Buying Advice Kubota B2920 - good tractor?
/ Kubota B2920 - good tractor? #1
Wvorange
Wylieville,wv
None at this time
Hello!New to the site. I'm looking at 2011 kubota b2920 HST with 140 hrs. Tractor has FEL, BH65 with thumb and 60" MMM. Price is $21,000. Like new condition. Would like to know if this is a fair price and if it is a good tractor. Any issues with this tractor? Going to check it out / hopefully buy next week. Thanks for the help!
/ Kubota B2920 - good tractor? #2
Tractors do not have titles like cars.
Make sure the seller can show you a bill-of-sale. If financed, make sure loan has been paid off so seller has clear title.
It the tractor was stolen, or if a loan is not paid off, you can lose it with no recourse.
Kubota makes excellent equipment. B2920 is a popular Kubota model.
$21,000 is somewhere around $5,000 less than new cost.
/ Kubota B2920 - good tractor? #3
/ Kubota B2920 - good tractor? #6
2920 is a great tractor. If it was in good shape and the price was fair, I'd have no issues. 140 hours is still like new.
/ Kubota B2920 - good tractor? #7
That is a fair to good price. And the B2920 is a great machine if properly sized for your tasks.
/ Kubota B2920 - good tractor? #8
B series do not have position control on the 3 point, instead it uses quarter inch valving. The vast majority of people seem to prefer position control, so that's something worth mentioning if you haven't already thought of it.
/ Kubota B2920 - good tractor? #9
Some B's have position control. Although the 23/26/2920 series does indeed have quarter inching. I have tractors that use both systems, and agree that I like position control better. But in the same breath, there is absolutely nothing wrong with quarter inching either.
Never used quarter inching valve. Is it a pain? Would it be a major factor not to get the tractor?
/ Kubota B2920 - good tractor? #11
I had no complaints about the quarter-incher. In fact, I have position control on my latest tractor and can't say it's any better for my uses.
/ Kubota B2920 - good tractor? #12
I don't think it is a pain. It works as well as position control, it just takes a little more getting used to. I don't think it is a detriment.
/ Kubota B2920 - good tractor? #13
I just bought a B2320 and I am still getting used to its quarter-inching valve. I prefer the position control on my utility tractor, but I don't find the quarter-inching valve to be a pain.
Steve
Thank you. Have anybody had any issues with the MMM adjustment knob not staying in the position? Cutting at 3" and it dropping down to 2"? I read past posts having this issue. Wasn't sure if kubota or a member found a fix?
/ Kubota B2920 - good tractor? #15
I don't have that problem. I have a 60" MMM on mine and it is a fantastic deck and a pleasure to mow with.
/ Kubota B2920 - good tractor? #16
Just from my experience
I had a B2920 w/ MMM and loader. It did leave a great cut. This tractor did have a valve issue with the loader but outside if that the tractor seemed indestructible. I literally a used the machine for nearly 300 hours and it begged for more. I used (cautiously) a 72" brush cutter to clear some of my land and it handled it. This isn't recommended but it worked. I had hooks welded on the bucket and used them all the time. I literally took my mower off and loader or weekly if not more.
What I did not like was the quarter inch valving. Truly a pain. I read on here and "the other site" that quarter inch valving won't drop. FALSE. For instance if you have a 3pt implement and leave it up over night, it will be on the ground come morning. If I do that with any 3pt on my grand with position control it will stay were ever I leave it.
Also, when tilling, brush cutting, etc I always have my hand on the three point for unlevel ground and I can lower or raise and know where it's supposed to be. 4 is always 4. A quarter inch valve was just a pain as you can raise and lower and you'll get used to it but definitely not as nice as position control.
With all they said, the b2920 is a beast of a tractor and I had great experiences with it.
/ Kubota B2920 - good tractor? #17
I have a very similar tractor b2620 with same mower loader and backhoe. Its a great machine. Quater inching is not a big deal for me.
/ Kubota B2920 - good tractor? #18
/ Kubota B2920 - good tractor? #19
/ Kubota B2920 - good tractor? #20
Close the flow-rate valve under the seat and it will not drop. When closed, it basically stops fluid from leaving the lift cylinder, so it can't bleed down.
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
New 20Ton Air/Hydraulic Bottle Jack (A65579)
New 20Ton...
Ford Jubilee Tractor (A65579)
Ford Jubilee...
2007 Allmand Max-Lite ML20 20KW Towable Light Tower (A64194)
2007 Allmand...
New/Unused Landhonor Power Rake (A65583)
New/Unused...
2016 Dodge Charger Sedan (A61574)
2016 Dodge Charger...
