Everything Attachments Rotary Cutter....FIRST LOOK!!!
   / Everything Attachments Rotary Cutter....FIRST LOOK!!! #1
EverythingAttachments
Elite Member
Newton NC
Which One do you want to know about?
After several requests for an EA Cutter, the first one is nearing completion. Designed for small compact/subcompact tractors, it features a 44" cutting width and limited Category 1 hitch.
We have all the necessary components in house and are currently designing models up to a 72" HD Cutter.
Here's a peek:
Travis
   / Everything Attachments Rotary Cutter....FIRST LOOK!!! #2
Here's a peek:
Travis
Looks like what I need for my B7610.
   / Everything Attachments Rotary Cutter....FIRST LOOK!!! #3
Quality workmanship as always I see! What kind of tail wheel setup? A washer and pin or a heavy duty collar? Are you going to beef up the larger models with cross bracing?
Thanks! I think the smaller models will have a washer and pin holding on a 15" laminated tailwheel, but i'm not sure about the larger models.
Knowing Ted, I am sure the larger HD models will be beefed up considerably!!
Travis
Our first rotary cutter is ready for the photo shoot and video now. Here are some pics from my cell phone.
Travis
IMG_20140210_085009_937.jpgIMG_20140210_085102_092.jpgIMG_20140210_085335_100.jpgIMG_20140210_085341_185.jpg
The pictured cutter is the first one that we've cut/welded together, so there are some small changes to be made.
The front shield will be cut and/or bent some(and probably removed by customers for full height cutting) and the rear shield also needs to be tweaked.
Our first rotary cutter will be going to "Humpy" Wheeler, the past President & GM of NASCAR's Charlotte Motor Speedway and the most decorated promoter in NASCAR!
   / Everything Attachments Rotary Cutter....FIRST LOOK!!! #8
That shield wouldn't last too long around here, that's for sure. I like chains, but it's a dirty deal on an OROPS tractor. It sure would be nice if someone came up with an easily changed out chain or rubber shield option that could be ordered either way...hint, hint.
   / Everything Attachments Rotary Cutter....FIRST LOOK!!! #9
TRAVIS: Where will gear boxes be sourced, U.S.A. or imported? What about blades?
   / Everything Attachments Rotary Cutter....FIRST LOOK!!! #10
A piece of flat stock and a piece of rubber on that mower would probbaly fit the bill...
Aaron Z
2014 Ford Taurus AWD Sedan (A54815)
2014 Ford Taurus...
2016 Ford Explorer AWD SUV (A55758)
2016 Ford Explorer...
Red Military Truck (A53422)
Red Military Truck...
Wooden Rack Hay Wagon (A50775)
Wooden Rack Hay...
2018 Volvo MCT 110C (A47477)
2018 Volvo MCT...
Survey Kit (A53316)
Survey Kit (A53316)
