Flail Mower Let's talk flail mowers
/ Let's talk flail mowers #2,441
I'm glad you posted that link.. which are the blades that fit the Caroni? Or are there options? Mine will be a light use unit most of the time.
No those are not the blades that fit the Caroni. I'm pretty sure that if you search this thread you'll find exact Flailmaster part numbers that I posted a couple/few years ago for knives and clevises for the Caroni TM1900. I'm on my cell phone now so cannot easily search until I get home. Let me know if you have trouble.
/ Let's talk flail mowers #2,442
33 I further investigated. I can spend another $100 and try the inverted V side slice blades. If there's improvement I'll report it. If I get the same results I'll report it and sell the mower.
Good luck. Hope it works out. Are you getting both blades and attachment hardware? I'm just guessing but I think you'll need a clevis or strap of some sort to attach the Y/l blades. Not sure if your current setup already includes that.
/ Let's talk flail mowers #2,443
Yeah, I'm calling "forward-down" as same-direction-as-tires... I'm calling "forward-up" as opposite-direction-as-tires.
"forward-up" is not possible, the shaft either rotates forward or reverse. I would call it "reverse-up", since the shaft is rotating opposite of the tires when moving forward and the cuttings go up and over the shaft. :2cents:
/ Let's talk flail mowers #2,444
TomAto TomAHto ... In my opinion, "forward-up" makes more sense. :D I'm sure we're both wrong anyhow, there's probably a technical term.
/ Let's talk flail mowers #2,445
Here is the text of a post I made in 2010. I doubt the prices are accurate but the part numbers should be.
""I know this is a general flail thread but as there are a lot of Caroni users and potential buyers reading it I thought I'd give some info on replacement parts that might be of use. All parts are available from AgriSupply and they are pretty good about shipping quickly. However, the cost of their flail knives and associated hardware is pretty high compared with what Flailmaster sells. Unfortunately, Flailmaster doesn't carry Caroni specific parts and they don't sell metric parts. Still, through trial and error I have found a few things that might be of help.
First, the Flailmaster M-108381 heavy duty forged knife is exactly the same dimension and weight as the Caroni flail. They cost $1.45 each or less than half of what the Caroni flail costs from AgriSupply. Over time you'll definitely need some to replace losses (especially if you are in rocky areas like New England).
The other parts that need replacing with the flails are the clevis and nut/bolt. AgriSupply charges dearly for the clevis at $6.49 each. The grade 8 10mm x 80mm nut and bolt costs $1.39 which isn't too bad.
I have found that nearly all my replacements have come as a result of clevis failure. Of course if the clevis fails you lose both knives too. The nut and bolt need to be replaced too so each loss mounts up to over $13 in parts if you buy from Caroni.
Unfortunately, I have not yet found an alternative source of the metric sized clevis. Basic dimensions are 55mm tall and 45mm wide outside with a 10mm bolt hole. Flailmaster does not have anything that matches. Closest thing flailmaster has is their beefier M100761 which is just a 1/8 inch too wide and one ounce heavier. I could live with one ounce heavier especially if you replace all of them but the clevis is too wide for the Caroni mount. I tried grinding one to size but it leaves the ears being narrower than the original Caroni clevis ears so figured that was not a good idea. Too bad as the bigger gauge Flailmaster clevis costs less than half of what Caroni charges for a smaller gauge and the larger one would be more durable.""
Note that since that post I and others have found that the Flailmaster clevis can indeed be made to fit the Caroni. It just takes grinding/flap sanding about 1/8 inch off the shoulders of the clevis and pinching the clevis together with a good vise. It only takes about three minutes work each if you do them in batches.
And, I don't worry about the slight extra weight of the flailmaster clevis either. I have about half flailmaster and half Caroni clevises at the moment. Every time a Caroni clevis fails it gets replaced with flailmaster knives and clevis. Haven't had any failures of flailmaster clevises since I started using them a couple of years ago.
/ Let's talk flail mowers #2,446
Cool, thanks IT
/ Let's talk flail mowers #2,447
This is what Alamo calls Foward Rotation, leonz calls it ccw, would this be "forward down"? My front mount rotates the other way, opposite of tire rotation moving forward.
AS my power wigged out before I was able to finish this today GGGGGRRRRRR!!!!!!
I will start once more.
The way Alamo Industrial has configured these flailmowers allows them to be used
with hydraulic drive using PTO shaft mounted pumps and hydraulic motors for the
rotor drives for the wing mowers and or simply rear mounts and in some cases
allowing three flailmowers to be operated at one time with one or more flail mowers
in the raised position.
