Buying Advice mahindra 3016 versus 40hp
   / mahindra 3016 versus 40hp #1
ziggyport2001
Malone, NY
mahindra 3016
I am presently researching tractors and am pretty confident in buying the 3016. However the dealer was trying to suggest buying a 40 hp in case I might need the higher pto hp later. I have a 24 acre lot where I will be doing some tree clearing and landscaping. I would appreciate some advice on how large a tractor I might need. Thank you.
   / mahindra 3016 versus 40hp #2
Welcome to the site:welcome: I would choose the 40 HP .. Best I recall ,It's the same (physical) size tractor with more HP. With a 30 HP tractor You will have roughly 25 PTO HP. Next tractor I buy will be at least 45 HP
   / mahindra 3016 versus 40hp #3
Welcome from St.Lawrence Co.;I also would go for the 40 HP.
   / mahindra 3016 versus 40hp #4
A 30hp Mahindra will do the work of a 50hp trator in any other brand
   / mahindra 3016 versus 40hp #5
   / mahindra 3016 versus 40hp #6
While more horsepower is always welcome and I tend to agree with your dealer about jumping up in horsepower. But, another thought on how you add that extra horsepower. Consider a second, older and larger tractor in the future if you need horsepower. I can assure you a second tractor no matter the size will prove handy.
   / mahindra 3016 versus 40hp #7
Please give examples and explain.
I agree, I've got to hear this 1. A 30 HP with a 25 HP PTO will pull a 5 ft rotary cutter t. A 50 HP tractor with a 45 HP PTO will pull a 9 FT cutter using the 5 ft per HP rule
Thank you for your responses. I don't believe any 30 hp tractor can beat a 50 hp tractor.
   / mahindra 3016 versus 40hp #9
Mahindras use the 2.5 ft per HP rule
   / mahindra 3016 versus 40hp #10
WHAT?
Enmark Z Spray (A53316)
Enmark Z Spray...
2003 Big Tex 10PI...
FOREST CITY 8R SUB / BED (A52708)
FOREST CITY 8R SUB...
16001 (A55853)
16001 (A55853)
1998 Caterpillar 12H Articulated Motor Grader (A55973)
1998 Caterpillar...
(4) 305/45R22 TIRES & WHEELS (A58374)
(4) 305/45R22...
