Log winch
/ Log winch
One caution that comes to mind is that these winches exert considerable pulling force. If a tree were to hang up on something while being pulled up a steep slope, I suspect it could pull a L2502 down a slope. A redirect could help reduce this risk by parking the tractor in a safer spot, and then using the redirect to make the pull up the slope.
The forestry winches have a blade that sets down into the ground and take the stress off the tractor while also giving the winch a very solid platform to winch from. That's why I am considering a forestry winch verses just mounting a winch onto the back of the tractor which would be MUCH cheaper. I could do an electric winch off of the draw bar for under $400 otherwise.... And I have contemplated that route as well.
/ Log winch #22
....I could do an electric winch off of the draw bar for under $400 otherwise....
That's been talked about for a while, your alternator can not keep your batteries charged enough, yes... you can put a bigger alternator on and have a couple of deep cycle batteries installed but the line speed is super slow (they are made for power, not speed).
Not to mention, duty cycle stinks on electrical winches, too...
/ Log winch #23
This is what I have on my trailer. It works out by having two group 39 deep cycle batteries, which gives me enough charge to load the trailer. Then they must slowly recharge off the truck alternator, while I drive home with the load, unload it, and drive back to the site to load up again.
Unless you want to mount a few large batteries and a charge controller on your tractor, and/or take a lot of breaks between pulls, this is not the way to go. Figure 150 amps in any hard pull, doing some simple math on amp-hours to determine the amount of battery you'll need to cushion against your alternator and other alternator loads.
It's not a complicated problem, but it is a real problem to work out before implementation. Nothing is free.
/ Log winch #24
I think you are on the right track. Used winches are hard to find so if you take care of it and eventually decide you don't need it anymore, recouping much of your money should be easy.
/ Log winch
Yeah I guess I should have said I "had" contemplated that route but decided that wasn't the best option for me. It will be a forestry winch when I do go that route. I have been pulling what I could out so far with a long chain and recovery strap. It's worked but I am slowly getting to the point I will have to buy a much longer steel cable to reach.
/ Log winch #26
For me, the big advantage of cable is that you can run it thru blocks. I keep three of these in my toolbox:
Another option is dyneema or vectran line, much lighter and easier to transport than chain or cable, but very low abrasion resistance. You would never choke directly onto a log with hi-tech line, but you can use it to attach to a choker chain or cable, and then run that thru blocks to the tractor. The nice thing about line, versus cable, is that it's super easy to splice (if you go single-braid), and you can tie it off at any length with a bowline or a simple 2:1 to a figure-8 on a bight.
Check out Amsteel Blue, if interested in this option.
/ Log winch #27
Everybody should work the way they want. There are lots of variables, terrain (as oldnsloe mentioned) and wood lot characteristics are two big ones. For me a forestry winch is the way to go. I wouldn't get very far w/o one. I was working in this area last January.
A link to pictures of one tree I pulled out.
gg
/ Log winch #28
I have a Farmi winch I use with my Kubota BX24 and I have been well satisfied. Definitely consider a self releasing snatch block with your purchase. In my tight hilly forest I would be lost without it.
Make sure the drag is properly set. I didn't and I paid the price (literally). Had major damage from a near miss tornado. I had a 12" hickory tree snapped 25' up and hanging down. I connected my winch and thought I might be able to pull and release a few times to get the top to break loose. The drag was not set properly and I did not notice I was making a massive birds nest in my winch. It took an angle grinder to get it loose. The good news was I only lost about 5' of cable. The bad news was it was at the almost exact middle of my 180' cable.
Doug in SW IA
/ Log winch #29
Doug in SW IA
I anyone is interested I have a very lightly used Farmi L501 10,000 pound log winch for sale. Comes with a self releasing snatch block
Located in Woodstock Conn
Andy
/ Log winch #30
I think I have mentioned this before but my wood lot is all on a side hill. I now have the Wallenstein FX 110 with remote. The side hill with the tractor was a little nerving using chains and getting in and out of the tractor several times to make a short hookup. What really happened was that my hip started to bother me. The cab on a 4320 is not that big and I had to twist on my one leg to get in and out cab. Now with the winch I park the tractor at a convenient spot that maybe I am going to winch several logs. I work outside that cab, I do all of the hook ups and head to the landing. My hip still bothers me but I think the winch has slowed down the progression.
/ Log winch #31
That's awesome. Thanks, Doug! I've been using snatch blocks forever, both in sailing and rigging. But I'd never seen or heard of a self-releasing snatch block before, and it solves one of my most tedious frustrations with winching logs onto my trailer from wooded lots. I know what's going to be on my Christmas wish list, this year.
Anyone who runs snatch blocks has dealt with the frustration of jamming a log or cable eye up on one. It usually happens whenever you let a friend "help" with the winch controls.
/ Log winch #32
I have a Farmi 351P winch and am very satisfied with it. I wish I had experience working with a seasoned operator, but I just go slow and have never had a problem nor anything too "exciting."
/ Log winch #34
I have many trouble free hours on my Igland 3501, (7000# pull) winch. I've had it almost 8 years and it gets used hard. Once a year I'll spool out 100% of the cable and respool it under tension. In year one I managed to create a rats nest on the cable spool, I was fortunate to be able to untangle the mess without cutting the cable.
/ Log winch #35
I've NEVER cut a cable, if I get the line stuck, I hook it to a tree and drive the tractor ahead to pull on the line to free it up!
SR
/ Log winch #36
Looks to be OK but what is the do-dad on the end of the cable? New design I'm not familiar with?
Plus no sliders for attaching more than one log?
/ Log winch #37
That's the lowest price on a new 3pt tractor winch I've seen in the last year, especially since delivery is evidently included in the price.
/ Log winch #39
From the looks of it, you get what you pay for too...
SR
Care to comment further? You do tend to use your tractors and implements more than most of us.
Granted it isn't a Farmi or Fransgard, yet for the OP's intended use it seems like it should serve him well. A few sliders and chokers will add to the cost yet even after that I haven't seen anything used in decent shape, for close to that price.
/ Log winch #40
I forgot to mention this but the 8800 pounds of pull is when you have your 200 feet of line exposed. If you only have 50 ft of line out then you have some what less pulling power. I have at times when I couldn't pull something, move my tractor farther away just to get that extra pulling force. Now I think my FX 110 is like 3000 with a full spool and 11,000 when paid out. This is from memory so my numbers are probably off.
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
Massey Ferguson 383 (A64126)
Massey Ferguson...
Landhonor Mini Skid Steer (A60352)
Landhonor Mini...
2022 TEXAS PRIDE DUMP TRAILER (A65643)
2022 TEXAS PRIDE...
New/Unused ATS Cement Mixer (A65583)
New/Unused ATS...
(4) Tires and Rims (A65640)
(4) Tires and Rims...
