Which model for snowblowing 500' driveway?
/ Which model for snowblowing 500' driveway? #1
danwolfgang
CT
Deere 1025R
I'm in the process of buying a home and need a tractor. With a few Deere dealers nearby that seems like the appropriate choice, but which model? (I haven't visited any of those dealers yet.) There's only about 1/2 acre to mow (though that may grow over the years as we clear some more of the property), however there's a flat 500' driveway that I'll need to clean. It seems to me that the demands to blow the driveway will far exceed the mowing and other light hauling and yard cleanup the tractor will be used for. If it weren't for the blowing, I'd think an X300 would be more than adequate for a very long life of use. But what will the flat 500' driveway require -- step up to an x320? x360? Even an x500? Any input is appreciated.
Dan
/ Which model for snowblowing 500' driveway? #2
Welcome to TBN!
Think about your future plans on the property, and use that as a guide now. If you foresee
clearing land, maybe regrading the area, and growing more lawn, you may want to consider a
small CUT with a loader and 3ph. Sure is a lot more $$$ than a lawn tractor, but for landscaping
projects its a nice tool to have.
Another option, a used X700 style tractor can also be found with a small loader, and they have
sturdy attachments like the front blade or blower, and an optional 3ph for a tiller.
If these projects are still in the maybe stage, then you can get away with an X3 or X5 to do
the snow removal, leaning towards the X5 for the differential lock and larger tires and increased
weight which will aid in traction with the blower on. Again, if new isn't in the budget used machines
are out there with very low hours at a bit of a savings.
How much land is there on this property?
Yes, I'm thinking about future use. Ground engagement for a tiller may be in the future, but I have no expectation of clearing the property with such a small tractor. We've got 2+ acres and some more of it may get cleared for grass/garden/playing (perhaps another 1/2+ acre?), but I don't expect to do that myself. (I'm betting it would make a lot more economical sense to bring in some heavier equipment for a few days to clear if/when we do that.) I expect the tractor to be used for snow, lawn, typical yard work with a cart, and probably some rides with my son.
/ Which model for snowblowing 500' driveway? #4
As Dutch states getting a little bigger machine like a CUT in the 1023/1026R or similar would give you more versatility down the road.
I would think with 500' drive a front mount snow blower would be ideal, and then a rear blade for cleanup and counter weight.
/ Which model for snowblowing 500' driveway? #5
Bite the bullet and go with the X700 series and get 4WD. Your going to find more and more uses as time goes on.
I bought a 355D and while it was a good machine the 2WD is a pain. I have about 400' of driveway. The X748 does it all with never spinning a tire. I won't use chains on it since I have a blacktop drive.
In the long run I'd have saved money getting the X748 originally.
/ Which model for snowblowing 500' driveway? #6
For my 530 foot gravel driveway and another 300 foot driveway I use a 30 HP 4wd CUT with the Frontier 64" wide 3 point snow blower.
/ Which model for snowblowing 500' driveway? #7
I have a similar length driveway and I second the recommendation to make sure you get 4WD. If you're thinking of things like clearing that drive, tilling a garden, and clearing a bit of land yourself then I'd personally get a 1026R. It's a lot of money, but it's super-versatile. I highly doubt that you'll ever wish you'd purchased a smaller tractor...
For our 4.2 acre property (nearly all wooded) with about 600' of driveway (and two garage aprons), I bought a 2032R with a 54" front-mount snowblower, a loader with forks and a bucket, and a box scraper. It's more than we need, but my wife and I spent the evening in the woods with it today and I'm glad that I didn't get anything smaller. I'm already zeroing in on the next implements that I want to buy!
/ Which model for snowblowing 500' driveway? #8
At this point in time, I'd go for a fairly cheap riding mower and a plow for your truck or SUV.
You could also consider one of the older Deere CUTs (755, 855, 4100 or similar)...or another brand (Kubota BX2200 or B-7500). Most of these can be had for less then $10K..much less if you look around enough. And you might find one with a front mounted snow blower!
Future plans to expand your lawn may require other larger equipment (and a zero-turn mower may be a better choice then)...other you may never increase that .5 acre you're going to mow. That decision can come at a later date.
