Buying Advice Wolff Limb Clipper
/ Wolff Limb Clipper #1
raaron
Roola Mo
LS
Anyone own or have ever used a limb cutter by wolff MFG, thinking about buying one any advice
/ Wolff Limb Clipper #3
I emailed them and the tree shear is $3900 + shipping and the Limb Shear is $1500 + shipping
No hoses with either
/ Wolff Limb Clipper #4
That design looks simple and quick to home build and for sure not $1500. Some scrap 1" plate, a few bolts and a cylinder plus whatever mounting hardware you wanted to use.
/ Wolff Limb Clipper #5
On Ebay, a new unit is $1400. Used handheld saws are $400.
It would be hard to build a compatible system and save any money. It could be done, no doubt but is it really a cost effective build?? JMHO
/ Wolff Limb Clipper #6
/ Wolff Limb Clipper #7
That's what I need!!
Do you have any dimensions and hydraulic specs?? You can PM me if you like
Thanks J_J
Kneedeep
/ Wolff Limb Clipper #8
/ Wolff Limb Clipper #9
The steel is 3/4 n , cutting blade is 6 in wide, 20 in long.
8 or 10 in cyl.
Made out of stuff I had laying around.
My hyd are 3000 psi.
/ Wolff Limb Clipper #10
Did you ever work out the hydraulic chainsaw?
No, but have a good idea how to make it work.
The chainsaw is closed center, and my hyd are open center.
/ Wolff Limb Clipper #11
Here is my limb cutter. Similar but cheaper. ... Total cost about $50. Had most of the parts.
J_J that's great. And it looks like you can turn it horizontal, is that the case?
Then all you would need is a vertical riser and longer hoses and you could trim tree tops. That's what I want, to keep my trees from growing up into the power lines.
Nice job.
/ Wolff Limb Clipper #12
I have a 4 way adapter to change direction.
Pointed down, I can cut roots after digging a hole.
/ Wolff Limb Clipper #14
2015 DODGE DURANGO RT SUV (A59575)
2015 DODGE DURANGO...
2022 Takeuchi TL12R2 (A60462)
2022 Takeuchi...
Arrow Quip 5500LV Cattle Chute (A64047)
Arrow Quip 5500LV...
UNUSED KJ 42'X30' METAL STORAGE SHED (A62131)
UNUSED KJ 42'X30'...
UNUSED WOLVERINE QC1-26-20G UNIVERSAL HITCH (A62131)
UNUSED WOLVERINE...
2023 John Deere 8R 370 Tractor (A63109)
2023 John Deere 8R...
