NEW PROJECT
/ NEW PROJECT #11
looks very clean RB, not wasting any time on this one either !! Mine has just turned 1600 hours, its got a yanmar loader on it, ikts a handy size tractor
/ NEW PROJECT
I couldn't tell by the pics.. Will you have to replace the rod as well as turn the crank. I have owned drag cars, and when my engine turned a bearing, it usually also screwed up the rod
Not sure about the rod. The rod cap didn't look to bad. I'll know more when I get it broke down. Now I have to clean out my shop so I can get it inside. May take a while.
/ NEW PROJECT
I managed to get the tractor in the shop yesterday and will start tearing it down this week. I noticed someone has replaced one front rim that will only fit dish out. I need to try and find an original rim to match the other one. As a last resort I know Hoye has new ones but I would like to find an original one. Anyone know if you turn one rod journal does all the journals have to be turned to match?
/ NEW PROJECT #14
R Barger,
From my days rebuilding auto engines, I USUALLY had them all turned to keep things equal. It isn't REQUIRED, so if you are trying to save money, just turn the one. If you are going to reuse the rod, just make sure you know haw far the rod journal was turned so you can get the right oversize bearing. Make sure you clean out the oil passages in the crank and PRELUBE all the bearings with lithium grease. Also, what I used to do was to prime the oil system after assembly. There are SEVERAL ways to do this, but I'm not sure which would be the way on your engine.:confused3: Good luck with the GREAT find. :thumbsup: :2cents:
Dave
/ NEW PROJECT
Thanks for the info. The rod journal that is damaged is the last one to receive oil and it seems all the other beariings are good. I suspect a blocked oil galley. I'll know more when I get it tore down. I'm not really pinching pennies but if the other bearings are not worn why spend the money[847hrs]. I'm planning to prime using the decompression feature before starting.
/ NEW PROJECT #16
R Barger,
Is there a way for you to turn the oil pump from outside the engine?? If so, this would be the PREFERED way to prime the oil system. On gas engines, I would leave the distributor out after assembly and use a stub shaft and a drill to turn the oil pump and VERIFY that there was oil pressure. :2cents:
Dave
/ NEW PROJECT
Not sure about turning oil pump from outside. Started the tear down today. The crank is just as I thought it would be with one journal bad and the rest of the crank okay. The sleeves look good but all three pistons were cracked between the ring grooves. Going to pull the crank and take it to the machine shop and see if it can be turned. If not then I'll have to have it built back up and turned down to standard or buy a new crank.I'm going to replace the rod where the bearing spun. Here are some pictures. 002.jpg005.jpg005.jpg011.jpg008.jpg004.jpg003.jpg
/ NEW PROJECT #18
Not necessary as long as you use assembly lube and fill the oil filter with oil. Decomp works just fine.
/ NEW PROJECT #19
Found this one on Ebay and had to go 180 miles one way to pick up. Here is a few better pictures. It seems that only the one rod bearing was the problem. The engine looks like 847hrs inside. everything looks new.It doesn't look like an engine that has been run without oil. Maybe some thing blocked the oil galley on that rod
What are the symptoms of a spun (seized ?) rod bearing. Is the crank hard to turn or is the entire engine acting like its seized?
Does it run but make a distinctive sound?
I just wanted to know for the next bargain tractor that comes along so I can diagnose it and decide whether its a deal or not. I passed up a nice Massey Ferguson already with a spun bearing at a huge discount. Practically giving it away.
/ NEW PROJECT #20
"What are the symptoms of a spun (seized ?) rod bearing. Is the crank hard to turn or is the entire engine acting like its seized?
Does it run but make a distinctive sound?"
Yes.
2014 Cadillac ATS Sedan (A59231)
2014 Cadillac ATS...
2006 International 7400 SFA 6x6 Bucket Truck (A60352)
2006 International...
2023 Kubota M7-174P (Premium) 4WD Tractor - 400 Hours (A61307)
2023 Kubota...
Toro hr:2213.5 (A56859)
Toro hr:2213.5...
1992 DFI PULL SPREADER (A57192)
1992 DFI PULL...
TORO GREENS MOWER (A56857)
TORO GREENS MOWER...
