Lights
/ Lights #22
I used a pull type switch
One notch out is just the front All the way out is front and rear. It is rated for 30 amps so no relay was needed. I got it from NAPA .
I don't use the factory lights they are almost useless.
/ Lights
Update -- A couple of Cree lights are on their way to my house from China. (cheap too) I got two 18w lights first to see how bright they are. Depending on how bright they are, I'll get 2 more of them or the 27's or 36's. I'm expecting to put the 18's on the back and larger ones on the front. I'll share my findings when I test the 18's.
/ Lights #24
18's are definitely not as bright as the 27's. I like the 18's for applications you might get blasted with (like my side lights), and where you don't need the throw of a brighter light. With the 27's, for area lighting (flood), you get 3 lights output in two vs the 18w. Looking into a 27w LED at night is going to blind you.
/ Lights #25
The 27 watts I ordered came yesterday. I'll put them on this weekend and see how they look on the Kubota. I think I will ziptie them until deciding what to mount them with. I have to raise/lower the Rops to get the tractor under cover when done. I don't have a cab or top. May have to get some kind of mounting bracket for permanent function.
/ Lights #26
I'm going to try these and if they hold up, I'll get another for the rear. I had to unhook the finishing mower in the dark the other night to put on the boxblade to work on the driveway. I drove off without unhooking the pto shaft so I was dragging the tractor half over to the boxblade for hook up. I just happened to notice it when backing up. First time I've ever done that after many years of hook ups. I have a rear light on my old 8N so it is easier...but not the new Kubota yet. Hope to fix that soon!
/ Lights
Keep us in the loop gwstang. I'll do the same. Everybody loves photos.
2018 Bobcat S-570 (A63689)
2018 Bobcat S-570...
2014 Lincoln MKS Sedan (A61574)
2014 Lincoln MKS...
YANMAR VIO35-6A EXCAVATOR (A63276)
YANMAR VIO35-6A...
2017 CATERPILLAR 420F2 BACKHOE (A64279)
2017 CATERPILLAR...
2015 Ford Explorer AWD SUV (A61569)
2015 Ford Explorer...
2022 EZ-GO ELITE...
