Mig Welders
/ Mig Welders #61
And about 2/3 the cost of buying a tank, unless you have something huge. Does that include the filling?
No. That's just the rental for 122 cu ft oxygen tank and 65? cu ft acetylene.
I think to purchase is about $500 for the pair now.
Terry
/ Mig Welders #62
Terry
Ok, I was thinking for some reason that was 1 tank.
/ Mig Welders #63
I am far from any kind of expert, but I have never heard this. Could you elaborate please?
Here is a nice little chart.;)
Zap over on Welding Web let us in on how he uses a drill motor and bench grinder to sharpen tungsten, works really well.
/ Mig Welders
My oxygen contract is around the $60/year. If all you use the O/A for is cutting then you should switch to propane. Well actually switch for everything. I could need to be corrected on this but from what I understand you can use propane instead of acetylene for everything but puddle welding cast iron. Something about adding carbon to the weld which isn't good. The only change needed to your torch is a propane cutting tip.
I usually get around two years worth of O/A use out of 20 lb bottle of propane. It's a lot cheaper than acetylene and no bottle contract either.
/ Mig Welders #66
Would it then effect brazing on c.I.?
/ Mig Welders #68
I've read where people say you can't use propane for welding, because propane doesn't produce a CO2 gas coverage. How true that is I have no idea! :confused3:
/ Mig Welders #69
It might. I don't know. I braze with propane all the time and haven't had any issues. Don't know what c.I. is though.
Sorry, supposed to be c.i. (cast iron) auto capitalize makes it look kinda funky.
/ Mig Welders
I'm thinking that brazing cast should be ok because your not melting the cast. When I look that two week welding course that Alberta Agriculture put on we puddle welded cast iron complete with cast iron rods. That's the only time I've ever done that. Now I weld cast iron with Arc Tec 223's.
/ Mig Welders
Now you have me curious. I have O/A welded steel before with propane but haven't done it for a long time. I have some rods and steel. What do I need to look for?
/ Mig Welders #72
So just switch to propane? Anything gotta be changed.. Regulator? torch?
/ Mig Welders
Everything stays the same. The present regulator just screws into the propane bottle. The only thing you need to change is the cutting tip. A local welding supply store or where you buy your oxygen should be able to supply you with a tip. Just take the old one along to make sure you get one that fits.
The puddle welding tips don't put out as much heat as they used to but I get along just using my largest tip for brazing. The other thing to remember is that acetylene rises in air so you light above the tip. Propane sinks in air so you light below the tip.
/ Mig Welders #74
Learn something new every day. Looks like I need to get on board with propane since all I use mine for is cutting and heating. I'll have to check out new tips and how the gauges will attach to the propane tank. Strange thing is that just yesterday I purchased a new smaller cutting tip for the O/A setup. How's that for lousy timing?
/ Mig Welders #75
Good timing for me, good info. I just accepted a free O/A set with an empty Acet bottle (big bottle!). It has a full Oxygen bottle though (200CF?).
/ Mig Welders #76
I have no idea. I can't even remember the last time I welded something with O&A.
Here is a good video on getting set up with propane. It make a real nice cut, takes a little longer to preheat tho. I can't stand to use propane to heat shrink anything, just takes way to long.:thumbdown:
https://www.youtube.com/watch?v=f2amO0T3vkQ
/ Mig Welders #77
Don't feel bad....
Terry
/ Mig Welders
Take it back and exchange it for a propane tip.
/ Mig Welders #79
I just finished using it to cut a circle in some 1/4" plate. Besides I only paid $7 for it. PA had a sale on.
I sure wish my cut looked like the ones Shield Arc posted. I spent way more time grinding than cutting. I think I need a LOT more practice.
Terry, that is a lot of tips and torches. I only have one torch, one welding tip, one rosebud and now 2 cutting tips. I don't get a lot of use from it but it sure is nice to have it when needed.
/ Mig Welders #80
I just finished using it to cut a circle in some 1/4" plate. Besides I only paid $7 for it. PA had a sale on. I sure wish my cut looked like the ones Shield Arc posted. I spent way more time grinding than cutting. I think I need a LOT more practice. Terry, that is a lot of tips and torches. I only have one torch, one welding tip, one rosebud and now 2 cutting tips. I don't get a lot of use from it but it sure is nice to have it when needed.
Long live Princess Auto! :):)
Terry
EZ-GO SHUTTLE 2X2 TXT GAS GOLF CART (A63276)
EZ-GO SHUTTLE 2X2...
UNUSED WOLVERINE HYD CONCRETE CHUTER (A64281)
UNUSED WOLVERINE...
2018 Nissan Versa Sedan (A61574)
2018 Nissan Versa...
2025 48in. Farm Jack (A61572)
2025 48in. Farm...
2022 CATERPILLAR 310 EXCAVATOR (A62129)
2022 CATERPILLAR...
Adams 5 T Fertilizer Spreader (A63688)
Adams 5 T...
