Possible 3ph problem
/ Possible 3ph problem #1
Bluest
Whitworth, Lancashire, UK
Yanmar F14D, DR Wheeled Trimmer
/ Possible 3ph problem #2
check this picture: Yanmar Tractor Parts: THREE POINT AND PTO
You will see the chains you need to pull the arms towards the tires. When you don't have any attachments on the arms just use a bungy cord to keep them pulled in.
/ Possible 3ph problem #3
Here is a scan out of an F24/FX24 manual showing the 3 point set up. Not knowing whether the F14/FX14 would be the same or not.
Hoye also shows this listed under the F14/FX14 (D) tractor? Yanmar Tractor Parts: LOWER LINK ASSEMBLY
/ Possible 3ph problem #4
Dang, was just going to post that. someone has jury-rigged the 3ph system.
Thanks for your help. When you say it's jury-rigged, what exactly is wrong? Is it the lower link assembly?
Mine looks different to the one picture above, in that the rod that the link arms mount onto seems to allow a lot of lateral movement of the arms. What I mean is that they can slide a long way left and right. I take it that the arms should be constrained closer to the centre line that the outside? If thats the case I could drill the rod and put pins in.
I'm still not at all sure where the stabiliser chains would affix at the tractor end though. Can anyone help with that?
/ Possible 3ph problem #7
Sorta what you need. However, I can't tell enough about the home made lower link assembly to know whether it is solidly anchored and strong enough. Also, you will need a place to fasten the linkage stabilisers. Your pins stick way out to far for my liking.
That stabiliser I linked to, I think, is designed to fit onto the ends of the very long lower pins. I don't think the lower link is home made, there are a few small tractors for sale on Ebay UK that have a similar lower link. See what you think of this one... Compact Tractor Yanmar | eBay
Mine isn't identical to that, so I'll take a clearer photo and post it shortly.
OK, here's some pictures of the lower link from below. Suitable or not?
/ Possible 3ph problem #10
I hate to be negative but just two bolts holding that rod across there just doesn't look right to me. I think I have jerked on my 3 point hard enough to pull one of those bolts out. Just an opinion. Maybe factory.
The lower lift arms on the ebay tractor you attached look awfully close together. I don't see how the stabilizers are able to spread them. It also looks line the lower link is bolted underneath the tractor similiar to the one shown on Hoye.
I know I am not much help but just giving my honest opinion. There won't be a charge. :D
I think I'm inclined to agree with you winston1. Those two brackets look exactly like the type that are supposed to anchor the stabiliser chains, not support the whole linkage. Plus he way they are arranged puts them in bending. Looks like I might need to spend some money with Hoye! I just wish carriage wasn't so high.
/ Possible 3ph problem #12
Bluest, I see you are in UK so the Hoye kit might be expensive. But I think you need that kit or whatever you can find locally designed equally strong. My first YM186D (similar hp to your F14D) has been repaired at that point. There are welds re-attaching the lowest part which holds the cross-rod, to a vertical plate that covers most of lower back of the transmission.This vertical plate is also anchored to the towbar receptacle below the axle to share some of the stresses. This assembly that ripped apart from the vertical plate would have been far stronger than those two ears holding your cross-rod - and it got torn off regardless.
[edit - later - see post #14 below].
I suggest study what Yanmar intended at that location and locate the real Yanmar parts, or at least the equivalent of the Hoye kit. I don't think the tractor is complete and ready for hard work as it exists presently.
And Welcome!
/ Possible 3ph problem #14
Here's a photo of the 3-point attachment on my first YM186D.
There is a tube that the horizontal rod goes through. Repair welds re-attached this tube to a bracket on the back of the transmission.
The stress of pulling an implement is applied to 'ears' near the ends of the horizontal rod. These 'ears' go forward and are bolted to the sides of the transmission. I surmise these bolts fell out at one time causing the damage repaired by the welds.
I think you need to buy the Hoye component that Winston referenced in Post #3. (or similar that fits your model).
I'll repeat the Hoye photo below my photo. On this version the horizontal tube appears to be part of the drawbar socket assembly under the transmission. Like my version, it has 'ears' near the end of the rod which transfer implement-pull stress to the sides of the transmission.
