Buying Advice Wolff Limb Clipper
/ Wolff Limb Clipper #1
raaron
Roola Mo
LS
Anyone own or have ever used a limb cutter by wolff MFG, thinking about buying one any advice
/ Wolff Limb Clipper #3
I emailed them and the tree shear is $3900 + shipping and the Limb Shear is $1500 + shipping
No hoses with either
/ Wolff Limb Clipper #4
That design looks simple and quick to home build and for sure not $1500. Some scrap 1" plate, a few bolts and a cylinder plus whatever mounting hardware you wanted to use.
/ Wolff Limb Clipper #5
On Ebay, a new unit is $1400. Used handheld saws are $400.
It would be hard to build a compatible system and save any money. It could be done, no doubt but is it really a cost effective build?? JMHO
/ Wolff Limb Clipper #6
/ Wolff Limb Clipper #7
That's what I need!!
Do you have any dimensions and hydraulic specs?? You can PM me if you like
Thanks J_J
Kneedeep
/ Wolff Limb Clipper #8
/ Wolff Limb Clipper #9
The steel is 3/4 n , cutting blade is 6 in wide, 20 in long.
8 or 10 in cyl.
Made out of stuff I had laying around.
My hyd are 3000 psi.
/ Wolff Limb Clipper #10
Did you ever work out the hydraulic chainsaw?
No, but have a good idea how to make it work.
The chainsaw is closed center, and my hyd are open center.
/ Wolff Limb Clipper #11
Here is my limb cutter. Similar but cheaper. ... Total cost about $50. Had most of the parts.
J_J that's great. And it looks like you can turn it horizontal, is that the case?
Then all you would need is a vertical riser and longer hoses and you could trim tree tops. That's what I want, to keep my trees from growing up into the power lines.
Nice job.
/ Wolff Limb Clipper #12
I have a 4 way adapter to change direction.
Pointed down, I can cut roots after digging a hole.
/ Wolff Limb Clipper #14
UNUSED RAYTREE RHBC72-72" HYD BRUSH CUTTER (A62131)
UNUSED RAYTREE...
Valley Model 8000 Irrigation System (A62180)
Valley Model 8000...
2016 TEXT 26ft T/A Dovetail Flatbed Equipment Trailer (A59230)
2016 TEXT 26ft T/A...
20 Yard Roll Off Dumpster (A61165)
20 Yard Roll Off...
CATERPILLAR TL642D TELESCOPIC FORKLIFT (A62129)
CATERPILLAR TL642D...
(2) 580/70R38 TIRES W/8 LUG RIM (A62130)
(2) 580/70R38...