/ Which model for snowblowing 500' driveway? #9
This is what you need to go look at.
/ Which model for snowblowing 500' driveway? #10
I would say a 500' driveway could be easily handled with an x500 (with chains) since its flat. In CT your not getting daily snow. I saw a new x500 for $5.1k online. This is the time to buy for sure.
You can always trade up if you have the need.
/ Which model for snowblowing 500' driveway? #11
I have a mile long gravel driveway. In my situation, I've found that summer maintenance is much more demanding than winter snow removal. Pulling a land plane grading scraper(LPGS) or a roll-over box blade(ROBB) can require more HP than moving snow. I moved from a 25 hp tractor to my current 60+ hp unit and find that summer grading etc is much easier and definitely more efficient.
/ Which model for snowblowing 500' driveway? #12
Buy the X700 series if money allows.I bought the (diesel)X740 ultimate with the 7 iron deck back in 2011 and love it.
/ Which model for snowblowing 500' driveway? #13
I've got a LX280 (18Hp, 2 wheel drive JD "lawn" tractor) with a 2 stage Berco (Bercomac) 44" snowblower. On flat ground it's all I or you'll need. It'll blow snow probably 40-60 ft.
The only time I've ever got it stuck was early days with it, with a deep (1 ft+) of snow and I didn't know to avoid making a single width path of excessive distance. Then when you try to back up any great length in narrow canyon that you just cleared, it's easy to get off track an inch or two, back wheel knocks in snow, as blower also knocks snow behind it into your path, now blocking front tire going forward. With 2 wheel drive, back up traction with blower up is limited, so don't trap yourself. Even if you do, then it's a matter of picking up the back end (by hand) and getting back in track (or getting the old lady to sit on the fender for more traction). Or just go forward, fan to the left, fan to the right, and clear a turn around spot.
(Or only go 2-3 lengths at a time and make a double-wide path as you go.)
Haven't ever been stuck since 6+ years.
Then again, you'll never regret if you go bigger. (Gee its easy to spend other people's money.)
/ Which model for snowblowing 500' driveway? #14
You can do 2 wd but if you get stuck, it's a pain in the back at least. It can be very frustrating and you can hurt your back trying to get it out.
I'm in the 4wd camp. Not familiar with the JD line but the X 700 series looks about right equipped with 4wd, mower deck and front snowblower.
/ Which model for snowblowing 500' driveway? #15
I used to use a JD 425. Got tired of putting chains on it. Now have an X739 and love it. No chains required. HDAP tires are awesome in the snow. Also, know that a snowblower is going to get you real wet without a cab. Consider a front blade. It is way faster and keeps you dry too. The only time a snowblower has an advantage is in really deep snows. But, if you stay in front of the big storms, keeping the snow accumulation below a foot or so, the blade is the best. The blade isn't as neat, but much faster without getting you covered in blowing snow.
If you don't mind putting chains on, consider a used 400 series.
/ Which model for snowblowing 500' driveway? #17
I have 1/4 mile gravel road that I have used a JD 425 with snow blower and soft cab to clear until just recently. I replaced the 23in tires with 70lb per tire weighted and filled 26 HDAP tires ... this set up worked great and I never worried about chains. Recently though I bought my brother in laws 400 ATV with plow. This is far faster but not as fun or neat as Gittyup mentioned.
/ Which model for snowblowing 500' driveway? #18
I went much bigger, I suppose, opting for a SCUT with bucket loader & backhoe.. AND a front-mount blower. I have more woods & trees, and a 200' uphill driveway with a large apron in front of the garage.
Although I love my red tractor, I was just took a gander at the X748. Very impressive. That would also be my recommendation if you can swing it. The 4WD and diesel are also very good things to have; I've discovered I can mow my lawn in less than half the time compared to using my old (gas-powered) push mower, and use less fuel as well. :thumbsup:
The beautiful thing about a blower is the lack of banks and large snow piles, assuming you have enough room to blow it away and not into the neighbor's yard!:D
Welcome to TBN!