They advertise the same mowers for sale in Europe. I am unsure if they are built here
or in Europe but with MFN status "Most Favored Nation Status" between England and
the United States; they may be built here with metric parts anf then shipped simply using England for an finished inventory and parts depot.
NOW as you look at the sie view of the flail mower look closely at the mower shroud where
the pressure gradient is created by the high speed rotation of the flail mower rotor and the
free swinging flail knife pairs.
Follow the arc of the shroud to its end where it meets the rear apron where a portion of the
clippings hit the lower shroud and the balance of the clippings bounce out after hitting the rear roller.
NOW the mower will clog in Heavy and tall brush unless the mule is crawling on its first pass.
The Maschio flail mowers sold with the Land Pride brand get around this by having a trash door like some of the original Mott flail mowers This allows the end user to have the ability to mow real deep crap with a smaller mule and avoid plugging the flail mower and or burning a set of belts.
One of our members purchased an alamo flail mower his contract mowing work and as far as I am concerned they took advantage of him and have felt this way from the beginning of how it started for him as the Alamo salesman praised theier mowers to the heavens.
He ran into problems with clogging and damaged knives the time needed
to repair broken knife sets in difficult highway mowing conditions with garbage
and debris hidden in the grass tracts he is or was mowing.
I think i remember stating that he contract mowed 18,000 plus acres of highway shoulders and verges with a brood herd of rotaries and medium horsepower mules in the State of Kentucky.
I am unsure nor do I remember what mowing speed he used or if he mentioned
it when using the Alamo flail mower he purchased. Time was-or is money for him
in a mowing season.
If he had been sold a wide high horsepower flail mower/flail shredder like a
15 foot cut model 1700 Hiniker flail shredder he would have had a much
different experience as he would have been able to have a flail mower that
could be equiped with a running light light kit, end towing kit, skid plate and
hydraulic lift cylinders to speed both the haulage of the flail mowers and the
set up of the flail mower prior to mowing and with a fifteen foot cut operating
at 2 miles per hour he would have been able to mow
at 176 feet per minute
times the mower width 15 feet wide = 2,640 sqaure feet every two minutes times thirty minutes would allow him to mow 1.8 acres per hour at 2 miles per hour in a straight line
BUT the width of the mower saves return trips and reduces overlaps and mowing can be
faster with different mowing conditions.
In saying that it is hampered by its width in narrowed mowing areas where space is limited
for maneuvering.This can be overcome with a narrower cut flailmower of course with a high knife count to maintain a 2 inch cut.
Saying that a flail shredder is a much stronger mower than a standard duty flail mower
and Farms with junk was not treated as I would have wanted to see him treated as the
Alamo industrial salesman should have not sold him a flailmower in my opinion and told him he needed a medium width flail shredder for the work due to the conditions and the acreage
he was mowing. He probably would have recieved more rotary cutter sales if he had been
honest about it as he most likely knew about heavy crop shredders in my opinion.
This is where a front mounted flail mower on a bidirectional tractor would shine in
performance as a standard flailmower could be mounted on the front or rear of the
bi-directional tractor in the example allowing for faster mowing without the need
to turn around saving time, fuel, braking, and tires by simply dropping the wider
flail shredder near where it can no longer be maneuvered safely and finish the mowing
job with the smaller width flail mower shredder. when that section was done the
operator would simply travel to to next location by end towing the wider flail mower
to the job and then re-attaching it to the bi-directional tractor to begin mowing again.
I will tell you that the ditches along the roads on the secondary highways in
New York State look like crap from the lack of mowing- I am still waiting to see if
they mow my ditch.
I am not trying to make a mountain out of a mole hill here, honest but I quite often
expand on the subject of flailmowers as quite often happens and I try not to be boring about it.
/ Let's talk flail mowers #2,448
No you are not wrong TSO it all depends on the design of the mower
shrouds discharge point as I mentioned in my last post.
/ Let's talk flail mowers #2,449
Having a rear door on a flail takes away one of the main reasons for using a flail, safety. Mott's have never had a trash door. There are so many variables with mowing it's impossible to know exactly why certain problems occur without knowing the exact details. Too wet, too fast, PTO too slow, not enough HP for the job, wrong knives, etc. Interstators hyd's don't run off the PTO. How could you use the rear 3pt. mower? The hydraulics are run off the crankshaft at the front. Alamo flails are designed for tall grass and weeds up to 1" diameter. If a sales rep recommended them for brush cutting he should be fired. Alamo does have front mount Versa-Pro set ups for bi-directional tractors with Interstator style side wings. These set ups as well as Interstators are not cheap but the widest models cut over 21' wide. You would get a little better cut with a front mount because the tires wouldn't have pushed the grass down. I would like to see a brochure for a flail mower that mentions pressure gradient? Flails create a lot of wind but that's because the knives have to spin fast enough to do an effective cutting job. If you look at a flail spinning, it looks like it is moving from one side to other because of the way the blades are staggered on the rotor.
