Hill Climbing Primer
/ Hill Climbing Primer #41
I may be misunderstanding your example, in which case I apologize, but I don't think this is correct. >>If you are pulling from below the axle, then the torque will tend to rotate the front end downwards into the ground. If you are pulling from dead-center on the axle, there will be no torque.<< And if you are pulling from above the axle, the torque will tend to rotate the front end upwards.
I think what you are saying is that the lift arms attach above the axle, so if you are pulling from the lift arms, there will always be torque to raise the front end--but to me that seems like an argument for pulling from the drawbar, not the lift arms.
No. Any pull point above the ground [where the tractor applies force] has backtip potential --- increasing with H.
larry
/ Hill Climbing Primer #42
You are pulling from the H of the ball ends if the hydraulics is holding them above the attachment point of the arms on the tractor for the reason I said earlier. If the ball ends are, instead, lo you are pulling from the arm attach point on the tractor, and since that point will not move downward as the tractor tips the tip does not self damp. The operator has less recovery margin. BabyGrands method has all the advantages you cite as well as the added safety of a drawbar pull.
larry
I think we are saying the same thing. I am saying the force to pull and lift the log can be devided into two components. One horizontal (the pulling force) at the lift arm attachment point to the tractor and one vertical (the weight) at the lift arm ball end. Those two forces can be combined mathamatically into one force which would be above the lift arm tractor point. Your force.
If the log is raised off the ground, supported by the liftarms, and the tractor rolls back so the log suddenly rests on the ground the whole force picture has to change because the vertical weight component of force on the tractor suddenly dissappears. The front end gets heavier. I don't think you can remove a force and have nothing happen.
Oh well that is the way I see it anyway.
/ Hill Climbing Primer #43
Please read my prior post. #31, I believe. The site works so poorly that you cant multi quote - among other features that cant be relied on.
The pull point is not the attachment point of the arms on the tractor. Instead, when the ball ends are held above the attach point the effective pullpoint is at the height of the ball ends. Otherwise you are right. Take a look at the link post 35 with BabyGrands attach method and note the difference in how the forces resolve.
larry
/ Hill Climbing Primer #44
For the logs that will be firewood, I would cut into firewood at the landing and carry buckets of firewood up the hill. This will also give you a chance to "find the limits" of your machine.
For the rest, you may not need a winch. If you can pull in a straight line from the top of the hill, just use a long cable and snatch block if you need it. From the pics it looks possible, have to be there and see it to know though.
I think you will need to experiment quite a lot with different techniques to get this to work, your tractor is on the small side to get this done. But it is certainly possible and probably doable.
Carrying long heavy logs crossways uphill with a small tractor... well I just wouldn't try that. Too many ways to get in trouble. Pull 'em - snatch block, double snatch block, winch, whatever it takes. This is going to be slow work whichever way you do it, might as well avoid the rodeos!
Good luck!
/ Hill Climbing Primer #45
I don't think this is right. I have pulled on a stump with my drawbar, and my tractor ground to a halt (wheels spinning), but the front end didn't come up at all.
Just for fun, I made this:
/ Hill Climbing Primer #46
Couldnt watch it. Says private. I suspect you just dont have enuf rear traction to lift the front using a lever the H of your drawbar. A FEL often prevents that due to its front weight bias..
/ Hill Climbing Primer #47
Sorry--I got the settings wrong. It's public now. The traction issue may be true for my full-size tractor, but for the little model tractor in my video, traction is basically infinite relative to the weight of the front end.
/ Hill Climbing Primer #48
I suggest that the OP take three trips up and down the land with only the tractor and no load. If the travel is made without concern, on the fourth trip, add a small log and see how it goes.
Weight on the loader takes weight off the rear wheels. Might just spin to a halt.
A logging winch seems like such a good investment.......
/ Hill Climbing Primer #49
Hmm, I seem to be able to multi quote...:cool:
/ Hill Climbing Primer #50
The axle has to apply the torque. You are essentially pushing the model at the H of its axle. In the normal situation the wheel does push the axle, but by tractor based torque acting thru a lever that is the wheels radius, and pushing backward on the earth. Tip takes place at the tire to earth interface. Resistance to the tractors motion at any point above earth applies a backtip torque thru a lever as long as the height of that point. Enuf traction and a tractor will tip at any lever length greater than zero. During backtip a fixed drawbar of decent length moves enuf earthward quickly, thereby shortening the lever quickly enuf to exceed traction and arrest the tip in most cases.
larry
/ Hill Climbing Primer #51
I think what you're saying is that the tractor tips backwards, not because it's trying to "drive out from under" the attachment point, but because the axle must keep turning, and if the wheel can't go clockwise, the tractor is going to go counter-clockwise. Is that right?
/ Hill Climbing Primer #52
That is the net effect. ... But in essence it is the two levers of different length described that are acted on by the same amount of force that favors a tip.
