Which 3pt log skidding winch?
   / Which 3pt log skidding winch? #11
Honestly there haven't been many situations when I wanted to pull from the seat. I'm happy to get off the tractor, but that's just me. Whichever model you get, you'll wonder how you lived without it. I know I sure do.
I meant after you've winched the logs to the winch and are driving, it's nice to have the cage there. Which brings up a question: Do you, or most people, then hook the chokers onto the winch, or leave them connected to the cable when you drag the logs? Or both, to double the number of logs ( providing you have enough chokers)?
   / Which 3pt log skidding winch? #12
I do have enough chokers, but it depends on the size of the logs. If they are small I hook them to the winch and go get more so some are on the winch some on the cable. If they are medium sized I hook two or three to the winch and leave one on the cable, usually to the lower block if I can. Large ones I try to hook to the winch if possible. If I'm dragging big stuff around, I'd rather it not pull my cable in under the other layers. Really, I guess it's different every time. I can see how the cage is a nice safety feature, though.
   / Which 3pt log skidding winch? #13
If you're transporting logs attached to the winch cable, as I mostly do, it's probably best to use the lower pulley and not the upper one. If you hit a snag while moving, having the cable in the high position puts more leverage on the tractor, possibly enough for an upset on slopes and turns and definitely putting a lot of strain on the 3 point toplink. Not much of a worry if you're towing on smooth, open ground, but in the woods, etc., it's something to think about.
   / Which 3pt log skidding winch? #14
I am the proud owner of Gordon's old JL601 (Farmi). I had it for about a year or so and a bud asked me to help pull a huge Deer front end loader out of the mud. Everything was going fine until the input shaft bearing race let go.. WOO!
I don't know how old the winch was, but I was clearly abusing it!. Anyway, I pulled apart the following afternoon, got the make and serial numbers off ALL the bearings, cross referenced them on the internet to Timken and a few days later put the big lug back together again. I have put up about 150 cord of with since I have owned the winch, all felled on my property. It is reliable, rugged, and ugly. I love the big brute!
I do chain up the stubes rather than skid them attached to the cable. I don't like the logs flopping around when I am skiding them and chaining them to the winch frame solves that issue.Farmi says the lower block is to be used for skidding when doing so on the cable. I find I use the lower block when winching a particularly heavy stub as I believe it reduces the stress on the top link, putting more load into the dozer blade down force.
   / Which 3pt log skidding winch? #15
I don't think it's possible to buy a bad logging winch because it seems they are all good. Brand preference is most likely local availability.
Up here, I see mostly Fransgard.
Anybody have a Tajfun? A guy is selling them near me and I might go check them out.
   / Which 3pt log skidding winch? #16
Forestry winches | Les distributions Payeur
This is a Canadian company, they build several models both hydraulic and mechanical.
Seeing where the CDN dollar is right now, $.80, it may be very attractive for a US customer to buy.
I have a TR65H model, hydraulic, with a wireless remote and it is a great unit, rugged built ,Canadian made.
They have a wide selection of forestry equipment.
   / Which 3pt log skidding winch? #17
Got a Tajfun EGV-35A and been very happy with it. Has 200' of 3/8'' cable which is great for snaking logs from hillside so tractor stays on level ground.
   / Which 3pt log skidding winch? #18
I have a Wallenstein FX65 coupled to my MF 4608.
Not a log I couldn't pull...very good machine, well build and very easy to operate
I would highly recommend it...and as others have said, once you'll have one, you'll wonder how you ever did without.
   / Which 3pt log skidding winch? #19
When I was (kinda) researching them. The Tajfun impressed me. If you have 2 different dealers with 2 different brands, I'd shop price 1st. then dealer consideration 2nd. Farmi & Wallenstein (I think) are similar enough to toss a coin although Farmi has been at it for a long time. The reason I put the dealer after the price, is that unless you really get a "lemon" or absolutely abuse it, I doubt you'll need him for years after the sale.
   / Which 3pt log skidding winch? #20
I bought an Igland 3601 about 10 years ago from a dealer in Maryland. Been a very handy piece of equipment. Has enough "umph" that it will either pull the log to the tractor, or the tractor to the log. :D
ry%3D400
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
Zero Turn Mower (A48082)
Zero Turn Mower...
2018 GENIE GTH636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH636...
UNUSED CFG Industrial MX15RX Mini Excavator (A47384)
UNUSED CFG...
2017 Volkswagen Jetta (A50324)
2017 Volkswagen...
JOHN DEERE 35G EXCAVATOR (A51242)
JOHN DEERE 35G...