/ Let's talk flail mowers #2,450
Thanks for the info ArcWeld - I really like the Motts/Alamo mowers so it is interesting to read about them and the design.
/ Let's talk flail mowers #2,451
We have a posting and an attachment here on the forum that Island tractor was so kind in uploading that discussed the use of a flail shredder at a pineapple plantation in a doctoral students study in agriculture.
I have it in my files but I cannot find it right now but its here on the attachment page of the forum.
The Maschio/Land Pride flailmowers with trash doors have been made and used for years. I agree there is some risk with using them; when using them as crop shredders or in vineyards or orchards there are few if any pedestrians in the area.
In one example the INO flail shredders have several options available in mounting where the front mount was attached to the three point hitch in the front of the "standard" row crop tractor and the two rear mowers were attached to the three point hitch in the rear and powered by the 540 or 1000 RPM PTO.
Or they use the gang of three mowers in the rear with gearboxes and cross shafts from the power take off.
If I could attach video here I would be drooling all over the keyboard and probably short the computer in a cloud of smoke.
The Mathews Lawn Genies used air paddles in thier wonderful design which creates
additional air movement to pull the clippings over the flail mower rotor at a very high speed of velocity to remove the clippings with the aid of the slde slicers or blow them into the collection bag or basket just like a full width flail chopper would through hay ensilage into a silage wagon towed behind it.
Any air flow is properly referred to a pressure gradient whether it is under a flail mower shroud or the wind
Some flail chopper harvesters use a cross auger and impeller fan to blow the cut hay ensilage into the wagons.
The side slicers knives originally sold by Mathews for the Lawn Genies were are beautiful
example of mechanical and aeronautical engineering which I can say with a straight face.
This also goes hand with the knife hangers which do not require tools to add or change
knives or install dethatcing blades-i(nsert a heart or happy face here).
The design of these side slicer knives and the knife hangers is an aeronautical engineers dream.
The side slicers when hanging oppose each other at 45 degree angles at the tip.
The cutting edge on the hardened finish cut knive is 37 degrees.
These side slicer knives have tapered cutting edge which begins at the
point where the bend is made for the 45 degree angle of the sie slicer knife.
The tapered cutting edge continues to the point on the side slice knife where there is exacly
one half of an inch of new metal left on the base of the side slicer knive(this is a wear guage for end user)which is 1/4 of an inch for each side.
The key to this is the excellent knife design which sadly is no longer stamped.
The knife was designed with a mounting slot which permits the knives to become airborne but restrained where the knife at speed becomes horizontal in flight around the orbit of the flail mowers rotor to give the user a beautiful flat mowed turf.
The Mott knives are longer as compromise of sorts as they used a piece of round barstock to attach the knife mounting stations using thick drilled piees of bar stock for the knife hanger to save money in the design. The Mathews design is a step up from that.
The Mathews flailmowers were not designed to be towed in large numbers like the Mott Motorised flail mowers that were towed with jeeps and tractors when used in mowing and clearing brush.
I wish I could find out what happened to the three point hitch Mott flail mower that had a Wisconsin V 4 engine on it mounted on the right side of the mower that I personally know of. the mower was owned by a local resident but it has been 30 years since I saw it being used-he may still have it, but I am not sure.
This flail mower rotor which is a beautiful piece of mechanical engineering
is very well constructed.
The only bad part was the wheels of the lawn genies as the bearings did not last very long-but I dont think anyone planned on seeing them last 35 years either like mine with the original 16 horsepower Briggs and Stratton I/C Engine with the cast iron piston sleeve.
It is easier for me to list everything in order for everyones benefit so bear with me; no bears were pestered or harmed during or after this discussion.
1. The Mathews Lawn Genies were made for large lawn and estate care up to five feet wide.
2. They were/ are designed as a standard rear discharge flail mower
3. the flail mower used an 8 horsepower engine drive system for the 36 inch unit and a 16 horsepower single cylinde B+S for 48 inch models you cannot buy the I/C engines anymore ;^(
These smaller units were towed by the garden tractor that was used for the work of mowing and picking up leaves. The throttle control and the basket lifting rope or winch was mounted on a square tube that was attached to the mowers hitch. You could move the throttle stand to allow the garden tractor to turn more sharply and avoid bumping into the throttle stand with a tire or the fender of the garden tractor or the seat back.
