Screw drive garden tractor
   / Screw drive garden tractor #61
Oh man, bummer is right! Hope your plan for beefing it up works...
i was looking at these....do you think the 32hp is strong enough? i just worry that the torque at the axle shaft in 1st gear is quite high??? or am i crazy? i would just hate to blow one of these up next....
   / Screw drive garden tractor #63
I don't know, I build things using the TLAR School of Engineering method. (That Looks About Right). :D
I think that means 32hp on the input shaft. I guess you could call them and ask.
   / Screw drive garden tractor #64
TLAR, lol...I like that.:p
   / Screw drive garden tractor #65
HP = RPM * torque
Torque is what twists & breaks things, so worry about it more than HP. They made the bigger PTO shafts 1000 RPM so they could keep the shaft smaller & lighter while transmitting more HP compared to running them at 540 RPM.
   / Screw drive garden tractor #66
Can you make it a belt drive to your jackshafts? Mating Hydraulic vane/gear motors to the screws directly with a pump on the engine? Rotate your drive system so there are no 90 degree torque transfers? I realize it would involve re-engineering the entire drive. I don't think these are meant to screw across concrete, they are meant to be used in slippery conditions.
I was considering rotating the drivetrain, but I think I may go with those gear boxes instead...hydraulic just seems to expensive
   / Screw drive garden tractor #68
The pontoon cylinders need to be larger diameter and you need more, shallower screw vanes.
yeah I've seen that one, i don't think there is a video of the top left machine sadly....
   / Screw drive garden tractor #72
Any news? I was really enjoying this project, hope it's still alive. Once you get it figured out, I'll take a utility version for the cottage please :D
   / Screw drive garden tractor #73
I agree, I sure hope it's still a work in progress! :thumbsup:
don't worry, she's still a work in progress.... I'm just searching for some cheep 90' gearboxes. the new ones online are 150each, plus 180 shipping to Canada.....which is a lot for me (and my wife mainly :p) trying to find some used ones, not doing so well.....
   / Screw drive garden tractor #75
I was thinking about your project yesterday when I was a GBS bearings picking up stuff for my own project. They had exactly what you're looking for sitting on the counter. I didn't ask about price and I don't know how much shipping would be, but at least there wouldn't be any duties or nasty broker fees. Worth calling them to find out, they had at least 3 sizes on display including a large cut away model that looked like it could have handled a couple hundred hp.
mainen
i'll shoot them an e-mail, thanks!
mainen
   / Screw drive garden tractor #78
Great idea. :thumbsup:
   / Screw drive garden tractor #79
Yes!! That's a pretty clever solution - sure hope it works! :drink:
2021 CATERPILLAR 926M WHEEL LOADER (A60429)
2021 CATERPILLAR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2018 PINSA 130BBL VACUUM TRAILER (A58214)
2018 PINSA 130BBL...
Rockport Mobile Command Center (A59230)
Rockport Mobile...
1604 (A57192)
1604 (A57192)
Unused 2025 CFG Industrial QK16R Mini Excavator (A59228)
Unused 2025 CFG...
