Buying Advice mahindra 3016 versus 40hp
   / mahindra 3016 versus 40hp #1
ziggyport2001
Malone, NY
mahindra 3016
I am presently researching tractors and am pretty confident in buying the 3016. However the dealer was trying to suggest buying a 40 hp in case I might need the higher pto hp later. I have a 24 acre lot where I will be doing some tree clearing and landscaping. I would appreciate some advice on how large a tractor I might need. Thank you.
   / mahindra 3016 versus 40hp #2
Welcome to the site:welcome: I would choose the 40 HP .. Best I recall ,It's the same (physical) size tractor with more HP. With a 30 HP tractor You will have roughly 25 PTO HP. Next tractor I buy will be at least 45 HP
   / mahindra 3016 versus 40hp #3
Welcome from St.Lawrence Co.;I also would go for the 40 HP.
   / mahindra 3016 versus 40hp #4
A 30hp Mahindra will do the work of a 50hp trator in any other brand
   / mahindra 3016 versus 40hp #5
   / mahindra 3016 versus 40hp #6
While more horsepower is always welcome and I tend to agree with your dealer about jumping up in horsepower. But, another thought on how you add that extra horsepower. Consider a second, older and larger tractor in the future if you need horsepower. I can assure you a second tractor no matter the size will prove handy.
   / mahindra 3016 versus 40hp #7
Please give examples and explain.
I agree, I've got to hear this 1. A 30 HP with a 25 HP PTO will pull a 5 ft rotary cutter t. A 50 HP tractor with a 45 HP PTO will pull a 9 FT cutter using the 5 ft per HP rule
Thank you for your responses. I don't believe any 30 hp tractor can beat a 50 hp tractor.
   / mahindra 3016 versus 40hp #9
Mahindras use the 2.5 ft per HP rule
   / mahindra 3016 versus 40hp #10
WHAT?
Freightliner Tender Truck - Adams Tender (A56435)
Freightliner...
2009 Dodge Ram 3500 Flatbed Truck with Liftgate (A55973)
2009 Dodge Ram...
2022 Wacker Neuson PDT2A 2in Portable Diaphragm Pump (A55851)
2022 Wacker Neuson...
HYDRAULIC AUGER FOR MINI EXCAVATOR (A58214)
HYDRAULIC AUGER...
2018 SkyJack SJ1056TH 10,000LB 4x4 Rough Terrain Telehandler (A55973)
2018 SkyJack...
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