4. the 60 inch models were designed with three point hitch mounting and 540 RPM drive and the collection basket was raised and lowered with a hydraulic cylinder, I dont remember if it had a pair of them right at the moment.
The 60 inch model also hasa pair of greasable caster wheels to allow easier turning without digging in the turf.
The collection basket on the 48 inch model was raised with a wire winch. The 36 inch model used a rope to lift the collection bag frame to dump it. I owned my fathers 36 inch model and I now have the 48 model that my father had before me. I also had his 36 inch model that he traded for the 48 inch model(wish I still had it).
The 36-48-60 inch models have a diverter door that throws the clippings back down to the ground rather than directly in the collection baskets of the three models. this helps when cutting tall brush, leaves or wet grass to allow it to dry out quickly.
If I was to bring over a comparable model from Europe it would not have caster wheels and it would ride in side skids to mow or dethatch turf. The same model would require thee point mounting and use a pair of hydraulic cylinders to raise the collection basket and 540 rpm anf would cost about $15,000 USD before shipping from Italy.
Needless to say i wish I had them both just like the two Toro snow pups I had in the herd-978 and 1985 models-should have had them fixed even though they were worn out and I would have had four of them to use.
5. the Mathews Company Lawn Genie had two major options that were available to the purchaser.
a. a leaf recutting screen
b. a front full width roller to prevent scalping on uneven terrain and along curbing.
The leaf recutting screen must be removed for mowing grass.
NOW the flail mower rotor on the 36-48-60 models is and was
a lawn mowers dream and the heart of the system in my opinion
The flail mower rotor was designed with simplicity in mind where the rotor shell is 6 inches in diameter with welded ends with the shaft weldments. (I have to measure it again one of these days before snow falls).
Each knife mounting station was made from a piece of flat bar stock and it was fully welded to the flail mower rotor shell that was bent to allow the knive hanger to be slid in and out.
NOW for the knife hangers:
The knife hangers are were made from a piece of bar stock that also had a theaed end that held the knife hanger in place with a spring and two washers which allowed the easy removal of the knives and dethatching blade.
(The Mott Mowers were also designed to use a dethatching blade with or without the side slicers in place BUT the smaller flail mower rotor used weldments that required them to be secured with nuts and bolts)
I hope I have not bored anyone to tears.
/ Let's talk flail mowers #2,452
I think a Lawn Genie knife arrangement may have been an attempt around Mott's patents. Mott may have even sued them if I recall. I don't think they were designed for taller grass. Consider that the Mott Super Heavy Duty design is close to 50 years old and virtually unchanged. There's no better testament to their superb design. Everything on a Mott is the highest quality including the bearings. Like I mentioned previously, compare the deck thickness on a Mott to Ford, JD and several others and you'll see a big difference.
/ Let's talk flail mowers #2,453
For what its worth,
I am not disagreeing with you at all about flail mower build quality.
we used our first 36 inch lawn genie with the 8 horse Briggs & Stratton engine to
knock down 12-15 foot golden rod for my mother so she could jog in our old pasture
with the 36 inch cutting width finish flail mower. We used the 48 inch unit in the same
manner for both heavy brush and grass mowing. Mathews held patents for the design
of the lawn genie with its flail mounting system and the aerodynamic knives for seventeen
years until the patents lapsed.
My dad used his Ford Jubilee and a 7 foot JD25A finish flail to reclaim the same 12 acres of pasture
to keep it mowed he like a mowed pasture too.
/ Let's talk flail mowers #2,454
The build quality and ruggedness of my Ford 918H is pretty high... Is the Mott any heavier than mine? I'd be surprised
/ Let's talk flail mowers #2,455
A 74" Alamo Super Heavy Duty is 930lbs. and a 71" Ford 918H is 792lbs. An 88" Alamo is 1035lbs. and a 91" Ford 918H is 957lbs. A 96" Alamo is 1170lbs. Note the Alamo has a 10 gauge deck and looks more refined and streamlined (for lack of a better term). The 918H looks boxy and a little crude in comparison. The other thing to keep in mind is a new Alamo is probably over $5000. Not sure what the NH/Ford would cost in comparison.
/ Let's talk flail mowers #2,456
They are certainly very close in weight, thanks for pointing that out!
I heard somewhere that the 918H sold new for over $5k as well, but I don't know if that's accurate.