... I will have to continue this evening.
larry
/ Hill Climbing Primer #53
larry
I have thought and thought about what you were trying to tell me and have finally grasped your message. I knew the front end lightened when using the lift arms as a pulling point. I thought this was solely from the weight of the log. What I didn't comprehend was that some of this front end lightening that I feel is due to the horizontal pull acting on the angled lift arms thru the 3ph components as you said. Now that I see it and the mechanics of it are so basic and obvious I am embarrassed to have not realized this before and even more embarassed it took me so long to see it after you told me.
So I was wrong in stating the horizontal pull force is always at the lift arm connection point to the tractor below the axle. I agree that it moves upwards as the lift arm raises above horizontal.
Thank you for your patience. And I apologize for spouting misinformation on this great forum.
I can now see the merit of running a chain from the raised log to the draw bar to keep the pull force at a low point. What a great idea.
gg
/ Hill Climbing Primer #54
Back Flips:
Enough torque, enough traction and the tractor will rotate around the rear axle. Don't mater how low you hitch.:thumbsup:
/ Hill Climbing Primer #55
I am embarrassed to have not realized this before and even more embarrassed it took me so long to see it after you told me.
gg
Better to be embarrassed than dead. A lot of good people have ended up dead from tractor roll overs backwards.
Visualizing Dragsters / Funny Cars has helped me grasp the concept.
/ Hill Climbing Primer #58
The trick we used back before 3 point hitches was to use an extra long draw bar. As the tractor front end would rise the drawbar went toward the ground. People with short draw bars saw the front end come higher off the ground in a hard pull. Pulling at ground level there is no tipping force except for whatever is generated when the rear wheel climbs out of a hole. Tractors had to be a lot bigger to drag logs with out being able to pull up high lifting the logs off the ground and adding weight to tires but tipping was not much to watch out for other than what you would regardless of load.
Just what was said about funny cars etc.
/ Hill Climbing Primer #59
Back Flips:Enough torque, enough traction and the tractor will rotate around the rear axle. Don't mater how low you hitch.:thumbsup:
Yep. The rear axle pinion gear is trying to climb up the front of the rear axle ring gear. Same thing happens in any rear wheel driven vehicle when engine power is applied. That's why Dragsters use wheelie bars even though they have no load hitched to the rear of the car.
/ Hill Climbing Primer #60
gg
... No need. I really appreciate you persisting in analytic mode. These things only become obvious when all the almost correct diversions can be appropriately sorted. This perspective is not easy to see or to convey. I have a real hard time eliminating all the stinkin thinkin pitfalls as I try to turn the concepts every which way in my head.
Pardon me for addressing one of your statements that I think you are correct in, but leaves room for an interpretation that would be an "almost correct" diversion. >> The pullpoint is moved upward to the endballs when the arms are held up above the horizontal. If the tractor then backtips there will come a point when the arms are horizontal. At, and beyond that tip angle the pullpoint moves to the arm/tractor ball articulation attachment point [Which unfortunately for this issue has a location so near the axle that it stays at constant H during tip.].Effective pullpoint stays there after the arms become horizontal during tip and while they float to their max H. Here they encounter resistance forcing the endballs down below horizontal. THEN the pullpoint reverts to the ball ends.Tip is now becoming less favored, but it is already tipped a lot, perhaps beyond balance ... and even if not, the loaded components are not designed for loads that push on them and will probably fail as the ball ends near ground, and allow tipover.
As unlikely as it is to get a tractor into this situation, certain changes from what the operator is used to and has come to expect can increase traction or influence another factor so much that all previous "safe" use is moot. Fitting chains to industrials would likely be such a critical change. To deal with the significantly more aggressive pull in a manner favoring maximum performance with safety the physics of the tractor system must be applied in as wholly complimentary a fashion as possible. The designer has provided features that can let you do this conveniently. The configuration challenge is left to you.
.... Baby Grands configuration affords access to every advantage; =] You can lift as much of the load weight as you want or can with the hydraulics, =]You can tie the load to the fixed drawbar with a little slack, =] as you move forward the load hangs back and, if it wasnt clear of the ground to start, more lift force acrues increasing traction, =]you can tune the setup by varying the amt of lift, amt of slack in the forward tie, and height and length of the drawbar. ... You can tailor it as far as the point where you are supporting as much as the big end portion of the load and all the tractor on the rear wheels and be in a stable safe pull with the front wheels hovering at the ground. Any further backtip is automatically stabilized in 2 ways; 1]reduction of weight supported as you have said, and, 2] dipping of the drawbar end causing a lower pull point. Seems to me this might be the absolute limit to the pull available and as safe as you can make it.
Could be fun!
larry
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A63689)
PENDING SELLER...
2014 TIGERCAT 234 - 45' LOG LOADER (A64276)
2014 TIGERCAT 234...
7888SFL (A61567)
7888SFL (A61567)
2014 Nissan Sentra Sedan (A61574)
2014 Nissan Sentra...
2012 Ford F-350 Western Mule 1,500 LB Crane Service Truck (A61573)
2012 Ford F-350...
2012 Peterbilt 386 T/A Day Cab Truck Tractor (A60352)
2012 Peterbilt 386...
