #28
Interesting. Thanks for the info on the cycle stop valve. Very cool.
/ water well drilling info #29
I would have the company that drilled the well install the pump. My neighbor just built two big chicken houses and had a well dug for them. The water was a little brown and they thought it would clear up. In about a week it started pumping mud. My neighbor tried to pull the pump and it was stuck. the well co. came could not pull it. the well co. brought in the drill rig and tied again and the pump was still stuck and they could not get the pipe loose from the pump. They tried using the "drill" to push it down and they got 100' of drill rod stuck in the well. after working two days and getting some kind of 'air hammer" thing they got out 20' and quit for the day. The guy was just worn out trying to get it figured out. The farmer has two houses full of chickens and is hauling water in a semi tanker.
I go into all of this to say If you have problems even small problems it is better to have one co. to deal with instead of two blaming the other and you paying the bill. Ed
Talked to neighbor again the well driller left 80 ft of drill rod in the well and left. said he had to go drill a well for someone else. So he has 2 BIG chicken houses with thousands of birds in each and the well driller just goes his way. They just dug over 700 ft of waterline from a barn to get water to the houses. Not done yet, still using the tanker. Hope the old well can carry the house a milking parlor, the heard, and the two old chicken houses with the new ones as well. Ed
/ water well drilling info #30
We are looking at 16 acres on a mountian top in east tenn. The well has been drilled, so i called the well driller for info. He told me it has 300 ft of casing and 105 ft more to get to the water for a total of 405 ft. It is 6 inch casing.
Asked about GPM and told me it was 25 gallons per minute. Is this a good flow rate ?
I will just need to get a pump installed if we buy the property. Any suggestions on type of pump and the do's and don'ts !!
Thanks
Chuck
If I read this right your water surface is 405' under? Hopefully that's not correct. I'm going to guess that once the water has been hit, it will fill the casing to a higher level.
/ water well drilling info #31
Make SURE you get a centralizer on the first foot of pipe above the pump! Spacing them out every hundred feet is a good idea. Also, make sure they install centralizers on the hanging pipe as well! I recently had to pull my pump because the jabroney put ONE centralizer above the pump. The stinking wires rubbed through the insulation and shut my pump down. $500 dollars later and pulling the pump twice, I got it fixed by myself. It took almost 3 years for those wires to wear through and break but it happened!
/ water well drilling info #32
My well is only about 100'? I can see water at around 40' and watch it go up & down as the pump cuts on & off. Maybe being on top of the mountain instead of near bottom makes it so deep.
/ water well drilling info #33
Hello 747driver. I would suggest that you run the bore to a 5000 gal tank so that WHEN, not if , the pump stops you will still have house water while the bore pump is being repaired. I would also recommend that the toilet be on bore supply so that the water absence is noticed quickly. On mine the bore supplied the stock water as well.
/ water well drilling info #34
not sure you have your well installed yet, but I am about to put in one of those Stop Cycle Valves, I won one on ebay for .99 cents and it was taken off and put on a shelf because a plumber told the homeowner he did not need it when he put new pressure tanks in :). Anyway, my little 35 gallon or whatever it is was fine before we had more animals to water and three kiddos but now I have noticed the pump will kick on and off alot lately and this will stop that. I will let you know how my csv helps my setup as I was about to purchase a 80-120 something gallon to increase my capacity on hand and lengthen my run time. My pump's life is already cut short and living on borrowed time from a dry well condition or stuck contacts on the pressure switch a few weeks ago (I'm working on a solution to this utilizing an arduino micro controller and a current sensor).
If you do install the pump yourself, use a good quality rope or stainless steel cable to attach the pump too. build an a frame and use a piece of pvc and bend a good long sweeping 90 degree in it at the top to keep from kinking poly pipe(use a torch to bend the pvc). two simple prusik knots will allow a safe way to lower the pipe into the well and it simple slides up and down, similar to descending a rope but on a pipe and the rope is attached to the a frame. If you have a long rope or cable use a few pulleys to make life easier when lowering. Almost a necessity at that depth as that is a lot of weight Use lots of good quality tape to tape the power wire or even some rubber strapping in a knot. This will keep wires from touching casing and eventually short out and cause you to pull pump to repair wire damage.
/ water well drilling info #35
Since this threat was dug up...
Make a well inspection a condition in the offer to purchase. They will test the water, flow rate, etc. Without it, assume there is a small chance the well would require replacement - and that's not a cheap operation at 400'. Make sure they know that there is no pump installed, as I'm not sure if/how they will do drawdown/etc.
/ water well drilling info #36
Realize that a Cycle Stop valve is nothing more than a regulator. This means the pressure before the regulator will be very high. Although there will be fewer starts, I'm not certain I'd like my pump laboring to produce a pressure that is beyond it's design spec. At that point either the amps will be off the chart or the pump will be cavitating. Cavitation will wear an impeller just as fast as pumping sand. Personally, I'd go for a larger pressure tank before I went with a Cycle Stop valve. Also, check your bladder tank as it may have developed a leak. Frequent starts and dry runs are a symptom of the tank pressure being off. The correct pressure is 2psi higher than your pumps cut in pressure. If you see any moisture come out of the schraeder valve, then the bladder has failed and the tank needs to be replaced.
/ water well drilling info #37
/ water well drilling info #38
Have to disagree with most of this. Don't attempt to run coil plastic tubing on what is likely a 500+ foot well. It's too heavy and is not the best use of coil (black) plastic. Don't attempt to install this pump yourself. Odds of dropping it are high and odds of fishing it out after dropping are low. And, NEVER use rope on a pump with coil plastic. I know, most of the pumps come with a place to attach it, but the coil plastic is much, much stronger than the rope. Plus, when the rope breaks, guess where it goes? That's correct - it all falls right down on your pump - locking it down the hole. How does it come out then? In pieces because you have to bring in a cable tool rig and drill it up if it can't be fished out.
/ water well drilling info #39
This is not true, the amps will be lower than if you remove the CSV and let the pump run at full flow. It is true the pump will have the maximum pressure that it is designed for but I never heard of it cavitating. The pump here was installed ten years ago and is still running good.
Mine draws 8.3 amps with the CSV set at 50 pounds and the hydrant wide open, and a lot less at 1 gpm. The electricity consumed is directly proportional to the water flow in gallons per minute.
The CSV and pressure tank are underground, no heated well house to worry about freezing when the power goes off during an ice storm.
We are still considering this property. Thanks for all the good advice, as now we have a much better understanding of well drilling and pumps. If we decide on this property, then as previous posts have mentioned, we will have a well inspection done as part of our offer !
2006 Peterbilt 379 T/A Sleeper Cab Truck Tractor (A64194)
2006 Peterbilt 379...
SET OF (4) PORT A POTTIES (A65643)
SET OF (4) PORT A...
1996 International 4700 Box Truck, VIN # 1HTSCABP2TH265415 (A65563)
1996 International...
New/Unused Wolverine 44in Mini Grapple Bucket (A65583)
New/Unused...
New/Unused Wolverine 43in Mini Rock Bucket (A65583)
New/Unused...
AUCTION STARTS HERE @ 9AM (A65053)
AUCTION STARTS...
