Hill Climbing Primer
/ Hill Climbing Primer #61
What about making two "carts" that would support each end of the log. Use the FEL to lift each end into the cart and chain it down. Then rig up a normal wagon tow bar to the one end and drag it up the hill like you would a regular wagon?
Basically he would need a few pipes to act as axles. Some sort of platform and a couple of tires.
The logs should be thick enough to stay straight themselves. The larger wheel size will allow it to get over the humps, ruts, etc. And if the tractor can't handle the weight, he could probably borrow/rent a bigger tractor for a few hours to get the big boys out.
Or am I totally thinking wrong?
/ Hill Climbing Primer #62
Basically the same concept as the log arch I mentioned. And with some cable and a snatch block he could go back up to the flat area and pull with complete safety. I don't think there is any question his tractor would pull them up, especially if they are on wheels.
/ Hill Climbing Primer #63
Back Flips:
Enough torque, enough traction and the tractor will rotate around the rear axle. Don't mater how low you hitch.:thumbsup:
Yes it does. If you hitch rigid below ground the more traction you have the flatter the front tires get. ... Well, I guess that is rotating [forward] around the rear axle. :wink:
/ Hill Climbing Primer #64
Back Flips:
You will run out of traction first in dirt.
/ Hill Climbing Primer #65
Well sure but you have to be pulling backwards in reverse!:thumbsup:
/ Hill Climbing Primer #66
...No. With a pull/push point below ground in reverse the tractor would tend to backtip.
/ Hill Climbing Primer #67
One set of wheels just behind the balance point and use log as a long hitch. Turns it into a trailer!
/ Hill Climbing Primer #69
Note the word " enough ".
Lots of low hitch tractor scenarios will provide enough traction. Lots of times the front of the tractor may be off the ground when starting a heavy load. Tie an 8N to a big tree and have at it.:D
/ Hill Climbing Primer #71
You can do it with 2 wrenches of different length trying to turn something opposite one another and prove it to yourself. Different lever lengths is what it comes down to.
larry
/ Hill Climbing Primer #72
larry
You forgot the gears and mounted prime mover!
/ Hill Climbing Primer #73
I grew up on small Ford tractors, 8N included. Dad always said the pulling power of the 8N is unappreciated if the front tires are touching the ground. I was taught and proficiently learned the art of balance using the 3pt lever starting at the age of 7.
/ Hill Climbing Primer #74
/ Hill Climbing Primer #75
Irrelevant to the result if you set the experimental static situation up correctly.
/ Hill Climbing Primer #76
Yep. The rear axle pinion gear is trying to climb up the front of the rear axle ring gear. Same thing happens in any rear wheel driven vehicle when engine power is applied. That's why Dragsters use wheelie bars even though they have no load hitched to the rear of the car.
http://www.farmsafe.org.au/resources/document/24-10-13_01_36_Safe_Tractor_Operation_Guide.pdf
The last location has information and pictures!:thumbsup:
Compare and contrast highly accelerative conditions with a steady state pull. Weight distribution considerations will receive extra credit.
/ Hill Climbing Primer #77
Every ounce not supported on a driven wheel is a loss. Approx 1:1 or more with AGs.
/ Hill Climbing Primer #78
I don't think this is right. I have pulled on a stump with my drawbar, and my tractor ground to a halt (wheels spinning), but the front end didn't come up at all.
Just for fun, I made this:
As I said earlier, this is not an accurate repro of what happens in a pull. It is because the driving force is supplied from a reference frame independent of the tractor. Your experimenteffectively has you levering forward on the axle.
You can get an accurate depiction of what really happens by locking those rears and pulling back on the tractor from different heights while touching the tractor in NO other way. Somehow jam the tires against the body or fenders. See if you can get a few pounds directly over or just slightly ahead of the rear axle to assure enuf traction. Height of that weight is not important to a steady state level pull.
larry
/ Hill Climbing Primer #79
You finally said something I understand. You guys are talking so far above me..... I'm not worthy!!!! :)
/ Hill Climbing Primer #80
Really? Maybe use a teeter toter as an example. Just change the weight of the Totters. Same as two spaners.:)
How about a static force diagram?
2018 Ford Escape SE SUV (A61574)
2018 Ford Escape...
2016 JCB 507-42 (A64126)
2016 JCB 507-42...
CONEX BOX (A65643)
CONEX BOX (A65643)
John Deere 568 Mega Wide Plus (A60462)
John Deere 568...
2017 CHEVROLET SILVERADO 2500HD (A65643)
2017 CHEVROLET...
John Deere 5420 Tractor with Quicke Loader (A64047)
John Deere 5420...
