Grease Guns
/ Grease Guns #41
Canadian Tire has a 12volt one on sale this week . I don't know if it is a good one or not .
/ Grease Guns #43
I have a bunch of Dewalt Cordless tools, but they are all NiCad. I wanted to try Milwaukee brand tools and also switch to Lithium batteries. To keep the cost down, I bough a refurbished gun through CPO outlets. I have purchased a couple other tools from them, and been very pleased.Paid about $125 and liked it so much, a week later I bought an impact driver to go with it. If you do much greasing, and you know you should, battery operated is so much easier and cleaner. One hand still has to get greasy from the Zerk, but the pump hand stays clean. Is applies good pressure, and is easy to load and doesn't seem to get airlockks like the hand pump did. Plus no hand cramping . I'm wishing I had got this thing 10 years ago.
Yeah, my Dewalt starts a new tube every time with no bleeding. Just pull the trigger and wait a few seconds and it'll pump out all the air.
/ Grease Guns #44
I had a cheap grease gun, it air locked all the time. So, I bought a nice 50 dollar one a few years back. It air locked just as bad as the 16 dollar one! I have tried everything, including taking the pressure off when not in use. Bottom line if it sits for a couple of months without use it air locks! I have been thinking of trying one of the pneumatic ones or electric?
/ Grease Guns #45
Interesting, I have 4, I have never had this problem with any of them..
/ Grease Guns #46
I'm like James. I don't understand the constant air lock problem. I'm suspecting the grease more than the gun. I bought some grease at the local farm supply store several years ago, can't remember the brand or type. In warm conditions the guns would drip oil out the bottom of them. I can only imagine how ineffective that grease was as a lubricant on anything that created the slightest bit of heat. But I still don't recall them air locking.
/ Grease Guns #47
Loosen the jaws of the nozzle. Perhaps putting it on a little loose and applying pressure to keep it tight.
all the grease guns I have you can adjust the end by turning it so it isn't to hard to get off some Zerks.
Yep. Sometimes with use they'll get out of adjustment but a quick turn with your fingers and everything is good again.
I bought one of the lock n lube ends. I pumped a couple tubes of grease thru it and took it off. Too bulky. Too slow. A properly adjusted normal end works better for me. I am a grease freak and use a LOT of grease in a year.
And for the neophytes what they are writing about is the 2 section end of the tip which often seems to be screwed together by an 800 pound gorilla with a 4 foot wrench. I've had several that I've had to use my biggest vice grips on them to loosen them the first time.
Try hanging it where it's warm.
/ Grease Guns #48
Great info on the DeWalt. Electric sounds like adding a 3rd hand! DeWalt sure has made a difference whether I pick up the screwgun or the hammer. My eqpt will get greased more often - I'm gonna order one ASAP.
I have all 18v tools, they are NiCad. Is there an adapter to put 20v Li batteries on an 18v tool? Or some other 18v battery? Sure seems like there would be a market for tool battery adapters to mix & match brands. Gotta wonder if the mfrs are preventing such devices somehow - is there a DeWalt lobbyist in DC? :D Almost makes me want to buy a 3D printer!
+1 on the lock-n-lube coupling, that made a huge difference in ease and minimizing the mess (and the waste).
/ Grease Guns #49
There are good directions on how to load a grease gun to eliminate airlocks on the net. I searched a while back and printed out the directions for reference. I have both a lever and pistol grip gun. I use the lock n lube tip most often on a flex hose lever action TSC gun. It works well. I load by removing the head unit, inserting the cartridge of grease with the plunger locked in full out position. Then I screw the head unit on, BUT don't tighten it tight, release the plunger to push out any air, then after grease starts to exit the threaded section of the gun's threads, I tighten the head on tight.
I use good to high end grease from wherever, mostly TSC, and hang the gun upside down on the overhead door jam extension. I clean each zerk before attaching the Lock n lube end, then put the gun somewhere where I can push down toward the gun with both hands on the lever arm, for difficult to grease zerks.
Since using the Lock n lube end, I'd say there are no zerks that will not submit to my superior intelligence.:D
Grease guns are mostly devoid of instructions, and I did fight with mine until I figured out that the nozzle tip would release from the shrouded zerks, and other difficult to disconnect from zerks by adjusting the 3-4 jaw tip pieces, by undoing the nozzle end and adjusting the jaws so they will actually release.
My suggestion is to write down or print out what works well for you and post it, as I did near the grease gun hanger for easy reference, especially if you use your gun infrequently.
Grease guns in general are a PITA, but keeping them clean, and the OP clean is easier with paper towel rags and neoprene disposable gloves and the Lock n lube end, IMHO.
Here's a very through video of how to load, purge air, etc.
https://www.youtube.com/watch?v=q4FeaYOZGoo
/ Grease Guns #50
I actually like the 18v NiCad, you can take them apart and rebuild them, haven't because can find cost effect, Dewalts 18v bare tools were cheap, looks like getting rid of them and going to 20v?, had all dewalt 18v impacks, saw the 18v grease gun as bare tool, same issues with hand grease gun, should have gone too electric grease gun long time ago. I actually buy my tools based on the availability and the cost of the battery. I don't know how many times I have thrown out a perfectly good tool because the replacement batteries cost too much. Now we have gone to buying the tool around the battery and buy a whole bunch of replacement batteries. Looks Dewalts 18v bare tools are cheap right now.
2018 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A60352)
2018 Chevrolet...
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
Bush Hog 72in Rotary Brush Cutter Tractor Attachment (A55852)
Bush Hog 72in...
2020 DRAGON ESP...
2006 FORD F-450 XLT SUPER DUTY SERVICE TRUCK (A62130)
2006 FORD F-450...
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A56857)
2020 Caterpillar...
