John Deere 355D Overheating
/ John Deere 355D Overheating #1
craigst
Albany WI
John Deere
I have a JD 355D that is overheating. I had a coolant leak, and I changed the hoses and coolant. The tractor started overheating and I changed the thermostat. There are no leaks from the water pump, but I still have the leak near the reservoir. It only happens when it overheats. I noticed that one side of the radiator is very hot, and the other side is much cooler. Any suggestions?
/ John Deere 355D Overheating #3
f flushing doesn't solve the problem you may need to have it reworked at a radiator shop. The last time I had to rod out a radiator was on my 450 Deere dozer and did the job myself. If you don't have a lot of soldering experience this best left to others.
/ John Deere 355D Overheating #4
sounds more like radiator plugging to me as well.
but to hit on it. make sure you have correct antifreeze / water ratio. you can pickup a cheap tester at most automotive stores
/ John Deere 355D Overheating #5
It's a cross flow radiator and it should be hotert at the top and cooler as you go to the bottom of the radiator where the out let to the water pump is. If it hotter on one side than the other than I agree it has internal blockage.
(INOP) 2012 CHEVROLET TAHOE (A59823)
(INOP) 2012...
John Deere Z997R (A60462)
John Deere Z997R...
Like New! Kubota L2501 HST Tractor Package – LA525 Loader, RCR1260 Cutter
Like New! Kubota...
Cat CB24B (A60462)
Cat CB24B (A60462)
DOBBS 48in Forks and Frame Skid Steer Attachment (A61572)
DOBBS 48in Forks...
2019 Chevrolet Tahoe SUV (A61574)
2019 Chevrolet...