/ Let's talk flail mowers #2,457
I imagine any mower that heavy will be expensive. The Alamo is basically unchanged in over 40 years. If it works well why fix it. LoL
/ Let's talk flail mowers #2,458
Arc Weld-
Just out of curiosity ... what was the last production year for the Mott 72 flail?
/ Let's talk flail mowers #2,459
I'm not exactly sure when the heavy duty flails with the smaller rotor were discontinued. I would guess sometime in the 80's? My dad sold Mott till about 83. Some people seemed interested in my dads history so here's a little background. My dad had a heart attack and sold his 1/2 of the company to his partner in 1978 but stayed on as a straight commission salesman. I think it was late 82 or 83 when his former partner decided they didn't need my dad's services anymore even though he was straight commission. BIG mistake. They were the Jacobsen distributor and all the golf courses and parks departments knew my dad was the brains behind the whole business as he'd been in the industry since the 50's. He was well known across Canada as well having been the former president of the golf superintendents association. My dad had been appointed the Jacobsen distributor before starting his company and had Jacobsen's full support to start his own company. My dad just didn't have enough money to do it on his own. They also had the exclusive Ariens distributorship and my dad sales records for them. The commercial turf side got so busy they gave up the consumer lines of Jacobsen and the Ariens distributorship.
The company was so successful that they had to add another branch within about 2 years. My dad also set world wide sales records for Jacobsen having sold the most F20 9 gang self propelled mowers and likely the most HF15 7 gang hydraulic drive machines. The F20 was largest self propelled golf course mower ever made. A lot of sod farms started out in the 70's and purchased F20's and a lot of golf courses had 2 HF15's and they weren't cheap. My dad worked for a Ford tractor dealer that dabbled in turf equipment for a couple years and then got a call from the Toro distributer asking him if he consider going back to sell Toro. The Ford dealer was very impressed with my dad but fully understood his specialty was turf equipment. Interestingly enough my dad started out selling Toro and was the factory appointed Toro rep. He left to sell Jacobsen because he couldn't stand one of the people at the Toro distributor. My dad went back to sell Toro in 1985 and increased sales 110% the first year. Several of my dads customers told his former partner to not even bother to come around after what they did. His former partner sold the company to the BC distributer (my dad was in Alberta) a few years later and they eventually went bankrupt. If I recall it took about 10 years to go from a 75% market share with Jacobsen to basically running Jacobsen out of the province. A couple other places tried to sell Jacobsen to no avail. Jacobsen had top of the line equipment so that wasn't the problem. I asked my dad once about him being the Jacobsen factory appointed rep. and he said he could have made things really difficult for his former partner when he decided he didn't need him anymore but was more concerned with his health. His former partner must have known how good of friends my dad was with Mr. Mott because I answered the phone when he called to say that Mr. Mott had died crashing his plane on his private airstrip. That was really sad. At one point my dad was considering opening a company to just sell Mott flails. He said they were probably the best built product he ever sold.
/ Let's talk flail mowers #2,460
Arc weld, I'm curious about your claim of Mott being the first flail mower built? With Vrisimo currently celebrating 50 years in the flail mower business while talking about their owner (Mr. Vrisimo's) designing and development of flail mowers for orchard growers it raises question?? Just asking since Mott's existence seems to be shy of 50 years.
Also regarding your above statement and when shopping a couple years ago I found the Vrisimo mowers to be more substantial in build quality. Thicker shell and end plates, higher HP gearboxes, a single multi groove belt about 2-1/2 wide, larger diameter shafts/bearings and more overall weight running 980 pounds for a 74" mower. Also in regard to your information above I found Mott's current deck thickness on their super heavy duty flails are 10G top and 5/16 sides compared to Vrisimo at 3/16" top and 3/8" sides. I wouldn't say Mott mowers are unchanged unless they were 10G originally? I'm just sharing as this research is what caused me to opt for the Vrisimo mower.
2011 Dodge Charger (Police), VIN # 2B3CL3CG7BH526995 (A65563)
2011 Dodge Charger...
CHEVY DUALLY TRUCK BED (A65643)
CHEVY DUALLY TRUCK...
2014 UTILITY 53X102 DRY VAN TRAILER (A59914)
2014 UTILITY...
2003 PETERBILT 379 SLEEPER (A59914)
2003 PETERBILT 379...
2012 FREIGHTLINER M2 6X4 T/A ROLLOFF TRUCK (A66091)
2012 FREIGHTLINER...
Wagon Wheel Rocking Chair (A65583)
Wagon Wheel...
