Front-End Loader CT 235 FEL quit working
   / CT 235 FEL quit working #1
a4jock
My CT 235 has <200 hrs. on it, and has been maintained religiously here in sunny Tucson, AZ.
Today I was removing a brick wall and footings. The footings were really STOUT. I was using the FEL to lift, drag, pry, etc the footings. Things were going smashingly when the FEL decided not to function. NO up/down, but the bucket will tilt up/down, scrapper will raise/lower, and every other function works. No burst lines, Hyd fluid is full and no leaks noted anywhere.
I'm wondering if the heavy duty work out I was giving the machine tweaked a valve or ram.
Ideas?
   / CT 235 FEL quit working #2
Could be a blown seal in one of the loader rams. you could switch lines with the bucket to see of it's the ram or not?
   / CT 235 FEL quit working #3
I was thinking that maybe you knocked one of the loader quick disconnects loose.
   / CT 235 FEL quit working #5
Awesome I'm glad it was an easy fix thanks for posting your results.
   / CT 235 FEL quit working #7
Thank you didn't catch that. I hope that that is all it is still
   / CT 235 FEL quit working #8
I had a similar issue loosing curl on my CT 235. It was a bad quick connect coupler (male end). Swap the hoses around to check as mentioned above. Easy fix.
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2015 Freightliner Bucket Truck (A52748)
2015 Freightliner...
LayMor Sweepmaster 300 8HC (A55314)
LayMor Sweepmaster...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A55315)
2003 International...
Hustler super Z zero turn (A56859)
Hustler super Z...
2017 MOROOKA MST300VD CRAWLER DUMPER (A52707)
2017 MOROOKA...
