Jump Pack for Diesels
/ Jump Pack for Diesels #21
I've had the need for a jump pack many times before. I stopped at a local diesel shop and asked what they used on the rigs they service.
This is the model they recommended:Amazon.com: Jump-N-Carry JNC950 2000 Peak Amp 12V Jump Starter: Automotive
I was going to say the Magic Word of jump packs: Clore.
I have a Clore JNC660 and it would do the job for you. They are routinely used to start diesel trucks. It's 18 lbs vs 34 and $135 versus double that.
I keep it in the [heated to 50 F] house versus the garage. They will work when cold but they work a lot better warm. I also put in my calender to recharge it every month, though it usually doesn't need it.
/ Jump Pack for Diesels #22
I have had little luck finding clamps that pass that much voltage.
Wow that was quick. I'll be standing by for a review once you get to use it
It sure was, I ordered it from Amazon and had free 2 day shipping, I was quite surprised that it showed up a day early.
But I guess it makes up for the xmas order of a archery peep site that I ordered that ended up taking 2 weeks to ship from NY.
I'll be sure to review it once it get some use.
Matt
/ Jump Pack for Diesels #25
You can jump start directly from the Honda and Yamaha inverter generators. You have to buy the Honda cable, the Yamaha comes with it.
/ Jump Pack for Diesels #26
Something isn't working correctly if you have to keep cranking a diesel. All diesels I've ever owned start instantly after about 1/2 turn of the crankshaft, even after sitting for 9 months. This is IF you let the glow plugs work the proper amount of time. New type glow plugs need about 6 seconds in pre chamber engines and about 2 seconds in direct injection engines. Older glow plugs needed 30 seconds to a minute and a half to work (at -20 F).
Glow it the proper amount of time, and you won't need to crank it but about 1/2 turn.
Ralph
/ Jump Pack for Diesels #27
I got the same (JNC660) for my B.D. Mine said to charge every 90 days. Clore even has an email sign up for charge reminders. I charged it and put it in the truck, no need to use yet.
/ Jump Pack for Diesels #29
Jumping to boost start a diesel tractor from a portable inverter generator? Not likely as the current is limited to 10amps iirc.
25026SFL (A61569)
25026SFL (A61569)
2017 Ford Fusion Hybrid Sedan (A61574)
2017 Ford Fusion...
2001 Ford F-150 4x4 Pickup Truck (A59230)
2001 Ford F-150...
2018 Chevrolet Equinox SUV (A61574)
2018 Chevrolet...
2015 Ford Explorer AWD SUV (A61574)
2015 Ford Explorer...
2025 IREAS Grid-Shaped Rock Bucket Mini Excavator Attachment (A61572)
2025 IREAS...