All this info is great, especially the photogrpahs and last few posts. As far as I can tell there are is noone selling new parts for grey market Yanmars in the UK. I have found one breaker, but no "F" models in at the minute. I'm going to contact them in case than have one from another model that's either the same, or can be adapted. If that fails, my Dad is an experienced fabricator, so I'm going to get him to take a look and see if he can come up with something based on the info you've all helped me with. In fact, we might use this as a project to finally teach me to weld...
Ordering that heavy part from Hoye is going to be a last resort, the carriage and customs charges are a killer. To give you and idea, I ordered a few filters and a manual at Hoye's very reasonable prices but by the time I've paid the customs ransome I'll probably be over the $200 mark! That link bracket will easily end up over $300.
Ok, bit of an update. It turns out there is a good reason why I'm missing the lower link assembly. The four bolt holes, under the transmission, that the assembly should bolt up to are completely stripped.
The UK Yanmar breaker I contacted doesn't have an assembly for sale either.
But fear not, I have a cunning plan. I should be able to open the stripped bolt holes out to a larger size and tap a new thread. I also acquired a good sized piece of 10mm plate for free, courtesy of a very generous local fabrication firm. I've designed a very simple assembly that I'll get mynDad to weld up next week.
I'll post some pics and keep the thread updated as things come together.
Thought I'd try to keep this thread updated as I don't think it's uncommon for these small Japanese tractors to turn up without a 3ph. I think that because a lot of them were used with rotovators that mount directly.
Firstly, if you are in US, don't bother with this, just buy a new lower link assembly from Hoye. It's well priced, and a simple fit. But I'm in the Uk and no one over here sells the part. I could buy from Hoye too, but the post and customs charges make it a major expense.
Secondly, I am not an experienced fabricator and have limited tools so I've had to do the best with what I had. I'm sure many of you could come up with far more elegant solutions, but I ain't that good yet!
Here's a pic of the gathered materials I thought I'd need, along with my home made super simple lower link assembly.
As you can see, the assembly is simply a bit of 10mm mild steel plate, cut into a trapezoidal shape. It has four clearance holes drilled to take M12 bolts. This allows the assembly to bolt to the four threaded holes on the underside of the gearbox casing. This is the same place the real part would attach.
Cylindrical lug things are to take the rod that supports the lower link arm. They were already on my tractor and I'm reusing them. They are screwed to the plate in the pics, but will be welded once I'm happy. They are actually the lugs from the end of some 3ph stabiliser chains.
I also decided to add an old lifting lug which might be handy if I need to drag anything.
The helicoil thread repair kit is there because all four bolt holes on the bottom of the gearbox were stripped. If you put a bolt in, it would just fall out! if you've never used are thread repair kit, it was a lot easier than I expected and they claim the repair is stronger than the original. Here's a pic mid repair...
Once the threads were repaired I bolted it all up for a test fit...
And from underneath...
All that's left now is to have welding lesson ff my Dad and fuse those lugs on in the process. I can then give it a coat of paint, bolt it back on and see if rips apart the forst time I mow...
/ Possible 3ph problem #18
Hoye lists 2 hinge plates that work with that lower link arm assembly that support the ends of the shaft, but no pic. If you email Aaron I'm sure he would send you a pic from the parts book showing what they look like and how they fit.
/ Possible 3ph problem #19
excellent repair !!!!! A job well done !!:thumbsup:
/ Possible 3ph problem #20
Looks good!
I think I would also bolt it into the two bolt holes on the back side below the PTO. Two short piece of angle - one for each bolt to go through - welded to your plate then bolted in there would eliminate downward stress on the holes you repaired beneath the transmission. Something must have tugged on those real hard. I think sharing that stress as many places as possible is still a good idea. Also 'ears' forward from near the ends of the rod seems like a good idea if there is anything on the side of the transmission to bolt them to. My concern is based on the repair welds I pictured in post#14 above [small picture]. There must be some substantial stresses in that area to need a repair like that.
Oxy-acetylene Torch and Regulator Rig (A61307)
Oxy-acetylene...
2024 JCB 35Z-1 (A60462)
2024 JCB 35Z-1...
SKID STEER ATTACHMENT PACKER (A58214)
SKID STEER...
Gas Oven (A60352)
Gas Oven (A60352)
John Deere 4044M (A60462)
John Deere 4044M...
2014 TEREX USA LLC LIGHT TOWER (A60736)
2014 TEREX USA LLC...
