New Railroad ties used for structural support.
/ New Railroad ties used for structural support. #21
I had been given about a dozen old power poles when the local coop replaced lots when the added fiber cable about 5 years ago. Poles were 20 to 30 years old and you could still smell it when you got within a few feet of them. Get real beams made with zero preservatives for indoor use.
/ New Railroad ties used for structural support. #22
I would imagine the smoke would be horrendous in the event of a fire also.
/ New Railroad ties used for structural support. #23
Crickets from the OP... Besides NO, to the RR tie issue, I'll add that most all exterior walls are 2x6's.
/ New Railroad ties used for structural support. #24
Yeah, he hasn't been back to this site since making that first post. I don't know what the percentages are, but in some parts of the country, 2x4 exterior walls are quite common. It's fine structurally. Only reason to go 2x6 is insulation value.
/ New Railroad ties used for structural support. #25
If he is doing stud walls instead of post construction and those walls will be supporting free span trusses 2 foot on center - 2x6 walls on 12' center is not out of line especially since he mentioned 10' walls. Thats a bit of weight
/ New Railroad ties used for structural support. #26
It's very unusual to see a building with studs 12" OC, with any stud size. 10' 2x4 walls with studs spaced 16" OC are sufficient to support 33' trusses. Been there, done that (I do this for a living). Personally, I would do a post frame for such a building but that's not for structural reasons as much as it is for insulation and air sealing.
/ New Railroad ties used for structural support. #27
Something like this was brought up before. I'm aware of the toxic chemicals used to preserve the wood. Im 52 divorced and my children are grown. The small amount of money I made when we sold are family home I bought a few acres and I'm going to build a small bardominiom for myself. 33' x 55'. About a 1/3 will be a garage the rest living space. Going the traditional 16 on center 2x4 wall but I want to go with 10 footer and have an open ceiling for a lift that will be about 3/4 of the living space. Do you think I could incorporate The railroad ties into the interior of
the structure to add strength and mainly for looks. I a fairly decent artist and I'm confident I can either paint, stain, even do some airbrushing to make them look like old barn beams.
any thoughts.
Most railroad ties are 7"x9'. If me I would use 10 foot 6"x8". I don't think you would be able to paint over or stain the treated railroad ties. I also don't know what you plan on lifting in the living room with a lift but most lifts require a 6-8 " cement base for the lift. If you are preparing for the future when someone might need a lift to get them out of bed you will need to put beams in the ceiling to attach the lifting mechanism to.
/ New Railroad ties used for structural support. #28
I've done 12" on center and had the inspector require it on a 12 foot tall wall. You might get away with less. I went the extra mile on mine and know its solid
/ New Railroad ties used for structural support. #29
Depends where you are and the inspector you're dealing with I suppose. 2x4, 16" OC exterior walls meet code here, and that's with snow loads in excess of 70 lbs/sf. I've framed buildings in Ohio, Virginia, Missouri and Idaho and I can't recall ever seeing studs placed 12" OC.
/ New Railroad ties used for structural support. #30
For any sort of resale, putting in RR ties interior, especially structural, would be a deal killer for me.
We replaced my mates 1971 plank floor last week, for double OSB with insulation.
As soon as you take the planks off, you could smell the tar they painted the beams with, 50 years ago.
/ New Railroad ties used for structural support. #31
It would not be very long before you would be disappointed and wish you
never wanted to use rr ties. You can make you own trusses or have them
fabricated. You have any pictures of what you intend to build? Pictures are worth a thousand words
willy
/ New Railroad ties used for structural support. #32
The OP hasn't been back since the day he/she started this thread.
/ New Railroad ties used for structural support. #34
Every day I am reminded...they walk amongst us...
This doesn't even pass the common sense test.
/ New Railroad ties used for structural support. #35
Its okay to me, as a reader, if the OP disappears. The Thread still has value. :) I would never use RR ties for anything on my property, aside from making steps on a trail distant from the house.
/ New Railroad ties used for structural support. #36
Definitely could be useful to dissuade someone else thinking about it... it may be extremely rare but people do search threads sometimes before asking questions ;)
/ New Railroad ties used for structural support. #37
Agreed. It just may be a waste of time to ask the OP questions about his/her situation.
