OP
pmsmechanic
Elite Member
- Joined
- Dec 6, 2013
- Messages
- 4,437
- Location
- Southern Alberta, Canada
- Tractor
- 4410 and F-935 John Deere, MF 245
Terry you wanted a picture of my John Deere welder. <img src="http://www.tractorbynet.com/forums/files/welding/407621-mig-welders-forumrunner_20150120_092655-png"/>
That's the way I learned.... Introduction to oxy acetylene was first, to learn puddle control, just as you said. ..snip.....................There's really something special about putting a flame to metal, seeing that puddle form and then moving it along with a nice motion, getting two pieces of metal to join with NO filler rod just to see if you can keep two puddles joining at the same time. Blowing holes through it just makes you go back and try harder next time. If someone has never done oxy/acetylene torch welding, they really ought to take a crack at it. Its an art.![]()
I thought the order of utility for us "tractor maintainers" was SMAW MIG then TIG.
SMAW because it can do dirty, THICK and outside in the wind
MIG second because it can do thin, is fairly easy to learn and usually can do fluxcore outside in a breeze
TIG being last because it requires extremely clean conditions and no wind.
Is that not true?
Tell me who doesn't enjoy turning on the gas, clicking the striker a couple clicks, hearing the POP and seeing the pretty orange flame with black soot licking off it? Then start adjusting the knobs until you get the flame you want. If you stop and check yourself right at that point, you'll probably find yourself smirking a bit.![]()
Terry i just had a good look at the welder and the operators manual and there is no info in there as to who made the welder. I've had it apart once to replace a spring inside so that the amps wouldn't change while i was welding. <img src="http://www.tractorbynet.com/forums/files/welding/407679-mig-welders-forumrunner_20150120_152924-png"/>
Personally I think Tig welding is easier than O&A welding. With Tig welding, especially with these new inverter welders you have so much control over the puddle. And you don't have to put up with the heat of an O&A torch:thumbdown:. And you can control the amount of penetration you get with Tig by the way you sharpen the tungsten.
For a few years I couldn't afford to buy an acetylene contract so that's what I did all my cutting with, that I couldn't do with a chop saw. The ArcAir uses the full 295 amps. I tried it with a Miller 225 but the juice just wasn't there.
Acetylene contract is a misprint on my part. I should have said oxygen contract as I no longer use acetylene. Out here you can buy your own bottles but most people still pay a yearly bottle rental for oxygen. Not many use acetylene any more. Most cut with oxygen and propane. I live in the sticks too but I'm the one that does the fixing.
Count me in as one of the dumb ones who still rents his O/A bottles. Just got my invoice from LWS last month....almost $200 per year (including taxes.). I'm pretty sure that's almost triple the cost of when I started the rental back in the late 1960's.
Terry
