Buying Advice Kubota B2920 - good tractor?
   / Kubota B2920 - good tractor? #11
I had no complaints about the quarter-incher. In fact, I have position control on my latest tractor and can't say it's any better for my uses.
   / Kubota B2920 - good tractor? #12
I don't think it is a pain. It works as well as position control, it just takes a little more getting used to. I don't think it is a detriment.
   / Kubota B2920 - good tractor? #13
Never used quarter inching valve. Is it a pain? Would it be a major factor not to get the tractor?
I just bought a B2320 and I am still getting used to its quarter-inching valve. I prefer the position control on my utility tractor, but I don't find the quarter-inching valve to be a pain.
Steve
Thank you. Have anybody had any issues with the MMM adjustment knob not staying in the position? Cutting at 3" and it dropping down to 2"? I read past posts having this issue. Wasn't sure if kubota or a member found a fix?
   / Kubota B2920 - good tractor? #15
I don't have that problem. I have a 60" MMM on mine and it is a fantastic deck and a pleasure to mow with.
   / Kubota B2920 - good tractor? #16
Just from my experience
I had a B2920 w/ MMM and loader. It did leave a great cut. This tractor did have a valve issue with the loader but outside if that the tractor seemed indestructible. I literally a used the machine for nearly 300 hours and it begged for more. I used (cautiously) a 72" brush cutter to clear some of my land and it handled it. This isn't recommended but it worked. I had hooks welded on the bucket and used them all the time. I literally took my mower off and loader or weekly if not more.
What I did not like was the quarter inch valving. Truly a pain. I read on here and "the other site" that quarter inch valving won't drop. FALSE. For instance if you have a 3pt implement and leave it up over night, it will be on the ground come morning. If I do that with any 3pt on my grand with position control it will stay were ever I leave it.
Also, when tilling, brush cutting, etc I always have my hand on the three point for unlevel ground and I can lower or raise and know where it's supposed to be. 4 is always 4. A quarter inch valve was just a pain as you can raise and lower and you'll get used to it but definitely not as nice as position control.
With all they said, the b2920 is a beast of a tractor and I had great experiences with it.
   / Kubota B2920 - good tractor? #17
I have a very similar tractor b2620 with same mower loader and backhoe. Its a great machine. Quater inching is not a big deal for me.
   / Kubota B2920 - good tractor? #18
   / Kubota B2920 - good tractor? #19
   / Kubota B2920 - good tractor? #20
Close the flow-rate valve under the seat and it will not drop. When closed, it basically stops fluid from leaving the lift cylinder, so it can't bleed down.
2007 Toyota Camry (A56859)
2007 Toyota Camry...
2010 Ford F-150 Pickup Truck (A55973)
2010 Ford F-150...
2018 Ford F-550 Altec AT48S 47ft Bucket Truck (A55973)
2018 Ford F-550...
CASE IH MX220 MAGNUM TRACTOR (A57192)
CASE IH MX220...
1449 (A57192)
1449 (A57192)
2014 Peterbilt 388 T/A Wet Kit Sleeper Cab Truck Tractor (A55973)
2014 Peterbilt 388...
