Mig Welders
/ Mig Welders
Terry you wanted a picture of my John Deere welder.
/ Mig Welders #42
Terry you wanted a picture of my John Deere welder. <img src="http://www.tractorbynet.com/forums/files/welding/407621-mig-welders-forumrunner_20150120_092655-png"/>
Nice! Thanks. Any idea who made it for JD? Bilingual label for Canada... Terry
/ Mig Welders #43
That's the way I learned.... Introduction to oxy acetylene was first, to learn puddle control, just as you said. ..snip.....................There's really something special about putting a flame to metal, seeing that puddle form and then moving it along with a nice motion, getting two pieces of metal to join with NO filler rod just to see if you can keep two puddles joining at the same time. Blowing holes through it just makes you go back and try harder next time. If someone has never done oxy/acetylene torch welding, they really ought to take a crack at it. Its an art. ;)
Not an expert but O/A is good for puddle control learning.
Try Tig with no filler and do the same it is a good learning experience. Bottle plus $100 +/- gives a scratch Tig unit that is quite useful. Spend time just working the puddle. See what you learn.
/ Mig Welders #44
I thought the order of utility for us "tractor maintainers" was SMAW MIG then TIG.
SMAW because it can do dirty, THICK and outside in the wind
MIG second because it can do thin, is fairly easy to learn and usually can do fluxcore outside in a breeze
TIG being last because it requires extremely clean conditions and no wind.
Is that not true?
It's true if you only TIG weld with the TIG welder, but all the ones I have worked with can also do stick.
/ Mig Welders #45
Tell me who doesn't enjoy turning on the gas, clicking the striker a couple clicks, hearing the POP and seeing the pretty orange flame with black soot licking off it? Then start adjusting the knobs until you get the flame you want. If you stop and check yourself right at that point, you'll probably find yourself smirking a bit. ;)
/ Mig Welders #46
Never thought about it but that is so true. :D
Terry
/ Mig Welders #47
It is true, and it is fun, but the price.. sucks. I have been using TIG for everything I can, the price of Acetylene is just too high. Argon is not near as bad, and running TIG is a lot like gas welding anyway.
/ Mig Welders #48
Personally I think Tig welding is easier than O&A welding. With Tig welding, especially with these new inverter welders you have so much control over the puddle:cool:. And you don't have to put up with the heat of an O&A torch:thumbdown:. And you can control the amount of penetration you get with Tig by the way you sharpen the tungsten.
/ Mig Welders
Terry i just had a good look at the welder and the operators manual and there is no info in there as to who made the welder. I've had it apart once to replace a spring inside so that the amps wouldn't change while i was welding.
/ Mig Welders #50
Terry i just had a good look at the welder and the operators manual and there is no info in there as to who made the welder. I've had it apart once to replace a spring inside so that the amps wouldn't change while i was welding. <img src="http://www.tractorbynet.com/forums/files/welding/407679-mig-welders-forumrunner_20150120_152924-png"/>
Ernie according to Welding Web it is probably made by Century.
Don't ever sell it :)
/ Mig Welders #51
Terry
/ Mig Welders #52
When I started welding I bought a Century 295 stick welder at a flea market because it came with a 100' welding cable extension cord, 25' ground and 50' stinger cable. The seller said the high circuit didn't work so I got it for $180. (the extension cord is worth that much). I fixed the high circuit problem but I couldn't weld with it. I had no experience and had a heck of time trying to strike an arc. I took a welding course in the evenings at the local college but even after that I still had a heck of a time striking an arc.
I bought a Lincoln 180 mig welder and that problem ended immediately. Now I enjoy welding instead of cursing it. The mig just makes it so easy for a novice to use. THAT is what I love about mig. I still have the Century but haven't used it since getting the mig. I do however use the extension cord on occasion.:) I'm sure the stick is better suited for thicker materials but I have welded a fair bit of mild steel with the mig, mostly 1/4" or 5/16" and it has produced very strong joints in my opinion. I even welded some 1/2" for my 20 ton long splitter and it has held together for about 6 years now, even though I sometimes think it will break with all the stress pinging I hear when the splitter slows down in the very hard woods or knots. The 1/2" weld took a lot of prep work and multiple passes but I would trust that weld a lot more than a stick weld that I can produce.
