new member with yanmar problems
/ new member with yanmar problems #41
I installed a lower radiator hose heater on the tractor and if i plug it in for a few before i need it it fires right up like its a hot summer day out, i guess it was just to cold outside for it without some heat.
I figured the cold was your tractor's only problem..Cold is the enemy of a diesel
New problem now guys i had the tractor running the other day just putting around in the yard and the temperature light came on . How and were do i install a temperature gauge so i can make sure this thing is really getting hot and its not just a bad light sensor
/ new member with yanmar problems #43
/ new member with yanmar problems #44
We've been to this topic before. It's common for a new Yanmar owner to wonder if the cooling system is working properly. Sometimes overheating is caused by a bad head gasket or cracked head. Looking into the radiator cap and seeing bubbles would indicate this. The more common cause is the radiator is plugged with mowing chaff (exterior) or corrosion (internal). Replacing the radiator is an expected maintenance item after 30 years, you may have reached this point if cleaning it won't remedy overheating.
In my opinion money spent bringing the tractor back to Yanmar's original specs is much more effective than adding features that it doesn't need when it is running properly. Yanmar knew what they were doing when they designed these, they got it right way back then. It should be capable of running at full throttle / full hp output for many hours - running a ditch pump or generator etc, and never overheat. Spend the money to bring it back within spec and it won't overheat.
This $12 non-contact thermometer from HF is all you need to diagnose if the cooling system is running within spec or not.
/ new member with yanmar problems #45
sure your cooling mixture is correct ?
2003 CASE 70XT SKID STEER (A65053)
2003 CASE 70XT...
Landhonor HPF-11-3000G, 48" Heavy Duty Forks (A62679)
Landhonor...
2017 Lincoln MKC Multipurpose Vehicle (MPV), VIN # 5LMCJ2C95HUL50284 (A65563)
2017 Lincoln MKC...
Gasoline Concrete Mixer 8.0 Honda (A62679)
Gasoline Concrete...
BUSH HOG 1815 - 15' BATWING ROTARY MOWER (A64277)
BUSH HOG 1815 -...
213130 (A64276)
213130 (A64276)
