First time welder type suggestions.
/ First time welder type suggestions. #21
Oh there is nothing like old iron! 1948 Lincoln SA-200 Short hood. :D
Show off !!:)
Keep that up and I'll have to send you my two for "spiffing up" :D
Terry
/ First time welder type suggestions. #23
Terry
I just did one for a friend of mine. 1963 Lincoln Red face.
/ First time welder type suggestions. #24
/ First time welder type suggestions. #26
Oh, you belong to Welding Web too.:thumbsup:
One of the newer, inexperienced (but good looking) members.
BTW. I'd recommend Welding Web to anyone remotely interested.
Terry
Thanks for all the help and suggestions. I've decided the everlast 140ST is going to do most of what I need. I'd also like to say the TBN forum is the best resource for info and support I've seen period!
Power arc 140ST on the way. Found one open or damage box for $229. Comes with everything as new. Will be putting the 240 vac outlet in after it arrives.
/ First time welder type suggestions. #30
What ever welder you choose is fine, but make sure if you are doing any welding on the tractor itself you disconnect the battery. Especially if has any electronics on it. Welding currents flowing through equipment with the battery hooked up can and will set up all kinds of strange current flows. From blowing out alternators and ECM's to freezing transmission shift rails in place. We get all kinds of strange no starts and no charge to steering stuck. First thing we look for is fresh welds.
Great advice! I hadn't thought of that. The 140ST said it would only generate 85 amps on 110. That seemed like a waste of the waders potential. I'll be be coming off the circuit the stove is on. Just have to make sure no ones baking biscuits.
I also got 2 lbs each of 1/16 and 3/32 rods. Not sure if I got the right sizes to start with?
/ First time welder type suggestions. #32
I don't think there are any welders that put out much more honest power from 110v.
1/16 might be a tad small. 3/32 should be fine and 1/8 a stretch with the 110 but fine for 220. I haven't used the exact same welder as my experience is with the Miller Maxstar running on 110.
/ First time welder type suggestions. #33
85-amps, you should be able to run 3/32" 7018, and 1/8" 6010.
What could I run on 240vac @140 amps? I may potentially have some thick stuff to weld such as plows, hitches etc.
/ First time welder type suggestions. #35
Oh you should be able to run 5/32" 6010, and maybe 5/32" 7018, especially if it comes out of the an oven. Here at home if I need anything bigger than 5/32" 7018, thats when I break out the wire feed.
/ First time welder type suggestions. #36
Gary you should order this book. There is more to welding than just running beads. Joint prep will make or break any welder.
Books
/ First time welder type suggestions. #37
And get yourself an auto darkening helmet. Everyone has their opinions on qualities.
Mine is : just don't buy the cheapest or the most expensive. $100 will get you a good one. Check for fit if possible.
I have two Optrel's that are junk now as I can't replace the batteries. My 'go to' hood is a cheap Tweco that came as a mail in rebate with one of their welders.
Terry
/ First time welder type suggestions. #38
Here is another excellent welding text that you can use to self teach. Welding Principles and Applications by Jeffus 500 Service Unavailable Error The new edition costs over $200 but the 2007 version can be had used for a little over $20 from Amazon. I've purchased a number of books and taken a couple of classes and the Jeffus book really stands out. It is written as a textbook with theory and practical exercises as well as numerous tips. Well worth $20.
Thanks. I'm in Dayton a lot. I may be able to just pick it up there
/ First time welder type suggestions. #40
Just remember that Amazon will deliver it for you for cheap money. Not sure how many bookstores even stock such a textbook used. Good luck.
2014 Nissan Murano Cross Cabriolet AWD SUV (A61574)
2014 Nissan Murano...
130 BBL VAC TRAILER (A63569)
130 BBL VAC...
Case IH 950 Planter (A63688)
Case IH 950...
2023 Kubota Z412KW-48 Commercial Zero Turn Mower (A63689)
2023 Kubota...
2020 Freightliner 114SD T/A VacCon VPD3611 Combination Sewer Jetter Vacuum Truck (A61573)
2020 Freightliner...
2019 FREIGHTLINER M2 106 4X2 S/A 26FT  BOX TRUCK (A59912)
2019 FREIGHTLINER...
