Snow Equipment Owning/Operating Pictures of your snow weapons
   / Pictures of your snow weapons #2,261
Great set up I like how you "tucked" the plow tight and under the arms. This will be my first year with mine mounted under also. I had it connected with about 4 inches under the frame last year. It worked well, but I still didnt like the legnth and also that amount of weight overhanging the front. Made it feel like to much weight swinging around out there.
Here's a pic of what I install to plow snow.
   / Pictures of your snow weapons #2,263
Tell me more about these wings on the bucket. Did you build them or buy them?
Skyhook is correct - homebrew. There were a few pieces of 10 Ga galvanized that were cut to fit. They lap over most of the outside. On the inside each wing has two pieces of 1/4" x 1-1/2" flat bar. The first piece fits tight against the bucket and the second is staggered so it fits inside the bucket. Like a long narrow belt clip on a tape measure. Scrap pieces of angle are welded on the outside to stiffen them and another for a mini skid on the bottom. Due to the way things lock together, a single bolt holds each one securely. Now we need some snow for a test drive.
   / Pictures of your snow weapons #2,264
Chim, what did you use to make those "slits" for the chains on top of your bucket....
torches, plasma?
   / Pictures of your snow weapons #2,265
This is my snow weapon!!! I just got the FEL on it last week! Works like a charm!
   / Pictures of your snow weapons #2,266
torches, plasma?
Nothing fancy, just a drill press and band saw. Drill a hole where the bottom of the slot wants to be and then saw in from the edge. Instant radiused end.
   / Pictures of your snow weapons #2,267
torches, plasma?
   / Pictures of your snow weapons #2,269
:thumbsup:
   / Pictures of your snow weapons #2,270
I thought that chute was electric.... it sounds like a diesel! :laughing:
Nice job! :thumbsup:
   / Pictures of your snow weapons #2,271
   / Pictures of your snow weapons #2,272
Finally. After many, many years exposed to the elements I have a machine with a cab. Finally....... 022.jpg023.jpg027.jpg
   / Pictures of your snow weapons #2,273
Finally. After many, many years exposed to the elements I have a machine with a cab. Finally....... <img src="http://www.tractorbynet.com/forums/files/snow-removal/399309-pictures-your-snow-weapons-022-jpg"/><img src="http://www.tractorbynet.com/forums/files/snow-removal/399310-pictures-your-snow-weapons-023-jpg"/><img src="http://www.tractorbynet.com/forums/files/snow-removal/399311-pictures-your-snow-weapons-027-jpg"/>
Nice looking little snow machine, great wife. Best of luck and stay warm.
   / Pictures of your snow weapons #2,274
latest edition brought home today....1998 cat 416c turbo
   / Pictures of your snow weapons #2,275
Nice and clean,:thumbsup: do you plan on a plow for it or are you leaving it just as is.
   / Pictures of your snow weapons #2,280
D7E nice cat, looks well cared for. That should care for a light dusting😀
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A59905)
2020 KENWORTH T680...
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A59905)
2018 INTERNATIONAL...
2014 KENWORTH T800 HYDRO EXC VACUUM TRUCK (A59823)
2014 KENWORTH T800...
Enmark Z Spray (A53316)
Enmark Z Spray...
30KW GENERATOR (A58214)
30KW GENERATOR...
