Snow Equipment Owning/Operating Pictures of your snow weapons
   / Pictures of your snow weapons #2,261
Great set up I like how you "tucked" the plow tight and under the arms. This will be my first year with mine mounted under also. I had it connected with about 4 inches under the frame last year. It worked well, but I still didnt like the legnth and also that amount of weight overhanging the front. Made it feel like to much weight swinging around out there.
Here's a pic of what I install to plow snow.
   / Pictures of your snow weapons #2,263
Tell me more about these wings on the bucket. Did you build them or buy them?
Skyhook is correct - homebrew. There were a few pieces of 10 Ga galvanized that were cut to fit. They lap over most of the outside. On the inside each wing has two pieces of 1/4" x 1-1/2" flat bar. The first piece fits tight against the bucket and the second is staggered so it fits inside the bucket. Like a long narrow belt clip on a tape measure. Scrap pieces of angle are welded on the outside to stiffen them and another for a mini skid on the bottom. Due to the way things lock together, a single bolt holds each one securely. Now we need some snow for a test drive.
   / Pictures of your snow weapons #2,264
Chim, what did you use to make those "slits" for the chains on top of your bucket....
torches, plasma?
   / Pictures of your snow weapons #2,265
This is my snow weapon!!! I just got the FEL on it last week! Works like a charm!
   / Pictures of your snow weapons #2,266
torches, plasma?
Nothing fancy, just a drill press and band saw. Drill a hole where the bottom of the slot wants to be and then saw in from the edge. Instant radiused end.
   / Pictures of your snow weapons #2,267
torches, plasma?
   / Pictures of your snow weapons #2,269
:thumbsup:
   / Pictures of your snow weapons #2,270
I thought that chute was electric.... it sounds like a diesel! :laughing:
Nice job! :thumbsup:
   / Pictures of your snow weapons #2,271
   / Pictures of your snow weapons #2,272
Finally. After many, many years exposed to the elements I have a machine with a cab. Finally....... 022.jpg023.jpg027.jpg
   / Pictures of your snow weapons #2,273
Finally. After many, many years exposed to the elements I have a machine with a cab. Finally....... <img src="http://www.tractorbynet.com/forums/files/snow-removal/399309-pictures-your-snow-weapons-022-jpg"/><img src="http://www.tractorbynet.com/forums/files/snow-removal/399310-pictures-your-snow-weapons-023-jpg"/><img src="http://www.tractorbynet.com/forums/files/snow-removal/399311-pictures-your-snow-weapons-027-jpg"/>
Nice looking little snow machine, great wife. Best of luck and stay warm.
   / Pictures of your snow weapons #2,274
latest edition brought home today....1998 cat 416c turbo
   / Pictures of your snow weapons #2,275
Nice and clean,:thumbsup: do you plan on a plow for it or are you leaving it just as is.
   / Pictures of your snow weapons #2,280
D7E nice cat, looks well cared for. That should care for a light dusting😀
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
Kubota B2301 (A53317)
2014 KENWORTH T800 HYDRO EXC VACUUM TRUCK (A59823)
2014 KENWORTH T800...
Peterbilt 377 Semi-Truck (A56438)
Peterbilt 377...
2009 JACK COUNTY KILL TRAILER (A58214)
2009 JACK COUNTY...
Toro Zero Turn Lawn Mower (A56859)
Toro Zero Turn...
