SPYDERLK
Super Star Member
- Joined
- Feb 28, 2006
- Messages
- 12,577
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
Computer graphics are too much of a PITA so that wont happen. The info is all there to experience when you use dueling levers of different length. Forget rotation around the axle. Driving force is at the ground. The tip lever is the wheel radius. The anti tip lever is the distance from the axle down to the pull point. When the anti tip lever is as long or longer than the tip lever no amt of traction will tip the tractor in a smooth pull. The tractor will stall or break with hardly a twitch.Really? Maybe use a teeter toter as an example. Just change the weight of the Totters. Same as two spaners.
How about a static force diagram?
larry
