Buying Advice mahindra 3016 versus 40hp
   / mahindra 3016 versus 40hp #1
ziggyport2001
Malone, NY
mahindra 3016
I am presently researching tractors and am pretty confident in buying the 3016. However the dealer was trying to suggest buying a 40 hp in case I might need the higher pto hp later. I have a 24 acre lot where I will be doing some tree clearing and landscaping. I would appreciate some advice on how large a tractor I might need. Thank you.
   / mahindra 3016 versus 40hp #2
Welcome to the site:welcome: I would choose the 40 HP .. Best I recall ,It's the same (physical) size tractor with more HP. With a 30 HP tractor You will have roughly 25 PTO HP. Next tractor I buy will be at least 45 HP
   / mahindra 3016 versus 40hp #3
Welcome from St.Lawrence Co.;I also would go for the 40 HP.
   / mahindra 3016 versus 40hp #4
A 30hp Mahindra will do the work of a 50hp trator in any other brand
   / mahindra 3016 versus 40hp #5
   / mahindra 3016 versus 40hp #6
While more horsepower is always welcome and I tend to agree with your dealer about jumping up in horsepower. But, another thought on how you add that extra horsepower. Consider a second, older and larger tractor in the future if you need horsepower. I can assure you a second tractor no matter the size will prove handy.
   / mahindra 3016 versus 40hp #7
Please give examples and explain.
I agree, I've got to hear this 1. A 30 HP with a 25 HP PTO will pull a 5 ft rotary cutter t. A 50 HP tractor with a 45 HP PTO will pull a 9 FT cutter using the 5 ft per HP rule
Thank you for your responses. I don't believe any 30 hp tractor can beat a 50 hp tractor.
   / mahindra 3016 versus 40hp #9
Mahindras use the 2.5 ft per HP rule
   / mahindra 3016 versus 40hp #10
WHAT?
Giyi Breaker Hammer (A57149)
Giyi Breaker...
John Deere 1025R (A53317)
John Deere 1025R...
LOT: (9) Sets of Gutter Broom, 250 KP, Std 26 (5 SEG) (A59076)
LOT: (9) Sets of...
New Holland WorkMaster 37 (A53317)
New Holland...
2001 Ford F-550 Liftmoore 6036 3 Ton Crane Mechanics Truck (A56858)
2001 Ford F-550...
2007 Ford F-450 Ambulance (A55788)
2007 Ford F-450...
