Grappling fun - A Picture Thread....
/ Grappling fun - A Picture Thread.... #421
I have to disagree. A 6ft 1/2" ID hose connected to 2ft of 1/4" will have a higher flow rate than 8ft of 1/4" hose (assuming the same head pressure). At least that's what the laminar flow physics says.
How does your theory fit with the fact that flow restrictors are typically only the thickness of a washer? I'm not a physicist but it seems pretty clear that the vast majority of the difference will be because there is even one inch of 1/4" tube.
/ Grappling fun - A Picture Thread.... #422
Slightly. But the real drag is in the 1/4" lines and the smaller fittings. If he was going more than 12' total, then yes, you could measure the loss. In this case, the 1/4" line is a restrictor and there would be a pressure drop because of it (the velocity of the fluid would also change).
http://www.lifcohydraulics.com/catalog/pdf/Hedland-(Flow-vs.-Pressure-Drop)-In-line-Flow-Meters.pdf
/ Grappling fun - A Picture Thread.... #423
I think if you go back and re-read you'll see that this is missing to point slightly.
My comment was also missing the point to some extent because diameter has a much greater effect on pressure drop than length (but length does nevertheless matter). What this means is that even very short reductions in diameter can cause a large pressure drop (as in your washer example). However, I would still prefer to have a 1/2" line cnvert to 1/4" at the end rather than it be 1/4" for the entire distance.
But back to the pictures! Giant grabber arms for the kid in all of us are awesome.
/ Grappling fun - A Picture Thread.... #424
Here ya go. :thumbsup:
/ Grappling fun - A Picture Thread.... #425
You're giant grabber arm is bigger than my giant grabber arm... Just don't tell my 3yr old!
/ Grappling fun - A Picture Thread.... #426
I am a little confused by this. I can see that you get pressure drop from any restriction while there is hydraulic fluid flow but doesn't the pressure drop or loss become zero or negligible as the cylinder slows at the end of its travel because there is no longer any flow. So there is no reduction in force holding or grabbing the load due to restrictions. Is this correct ????
/ Grappling fun - A Picture Thread.... #427
I think so. Here try this experiment. On you garden hose turn the water flow down to just a drip by nearly closing the water valve. Now lest say the water pressure on your system is 60 lbs. Now just a drip ever few seconds is coming from the hose. Put your thumb over the end of the hose, wait several seconds and you will start to feel the pressure building under your thumb. After some time the full 60 lbs per square inch will build up under your thumb. The flow rate of the flow is very very low, just a drip, but it will still develop the full 60 lbs per square inch under your thumb, it just takes a long time to do it. If a small amount of water leaks past your thumb, it will take some time to develop the 60 lbs again, but it will happen.
So the "flow restrictor" of the water valve nearly shut slowed the flow rate down to nearly nothing, but it still delivers 60 lbs per square inch of pressure over a long time period, at nearly zero flow rate.
/ Grappling fun - A Picture Thread.... #428
That is correct, but I am also confused by the term "pressure drop". From my experience, in an open center system, pressure increases with resistance to flow. Instead of "pressure drop", it is "flow rate decrease"
When the grapple lid stops moving, pressure will increase until the relief valve opens. That is maximum clamping force.
/ Grappling fun - A Picture Thread.... #431
Nicely explained, James! Your experiment would make Bill Nye The Science Guy proud! :thumbsup:
/ Grappling fun - A Picture Thread.... #432
Seems like the confusion in terminology is just over where we are measuring when we talk about an increase or drop in pressure. Restricting the flow causes the applied pressure to rise at the point of restriction, but results in a corresponding drop of applied pressure measured at the cylinder downstream, until the volume of fluid passing the restriction catches up to the original flow rate. James' experiment with the garden hose illustrates that.
/ Grappling fun - A Picture Thread.... #433
Thanks K0ua. Easy to understand that.
gg
/ Grappling fun - A Picture Thread.... #434
Bottom line, the output from a 1/4" line is perfectly adequate to operate a grapple cylinder. I use 3/8" because it is tougher than 1/4" and more flexible than 1/2". The last 18" or so are 1/4".
/ Grappling fun - A Picture Thread.... #435
From the bush to the mill....white spruce dead-fall.....grapples are great!!
13 foot log going down an 8 foot wide bush road makes things interesting:
....and finally on the mill:
/ Grappling fun - A Picture Thread.... #436
Knocking the dirt out of the newest stump by lifting and dropping it and then grapple holding it to square cut the top-
This one was heavier than most
garage tree stump 002.jpg grapples are the best:)
here is a pic of the tree- the stump was attached to before i dropped itGarage tree drop 001.jpg
/ Grappling fun - A Picture Thread.... #438
Yeah-:D it's still intact,
I thought about having it done professionally but we had already removed several other shorter/smaller trees using the same method. So just went for it, gotta say i didn't need any coffee during or after:laughing:
I posted about it over on the tractors and wood thread- using a long heavy duty cable/ rope setup hooked to the JD dozer and then wedge /hinge cutting the tree and pulling it over.
Here is the grapple picking up the base of the tree where it landedGarage tree drop 024.jpg
Wife did video it on her phone -but not sure how to post it without linking to her facebook page..??.
/ Grappling fun - A Picture Thread.... #439
I had to take it off because it caused too much damage.
Steve
Neat scale. I am guessing that is a half ton. Have you ever weighed it?
My 3/4 ton GMC weighs 7300 pounds, front axle 4100, rear axle 3200.
seems kinda light for the back half of the truck.
By picking up the backend he is transferring some of the weight to the front axle.
I think it is somewhere around 4500lbs. 05 Silverado Z71. Roger is correct, I would not be able to lift the front end at all.
Steve
I'll have to try it with my truck and see how it compares to the weight on the axle.
I had the crane scale on and remembered these posts from last year. My truck has been weighed at the Co-op, front axle, 4100 pounds. Rear axle 3200 pounds.
2344 pounds lifting from the receiver hitch, a lot less than I expected. Bullitt is right. :thumbsup:
/ Grappling fun - A Picture Thread.... #440
some from today, cleaning up fence lines
2014 Glasstream 360 SCX Twin 400R Mercury's with Triple Axle Aluminum Trailer (A61569)
2014 Glasstream...
2019 CUSHMAN HAULER PRO ELECTRIC GOLF CART (A58375)
2019 CUSHMAN...
2000 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2000 Bobcat 863...
John Deere 6125R (A60462)
John Deere 6125R...
(96) 1X8"X10' PONDEROSA PINE BOARDS (A62131)
(96) 1X8"X10'...
John Deere Z994R (A60462)
John Deere Z994R...
