Grappling fun - A Picture Thread....
/ Grappling fun - A Picture Thread....
Great photos Terry! I love that last shot!
/ Grappling fun - A Picture Thread.... #442
Here is my new (new to me) tractor with a 72" grapple. Grapple1.jpgGrapple2.jpgGrapple3.jpg
/ Grappling fun - A Picture Thread.... #443
/ Grappling fun - A Picture Thread.... #445
Thanks MJ.
This Tractor along with my other 2 has made life a lot easier :D
/ Grappling fun - A Picture Thread.... #446
Doing some more road clearing the last couple days.
Found a great reason for two lids vs one too. You can shove a debris pile into a tree to condense it, and then close the lids around it. Try that with a single lid! :)
/ Grappling fun - A Picture Thread.... #447
First and only reason for two lids I've ever heard. We'll put it in the record book.:laughing:
/ Grappling fun - A Picture Thread.... #448
Don't know how I managed to get this pile of brush into a single lid grapple without a tree around:
/ Grappling fun - A Picture Thread.... #449
Did you do it in a single move and bite?
Didn't think so... ;)
I'm not going to argue one is better or worse. I just pointed out a method singles can't do.
I have a 12' wide lane I'm working. With the grinder out back my tractor is 24' long. Pushing and crimping from multiple directions isn't physically possible like shown in your wide open field.
/ Grappling fun - A Picture Thread.... #450
Did you do it in a single move and bite? Didn't think so... ;) I'm not going to argue one is better or worse. I just pointed out a method singles can't do. I have a 12' wide lane I'm working. With the grinder out back my tractor is 24' long. Pushing and crimping from multiple directions isn't physically possible like shown in your wide open field.
Actually it was one bite! What I didn't show was that it was one bite out of a huge pile so the pile acted as a back stop. Also, the brush was very sticky and dry. My grapple jaw was at least a couple feet from the front of the load. More typically I roll brush over to compact it but I have used tree backstops too. No doubt your trick with the double jaw would work better around ornamental trees. I just push against trash trees and don't mind scraping the bark.
/ Grappling fun - A Picture Thread.... #451
I'm in! I just picked up my Everything Attachments 60" Single Lid Wicked Root Grapple from the freight terminal. It's raining cats and dogs here so pictures tomorrow. I can't wait to get it hooked up!
/ Grappling fun - A Picture Thread.... #452
/ Grappling fun - A Picture Thread.... #453
Huge pile takes more than one move and bite to create. You made my point. ;)
I have crop trees that damaged bark has zero impact on (logs or firewood) as long as I'm harvesting them in the near future. I can mash a pile of slash into one without any negative impact on my bottom line.
/ Grappling fun - A Picture Thread.... #454
Now I can grab it on each end!
It's nice to be able to pull it out the "long way".
/ Grappling fun - A Picture Thread.... #456
I understand your point. The huge pile in question was made by an excavator and big backhoe however. I was just cleaning up.
All grapples are better than no grapple. Even an added grapple arm on a standard bucket is WAY more useful than a bucket alone in moving brush and logs. We can all agree on that I'm sure.
Now, tell me how you would have pulled this rock out of the ground with your two lid grapple. Rock was buried until I snagged it with my little 48" grapple. I thought it was a small rock that had grown over the winter and was hitting my mower blades so I stuck the grapple "under" it, clamped and lifted. Not sure I could have done it with a double lid as the rock weighs something over 2000lbs and having it on one side of the grapple would have been dangerous.
/ Grappling fun - A Picture Thread.... #457
Island, how did you estimate the weight of that rock (granite?)?
/ Grappling fun - A Picture Thread.... #458
From memory. I measured the rock several years ago and calculated volume. It is granite. It lives about 50 feet from where I dug it out.
I didn't search for the post I made here on TBN many moons ago when I gave the measurements and calculated weight. As I recall it was significantly more than a ton but not 1.5 tons. It was held out on the tip of the grapple so was about three feet from pivot pins. I could only lift it a little higher than you see in the photo and my loader is rated at 2760lbs to full height at pivot pins. The grapple held it with just the one upper tine which got splayed out. Needed some heat and hammer to straighten it.
/ Grappling fun - A Picture Thread.... #459
I've moved several hundred yards of taconite with my 3/4yd bucket. 2Klb rock off one side would be cake.
/ Grappling fun - A Picture Thread.... #460
Ya, I think many would be surprised how much of a difference it makes as you move away from the effective point of pivot. I also think the distance and reduction in lift capacity are not linear. In other words, the farther out your load the bigger difference it makes. So a few inches at the end of your loader can make a huge difference in lift capacity.
2016 Ford F-250 Warner Service Truck (A61573)
2016 Ford F-250...
2001 16 Ft. Wellcraft Boat w/ 2000 19 Ft. Boat Trailer, (A61574)
2001 16 Ft...
2005 JOHN DEERE 450T LGP CRAWLER DOZER (A64279)
2005 JOHN DEERE...
2010 FORD RANGER SINGLE CAB PICKUP TRUCK (A59912)
2010 FORD RANGER...
Deutz D 2011 L03 Engine, 3-Cylinder Diesel (A63689)
Deutz D 2011 L03...
UNUSED WOLVERINE TDB-11-84W-84" BUCKET (A64281)
UNUSED WOLVERINE...
