Front-End Loader CT 235 FEL quit working
   / CT 235 FEL quit working #1
a4jock
My CT 235 has <200 hrs. on it, and has been maintained religiously here in sunny Tucson, AZ.
Today I was removing a brick wall and footings. The footings were really STOUT. I was using the FEL to lift, drag, pry, etc the footings. Things were going smashingly when the FEL decided not to function. NO up/down, but the bucket will tilt up/down, scrapper will raise/lower, and every other function works. No burst lines, Hyd fluid is full and no leaks noted anywhere.
I'm wondering if the heavy duty work out I was giving the machine tweaked a valve or ram.
Ideas?
   / CT 235 FEL quit working #2
Could be a blown seal in one of the loader rams. you could switch lines with the bucket to see of it's the ram or not?
   / CT 235 FEL quit working #3
I was thinking that maybe you knocked one of the loader quick disconnects loose.
   / CT 235 FEL quit working #5
Awesome I'm glad it was an easy fix thanks for posting your results.
   / CT 235 FEL quit working #7
Thank you didn't catch that. I hope that that is all it is still
   / CT 235 FEL quit working #8
I had a similar issue loosing curl on my CT 235. It was a bad quick connect coupler (male end). Swap the hoses around to check as mentioned above. Easy fix.
Greenworks Commercial 82V CZ60R Zero-Turn Mower- BRAND NEW, NEVER USED (A57024)
Greenworks...
2018 Dodge Grand Caravan SE Van (A55853)
2018 Dodge Grand...
LATE MODEL JOHN DEERE EQUIPMENT AUCTION (A53084)
LATE MODEL JOHN...
JOHN DEERE 26G EXCAVATOR (A52707)
JOHN DEERE 26G...
(2) PALLETS OF TRAILER JACKS & MISC TRAILER PARTS (A54757)
(2) PALLETS OF...
2012 Ford F-250 Pickup Truck (A55852)
2012 Ford F-250...