/ Which model for snowblowing 500' driveway? #19
Dan
We built a home on 4 acres with a 650-700' driveway (gravel). Before building, I bought a Kubota B2920 to do some light clearing, mainly to cut a narrow driveway path in, prepare for surveying, and to gather up lumber and firewood from valuable trees. Having a front loader and 3-pt hitch was invaluable for this work, as was 4WD. I had briefly given thought to using my Deere riding mower (LT series, previous model to the X300 series but with some features now on X500 series) with the rear garden cart, but was unsure of this. In retrospect, it would have been a failure, and a B2920-sized machine with front loader and 4WD was just perfect.
Later on, I upgraded the B2920 to an L3200 mainly to get a larger front bucket and a little more front loader capacity, but also to pull a larger box blade to improve driveway maintenance work (which has happened about once a year for the first couple years, but will probably taper off since the gravel has locked up pretty good now). I also use a 6' rear blade to clear snow, and the L has been great for this -- it has enough weight and traction that I can clear snow in 2WD. Here, we only get 2-3 significant snowfalls a year (significant for this area = more than 5").
Through all of that, I have kept the Deere LT, as it's superior for mowing. I went down from about 3/8 acre of landscaped fescue at our old house to 1/4 acre of simpler lawn over the septic field, with another 1/4 acre of native grasses up by the road front.
So with that pre-amble, here are some key points I have learned:
1) for under 1/2 acre, I have no doubt a small riding mower or lawn/garden tractor (or maybe zero-turn if lots of trees, curves, or obstacles) is the best option for mowing. Maneuvering the B and L in the same spaces is cumbersome and would not be practical for mowing. If the lawn is flattish, 2WD is just fine.
2) the 2WD lawn tractor is just fine for basic gardening work with a small cart. However, the larger tractors with front loader do that just fine even though it would seem overkill.
3) venturing off the lawn for any sort harder work, even as simple as hauling firewood around, is a chore for the little 2WD tractor, and it will get stuck in soft or slippery ground in a heartbeat. This is where 4WD starts to become important on any size tractor, and I'd think X700 series garden tractor is a minimum for harder work. If venturing into the woods or rougher terrain, ground clearance becomes important, and then you're talking about a SCUT or CUT for sure (though some of the SCUTs don't have that much more clearance than garden tractors).
4) the dynamics of pushing a snow blower are different than using a blade, but even with our limited amount of snow, there's no way I can envision using my X300/X500 sized LT model to clear snow on my long curved gravel driveway. Knowing how hopeless my 2WD LT is in snow, I'd say, 4WD and X700 sizing is a minimum, though it still seems too small when I consider the scale of the tractor to the scale of the driveway. The B2920 scaled well to my driveway in general. The L is a good size too.
Overall, I feel like you should look at a 4WD X700 series as a minimum (X748 is a gem if I am remembering the model numbers right). But that gets you up into a pretty lofty pricing range, and it is a lot more cost effective to consider a 1023E or 1025R at that point. Then you have the ability to put on a honest and capable front loader, and a lot more room for expansion down the road. Also consider the Kubota BX series. These SCUTs mow pretty good from what I have seen, and are not so large that they get cumbersome.
If ground clearance ever would become a factor when venturing off the lawn and driveway, maybe consider a Deere 2-series or equivalent. But then you have a machine that's too big for mowing small areas. And you'll start to arrive at my solution, which is a dedicated 2WD mower and a larger 4WD tractor. I think a lot of people here have the same or similar solution.
So X700 series and 4WD is your entry point in my opinion. I hope that helps. Good luck!
I talked to a bunch of people and read a lot (including all of the feedback in this thread), and came to realize that we needed something pretty big. An x738 or x748 was looking ideal, though the 1023e seemed a good option, too. Add in a tiller for my wife and the price difference between the x7 and 1 family was pennies. And gee, that 1 family tractor can handle a loader and backhoe to do some of the work on the property that we thought we'd have to hire someone to do. Our needs weren't too far off from our wants... so we just went in, whole hog. 1025R, 54" snowblower, 54" mower, H120 loader, 260A backhoe, 647 tiller. The 0% financing helped make it a pretty easy decision!
