Home-made attachments...
/ Home-made attachments... #221
My dad built a few things for this 455, first is a little grader, originally it had a manual angle blade, but he modified it a few weeks ago to use the front mount JD quick attach. So now hes got hydraulic angle as well. Second is a 3pt hitch potato hiller.
/ Home-made attachments... #222
Very nice.
Aaron Z
/ Home-made attachments... #223
Very nice.
Aaron Z
/ Home-made attachments... #224
Cool looking grader. Is he happy with how it works. Looks like the blade may be a bit too close to the rear wheels.
/ Home-made attachments... #225
He loved it before the change to the jd blade and quick attach. He took it up and down the driveway once after the change, found out the pivot pin/bushing are worn out a bit far so he gets washboard easier. We'll get rid of the play at the pivot and try again.
/ Home-made attachments... #226
Good eye. It's welded on in the picture, but I did that just as a mock-up. The finished design (pix coming soon) uses two 5/8- bolts on each side plus four 1/2" bolts across the face to attach the bucket to the plow.
I must be missing something! What keeps the plow attached to the bucket?
Or is it welded as one.
/ Home-made attachments... #227
A bit embarrest to show my meegre efforts after seeing some of the work in this thread but here goes.
Once i bought my tractor and restored it i had no implements, cashflow being low as i spent a bit more than expected on the restore i gathered up some leftovers and built a carry all box for the rear. As you can see its got round and square stock, anything that could be used was.
Having a small road trailer for my car and nothing for the tractor i made a 3 point attachment with ball hitch
You may wonder what the chains are for, the lift arms on lots of these small tractors are actuated by a simple cylinder they lift but only lower by whatever weight is on them and can easily be lifted(even by hand) by the trailer should the weight go to the back for any reason, the chains stop this happening and makes the job safer.
regards to all and thanks for postin, i have some new ideas now ;)
Derek
/ Home-made attachments... #228
As promised, here are a few pix of the finished plow/bucket.
attachment.php
attachment.php
attachment.php
attachment.php
/ Home-made attachments... #229
@Derek - Carryall and hitch look good to me. That's a very interesting looking tractor.
/ Home-made attachments... #230
A bit embarrest to show my meegre efforts after seeing some of the work in this thread but here....
Text redacted for brevity....
Derek
Hi Derek,
Nice thoughtful work. I may have to copy some of your concept.
Thanks!
Thomas
/ Home-made attachments... #233
I made a brush fork for the Front End Loader of my (sold) BX-24 tractor, it became my favorite attachment.
Then I made 5 mini-stick rakes that pin onto the tines of the brush fork.
374056d1399422460-home-made-attachments-forkrake_pile-jpg
Then I got a mini-excavator with a thumb.
Recently started adapting the mini-stick-rakes to the excavator. Not tested yet but hoping be able to rake up sticks like its nobody's business! ….and drop them on a trailer…..then tow the trailer (with excavator) to the burn pile……and toss it on the burnpile with the X! Fun stuff?
374060d1399422827-home-made-attachments-kx41_stickrake__testing_open-jpg
374059d1399422794-home-made-attachments-kx41_stickrake__testing_closed-jpg
/ Home-made attachments... #236
That's one industrial strength back scratcher, Sodo!
All kidding aside - a very clever idea, well executed.
I bet it works great.
/ Home-made attachments... #237
innovation is birthed out of necessity.
/ Home-made attachments... #238
2005 Kobelco 135SR Hydraulic Excavator (A61567)
2005 Kobelco 135SR...
2019 Kubota MX5800 HST Tractor (A61166)
2019 Kubota MX5800...
2008 New Holland T2420 (A60462)
2008 New Holland...
UNUSED JCT 84" HYD DOZER BLADE (A62131)
UNUSED JCT 84" HYD...
2001 CHEVROLET C8500 FLATBED TRUCK (A62130)
2001 CHEVROLET...
2011 Mack GU713 Granite Dump Truck, VIN # 1M2AX07YXBM010053 (A61165)
2011 Mack GU713...
