Front-End Loader CT 235 FEL quit working
   / CT 235 FEL quit working #1
a4jock
My CT 235 has <200 hrs. on it, and has been maintained religiously here in sunny Tucson, AZ.
Today I was removing a brick wall and footings. The footings were really STOUT. I was using the FEL to lift, drag, pry, etc the footings. Things were going smashingly when the FEL decided not to function. NO up/down, but the bucket will tilt up/down, scrapper will raise/lower, and every other function works. No burst lines, Hyd fluid is full and no leaks noted anywhere.
I'm wondering if the heavy duty work out I was giving the machine tweaked a valve or ram.
Ideas?
   / CT 235 FEL quit working #2
Could be a blown seal in one of the loader rams. you could switch lines with the bucket to see of it's the ram or not?
   / CT 235 FEL quit working #3
I was thinking that maybe you knocked one of the loader quick disconnects loose.
   / CT 235 FEL quit working #5
Awesome I'm glad it was an easy fix thanks for posting your results.
   / CT 235 FEL quit working #7
Thank you didn't catch that. I hope that that is all it is still
   / CT 235 FEL quit working #8
I had a similar issue loosing curl on my CT 235. It was a bad quick connect coupler (male end). Swap the hoses around to check as mentioned above. Easy fix.
2011 GMC Acadia SLE SUV (A53424)
2011 GMC Acadia...
2018 HONDA RECON 250 4-WHEELER (A51247)
2018 HONDA RECON...
2015 Ford F550 Service Truck (A52377)
2015 Ford F550...
2005 IC Corporation PB105 School Bus (A54814)
2005 IC...
2018 John Deere 470G LC Hydraulic Excavator (A53421)
2018 John Deere...
16ft T/A Flatbed Trailer (A55758)
16ft T/A Flatbed...
