Garage door opener.
/ Garage door opener. #1
Walkin Horse
Chesterfield Va
Shibuara Ford New Holland 555D NH Workmaster 55
I have an old 16' garage door opener. I closed my garage on the house and made a pool room out of it.
I saved the opener. Has anybody repurposed one for anything. I'm open to ideas. I hate to throw it away but I won't use it for a garage.
Sent from my iPhone using TractorByNet
/ Garage door opener. #2
I haven't, but I would imagine you could make an electric gate opening for a roly gate.
/ Garage door opener. #3
I have an extra opener also. Looking for ideas. One I have is using it for a lightweight lift for my attic.
Dave
/ Garage door opener. #4
push button stall doors
/ Garage door opener. #5
Do you have any out buildings you could put a roll-up door on?
/ Garage door opener. #6
Hello,
I have seen one used as a dumbwaiter. You set it on end and build a platform around the carrier......then you set your groceries on the platform, hit the raise button and your groceries go to the second floor. You need to have two closets that are right above each other for this to be an easy job. Otherwise you need to fabricate the tunnel (like an elevator shaft).
MFWD
/ Garage door opener. #7
How about:
  • A shooting range target retriever?
  • Move a 3-D archery target for in-motion shooting?
  • A gate opener?
  • Roof/window opener for a greenhouse?
  • A light-duty hoist to raise/lower a storage shelf in the garage?
  • Raise and lower a projector screen in the media room?
  • Create moving holiday decorations (Halloween witch on a broom?)
  • Flagpole / antenna raiser?
  • Automatic attic steps?
/ Garage door opener. #8
I know a guy that built a 3 sided greenhouse onto the south side of his garage. He suspended a 16x8 garage door over the glass panels of the roof and rigged a garage door opener to open or close it when bad weather was coming.
/ Garage door opener. #9
A place I was at the other day had a garage door opener for a power air hose reel.
/ Garage door opener. #10
Some openers turn a long screw. Others use a chain and sprocket.
Which kinds are some of these uses mentioned?
Bruce
/ Garage door opener. #11
Chain drive can crusher.
Bruce
/ Garage door opener. #12
Ping pong table dropper
Bruce
/ Garage door opener. #13
Door barricade
Bruce
/ Garage door opener. #14
Car door opener
Bruce
/ Garage door opener. #15
Pig Spit rotiserrie
Bruce
/ Garage door opener. #16
Dumbwaiter
Bruce
/ Garage door opener. #17
Barn door opener
Bruce
2012 Peterbilt 337 G and H 8000 Container Handler Truck (A64194)
2012 Peterbilt 337...
2002 FREIGHTLINER COLUMBIA DAY CAB (A62613)
2002 FREIGHTLINER...
2004 Rogers Detach Lowboy, 28' Well, Tandem Axel (A62679)
2004 Rogers Detach...
2020 CATERPILLAR 262D3 SKID STEER (A64279)
2020 CATERPILLAR...
2012 International 4300 Reefer Truck (A63689)
2012 International...
2018 CATERPILLAR 326FL EXCAVATOR (A64279)
2018 CATERPILLAR...