/ Mig Welders #53
Hilbilly in the 1970s I worked in a fab shop. Our #1 contract was building nuclear waste tanks. Some of these tanks had 7-inches of lead in the walls, floor, and ceiling. The tanks were 8-feet in diameter. They all had 4-inch thick x 8-inch tall rolled square stock welded at the top of the tank for a lifting ring. We had to put a 1 7/8-inch fillet weld top and bottom all the way around this lifting ring. We ran 1/16-inch Mig wire, with 100% CO2.
/ Mig Welders #54
Well, I like taking pictures with film, too, but it ain't practical compared to digital anymore. Nor is it productive. :laughing:
/ Mig Welders
I entered 295 into jdparts and two models showed up. Mine is the first model in the parts book. Thanks for the picture and info Terry.
I enjoy welding with mine. I weld with mostly 1/8th 7018AC. They aren't the easiest rod to weld with but if I use them every time then when I need to make a critical weld at least I don't have to learn to weld with a new rod first. Over the years I've come to exclusively use Lincoln rods because they weld so nice. Hilbilly that might have been your problem as not all rods weld the same. Plain 7018 (no ac) rods are just about impossible to weld with
I also have an ArcAir model K2000 that I use with this welder. I needed to buy ac carbon rods but it works. It a pain to keep the arc going but it works. For a few years I couldn't afford to buy an acetylene contract so that's what I did all my cutting with, that I couldn't do with a chop saw. The ArcAir uses the full 295 amps. I tried it with a Miller 225 but the juice just wasn't there.
/ Mig Welders #56
What is an acetylene contract?
I use O/A for any cutting I have to do but I'm not good at it. Just involves a little more grinding. I get my cylinders swapped at KMS tools or one of the welding supply places in the city. I'm not a welder but sometimes feel like one with the mig.:laughing:
I live in the sticks and it's just a necessity to do any welding and cutting myself, since it's a major PITA to take stuff into town to get fixed or fabricated. Besides I like to do things myself.
/ Mig Welders
Acetylene contract is a misprint on my part. I should have said oxygen contract as I no longer use acetylene. Out here you can buy your own bottles but most people still pay a yearly bottle rental for oxygen. Not many use acetylene any more. Most cut with oxygen and propane.
I live in the sticks too but I'm the one that does the fixing.
/ Mig Welders #58
Acetylene contract is a misprint on my part. I should have said oxygen contract as I no longer use acetylene. Out here you can buy your own bottles but most people still pay a yearly bottle rental for oxygen. Not many use acetylene any more. Most cut with oxygen and propane. I live in the sticks too but I'm the one that does the fixing.
Count me in as one of the dumb ones who still rents his O/A bottles. Just got my invoice from LWS last month....almost $200 per year (including taxes.). I'm pretty sure that's almost triple the cost of when I started the rental back in the late 1960's.
Terry
/ Mig Welders #59
I am far from any kind of expert, but I have never heard this. Could you elaborate please?
Obviously you can get finer arc control with a sharper point, and many people people like to ball the end for AC tig, but that is the extent of my expertise on tungsten profile.
/ Mig Welders #60
Terry
And about 2/3 the cost of buying a tank, unless you have something huge. Does that include the filling?
Year: 2020 Make: Hyundai Model: Sonata Vehicle Type: Passenger Car Mileage: 64,929mi Plate: Body (A61574)
Year: 2020 Make...
2025 Greatbear Rachet Tie Down & Flatpack Tool Box (A61567)
2025 Greatbear...
3pt 20' Cultivator (A64119)
3pt 20' Cultivator...
2007 International 4300 Bucket Truck 55' (A62613)
2007 International...
CASE INTERNATIONAL 3330 HI-CYCLE SPRAYER (A63291)
CASE INTERNATIONAL...
UNUSED 4' X 300' ROLL ATS POWER GRASS PROOF CLOTH (A64281)
UNUSED 4' X 300'...
