Drill Bits - Need some help and advice
/ Drill Bits - Need some help and advice #61
Here is what i use to get me in the ballpark. mild steel 80sfm x 4 = 320 rpm for a 1 " drill. So just divide it from their. if 1" =320rpm then 1/2" = 640rpm and 1/4" = 1280rpm and so on. For Stainless steel i cut the speed by 1/2 and aluminum i go about 25% faster This gets me in the ballpark and i dont burn up my drill bits.
Those numbers are right, but as I mentioned a few pages ago, you gotta have a press with enough power. Bench tops dont. You will burn up 1" drill bits ALOT faster on a benchtop 3/4hp press vs a 3 or 5hp press where you can actually remove some chips.
Remember, heat is removed in the form of the chip. IF you aint removing sizable chips, you toast the bits.
So is it just as bad for a bit to go too slow? Meaning I am working mild metal and putting 1/4" holes at 300RPM. Seems to slow from what you guys are saying.
/ Drill Bits - Need some help and advice #64
One other thing. Standard drill points are 118 degrees nothing else. If it 135 degrees or something else it's not standard. Later.
True. Drills specifically made for stainless steel f ex have 135 degrees. Dormer A108 is one.
/Marcus
/ Drill Bits - Need some help and advice #65
Does drill bit RPM mean anything other than maximum speed for the bit and material?
I've never had any problem switching from a 1/2 inch bit at 500 RPM to a 1/8 inch bit at the same speed. I don't want to (and don't) rearrange belts every time I change bit size.
Bruce
/ Drill Bits - Need some help and advice #66
Going too slow is not an issue.
The general guides online are theoretical maximums. Slower dont hurt anything but productivity. And you can even drill faster if you have flood cooling.
The whole idea of the speeds are based on temperature. Gotta keep the bit cool. Removing an appropriate size chip removes heat from the bit and part. Thats why an undersized benchtop drill press is gonna burn up larger bits even if running at the recommended 80-100sfm. Because they lack the power to be able to cut a decent size chip. Going slower gives you more torque. So you can remove large chips at a slower rate as opposed to tiny chips really fast.
/ Drill Bits - Need some help and advice #67
For those interested in annular cutter tap sizes (Like Carl), I just came across this the other day -
https://www.evolutionpowertools.com/downloads/booklets/us/steelcatalog.pdf
If you scroll down to annular cutters (page 16), they have a separate page JUST for larger tap drill sizes.
Found out if you enter "evolution + the part# from the above" (without quotes) into Amazon's search box (for example, evolution CC17/32L you can cut through all the crappy search engine's attempts at help :rolleyes: and go straight to the 5/8"-11 x 2" depth tap size.
For those NOT familiar with annular cutters, these are NOT recommended unless you have either a mag drill, a milling machine, or a REALLY heavy duty drill press - they tend to break easily with any amount of side play... Steve
/ Drill Bits - Need some help and advice #68
/ Drill Bits - Need some help and advice #69
I dont know about the comment that you cant run big bits in a cheap drill press. I have a Crapsman floor model. I think it will go down to 240rpms. I regularly run the cheap Northerntool 1 inch drill bits in it and I havent burnt one up yet. I also run up to 4in hole saws in the same drill and cut thru 1in thick steel, without the bit getting hot. One thing I am convinced of because I have proved it for myself. Using just any kind of oil will burn up a drill bit. WD40, PB blaster, never on a drill bit, or a bandsaw. I use the Lennox brand cutting oil and I can tell a difference as soon as the oil is applied. The bits, or saw will cut faster and stay cooler than any other oil I have tried. The only thing that I think might be better is the LPS1 spray oil I find at Granger. I can have a bit just throwing a few chips and squirt it with the Lennox or LPS1 and it will start throwing curls. I have tried water, transmission fluid, 3M machine oil, motor oil and for me, nothing beats using the Lennox or LPS1 when it comes to cutting and drilling. and it dont take but a drop to get the job done. If you can take a 2 1/2in hole saw and cut thru 1in of steel and as soon as you get thru the metal take your hand and grab hold of the bit and not get burnt, and the only difference is in the oil you choose, then I say stick to that oil.
Now as to why I feel so strongly on this subject is because I was sawing some 2 1/2 in shaft on the bandsaw, while drilling some 2 1/2 in holes in 1 in steel on the drill press. I was spraying PB blaster on the saw and using the cutting oil on the drill. Well while going back and forth between saw and drill, I managed to get the oils mixed up and used the Lennox oil on the band saw and it immediantly started cutting faster thur the steel. I thought huh, and sprayed the hole saw with the pb blaster and it almost immediantly started heating up and stopped cutting. Put the pbblaster down and put a drop of the lennox oil on the hole saw and it went back to cutting and actually cooled off. Thats my story and I'm sticking to it.
