Good Brake controller
/ Good Brake controller #1
sacmarata
KENTUCKY
Branson 6530C, Yanmar LX490, Forson Dexta
In addition to hauling the Dexta and Yanmar, I just bought a 31' travel trailer and have decided to upgrade my brake controllers in my trucks. I'm figuring my max gross will be somewhere around 10k. I always heard MAXBRAKE was the best but just noticed they must be out of business.
Any suggestions for electric brake controller?
/ Good Brake controller #2
I think most will agree for the simple electric plug in type, it is sure hard to beat the Tekonsha P2 or P3. I have both. Both work well (and the same) but I like features and the screen built into the P3.
/ Good Brake controller #3
Hayes is made in the US of A. I'm happy with mine. It's not the priciest one they make, not the cheapest either. Think I paid about $90-100. Worth every penny.
/ Good Brake controller #4
I love my P3
I have 2 other types. a drawtight activator 2 as well as a cheaper hoppy.
I must say. they all work.. the hoppy is the most vanilla. I'd say for 7k loads.. .. ANY e-brake controller will be fone. start getting bigger.. and then why not have the prodigy.....
/ Good Brake controller #5
I'd second or third the Tekonsha. I have the Primus with fewer bells and whistles than the P2 or P3, but it does all I want - with a built in accelerometer, any angle mounting, and adjustable boost settings, I think it is a better value.
/ Good Brake controller #6
+1 on the P3. About 15 min install time with prewired harness.
/ Good Brake controller #7
P3 is bullet proof but a pressure driven one like the Max Brake that is now out of business is 3 times better.
What is your tow vehicle? If it's a late model Ford or GM you can get the factory one that will blow any plug and play unit out of the water.
Chris
/ Good Brake controller #8
I bought a Tekonsha prodigy years ago and it seems to me it was the best I could find. I did my homework and decided the difference in price between that one and the cheapest was negligible when you consder the cost of a malfunction.
I would recomend this unit as it has been 100% reliable, but I would check and see if there is any new technology that may provide more reliable results.
I'm guessing here but I think hydraulc brakes, properly maintained, are the best way to go. If I was making a living with a trailer, that's what I would have.
Chris
'94 Dodge 2500 Cummins
2002 Chevy 1500HD 6.0 Gas
Didn't know about factory GM and Ford controllers???? hmmmm
/ Good Brake controller #10
06 and newer Ford's and 08 and newer GM'S have them now.
Chris
2019 GALYEAN...
Ratchet Straps (A61569)
Ratchet Straps...
New/Unused Top Cat Quick Attach Stump Grinder (A61166)
New/Unused Top Cat...
2010 Sterling A9500 T/A Day Cab Truck Tractor (A61568)
2010 Sterling...
New/Unused ATS 40 Gallon Two Stage Air Compressor (A61166)
New/Unused ATS 40...
20FT X 30FT ALL STEEL CARPORT (A58214)
20FT X 30FT ALL...
