Everything Attachments Rotary Cutter....FIRST LOOK!!!
   / Everything Attachments Rotary Cutter....FIRST LOOK!!! #11
The tail wheel appears to have a bolt/nut in the pin hole that will round off quickly during use. Suggest you replace the bolt/nut with a hitch pin or similar that will ride smoothly on the washer.
Most mfgs use a cotter pin or lynch pin.
I'll show all the comments/questions to Ted when he rolls thru and get some replies for you. They made the video this morning, so i'll post that when it's complete.
Travis
   / Everything Attachments Rotary Cutter....FIRST LOOK!!! #13
Travis
Personally I would rather have the bolt, much less likely to loose it than a lynch pin especially if backing into weeds and vines. Since the bolt is only subject to wear when the bush hog is raised so the tail wheel is off the ground, there would be very little wear on the bolt head and since the only time you ever need to remove the bolt is to replace the tail wheel, why worry about the head rounding off, just cut it with a grinder and put in a new one with the new tail wheel.
   / Everything Attachments Rotary Cutter....FIRST LOOK!!! #14
   / Everything Attachments Rotary Cutter....FIRST LOOK!!! #15
I've been using a #12 cotter pin in my tail wheel for the past year+ and it seems to hold real well. Had to hammer the pin into the hole but the arc in the cotter pin curved section grips the side of the tail wheel post very tightly and provides more flat surface for the washer to ride against. I don't cut a lot of weeds/vines or heavy growth but it would take quite a tug to pull the cotter pin.
TRAVIS: Where will gear boxes be sourced, U.S.A. or imported? What about blades?
Unfortunately, the gear boxes are from china, the same source that every other manufacturer uses. It may be possible to get a domestic gearbox, but the price would be way out of line.
Ted wasn't sure about the blades, but Nate told me yesterday that they had Italy on them....I'll verify with my own eyes when i get a chance.
Travis
   / Everything Attachments Rotary Cutter....FIRST LOOK!!! #17
Cold rolled steel pin is in mine and holds just fine.
   / Everything Attachments Rotary Cutter....FIRST LOOK!!! #19
Pretty nice.
I think the corners of the rear guard should be chamfered to avoid catching things, or just make the depth of the guard match the adjoining side.
Pretty nice.
Thanks!
The cutter in the photos and in the video is the first prototype that we've made. The guard and a few other things will be changed before we ship any out.
Ted talks about the changes that will be made in the video.
Travis
2014 Chevrolet Silverado 1500 Crew Cab 4X4 Pickup Truck (A55788)
2014 Chevrolet...
2021 FORD RANGER XL CREW CAB TRUCK (A51406)
2021 FORD RANGER...
2015 FREIGHTLINER M2 TANDEM AXLE 24FT FLATBED (A56129)
2015 FREIGHTLINER...
UNUSED JCT 84" HYD DOZER BLADE (A54757)
UNUSED JCT 84" HYD...
(APPROX 23) 2" X 3" X 162" TUBING (A54756)
(APPROX 23) 2" X...
2025 60 Gallon Poly Diesel Tank w/ 12v Pump (A55787)
2025 60 Gallon...