I also want to add that I just got thru drilling a 1/4 hole thru 12 inchs of round stock and then followed it up with the cheap Northern tool 1in drill bit, using the same Lennox oil on my lathe, and when I got done I could lay my hand on the round stock. My lathe doesnt have any coolant pumps or fancy coolers.
/ Drill Bits - Need some help and advice #70
The best I have found, been using it for over 20 years is Rocol RTD. Especially the compound because it melts slowly and stays in place for a long time. We used lots of it when I worked with building dairy machines all in in stainless steel.
https://www.rocol.com/products/search/type:brand/brand:rtd
/Marcus
/ Drill Bits - Need some help and advice #71
Mudd, if the "big bit" comment was aimed at me you should re-read - I specifically was referring to ANNULAR cutters, not big twist drills - I also have an inexpensive Taiwanese drill press and have drilled hundreds of holes (up to 1")using the cheapo HF "silver & Deming" bits as well as up to 3" holes using hole saws - they seem to hold up pretty well even when I just use compressed air cooling... Steve
/ Drill Bits - Need some help and advice #72
Annular cutters and carbide (or carbide-tipped) drills need a rigid (stable) spindle. Hand drilling with either is a recipe for chipped corners and loss of cutting action/chip formation. 'Short molecular chain' animal fats lube chips in the flutes, but also allow the cutting edge to bite in. Lube oils (long chain) work in the flutes but deter the cutting edge from biting in. Windex, water beat lube oils as a drilling aid.
btw, I googled 'lard oil' and discovered a cooking trend of using 'good old-fashioned lard' like Grandma always did. Lucked into a few how-to's to render and bottle lard oil for the mills & lathes. (filtered bacon grease works great, smells like breakfast :licking:)
Thread tapping is where you really see what works best and what falls short. ;)
/ Drill Bits - Need some help and advice #73
"filtered bacon grease works great" - bet that's where the expression "hogging out a hole" comes from :laughing:
TOG, seriously though - good info, that's the gist of what I found researching these cutters - so far I've only used a couple different sizes and only on my new mill. amazing how quick and clean a large hole can happen :thumbsup: ...Steve
/ Drill Bits - Need some help and advice #74
Yup.
Lubricating oils are intended to prevent metal to metal wear, just what you don't want when you're trying to cut metal, with metal.
/ Drill Bits - Need some help and advice #75
For general cutting and drilling I use black cutting fluid from Enco, same thing as plumbers use to cut threads. For a bit better finish sometimes I use lard oil that I got from McMaster Carr. For thread cutting I use TapMagic. For aluminum, WD40. And now I am gonna have to get a bottle of Windex and give that a try too.
/ Drill Bits - Need some help and advice #76
Wasnt directed at anybody in particular. I just saw it several times, and I dont think it was just in this thread, that the small machines wont drill big holes because of speed and HP. Admittedly, its hard to beat speed reduction and hp when drilling big holes, but a quality oil will help if you dont have the big machines. I dont subscribe to the theory that water or transmission fluid, WD40 etc, works better than the right oil because I have proven it to myself that that isnt true. And I had a old time machinist tell me many years ago that water was best, but I lost faith in that advice as soon as I found out what the correct oil would do.
And I believe the HF SD drill bits are made by the same chinese company the Northern tools are made by. Box and packaging looks the same anyways. Funny thing is, you can buy the 8 bit set for about the same price of just buying the single 1in drill. For what I do, those cheap bits get the job done.
/ Drill Bits - Need some help and advice #77
Water and water soluble coolants work well, but I don't use them on my mill or drill press because of the rust factor. Pretty much use the same as downsizingnow48. Terry
/ Drill Bits - Need some help and advice #78
...And I had a old time machinist tell me many years ago that water was best, but I lost faith in that advice as soon as I found out what the correct oil would
As a COOLANT only, water is better. But as a CUTTING fluid, oils made for cutting are much better.
/ Drill Bits - Need some help and advice #79
I tried windex, well it was the cheaper blue cleaner off brand, didnt like it. Just saying.
Have been doing a little reading about Lard. I had never heard of using animal fat before.
Dont know that I will ever try it because all my cooking grease turns into gravy and gets poured over my biscuits. I do wonder how much salt might be in the grease and what kind of effect that would have on a piece of machinery.
Aproximately 72' of Steel Catwalk (A62679)
Aproximately 72'...
2019 Freightliner 122SD (A62679)
2019 Freightliner...
Lonestar Panel 24ft. Free Standing Panel with Feed Bunk (A65640)
Lonestar Panel...
2008 DRAGON  130BBL VACUUM TRAILER (A65643)
2008 DRAGON...
(2) 30 Yard Roll Off Dumpsters (A65579)
(2) 30 Yard Roll...
S/A Utility Trailer (A64557)
S/A Utility...
