Eco Boost vs V8
/ Eco Boost vs V8 #101
Not a huge fan of the 6.0. It's a solid motor but does lack MPG's. I like the 6.2L much better. You are the only person I know that praises the Titian so much. You've had it quite a while so it must serve your needs well. Funny thing is when I go to the monthly sales meetings, the Nissan Titan is NEVER mentioned. It's not even a threat to GM truck sales. I don't know anybody that owns one to tell the truth. I'm not bashing. The #'s speak for themselves. Ford (as always) is GM's biggest competitor in the truck segment. Toyota and Ram are brought up also. GM has used BUMPER steps for many years on the Avalanche. Bled into the trucks this year. Ford uses a pull out BAR off the lift gate. That requires a free hand to pull out. The GM's bumper step does not. We can all talk HP, torque, and tow ratings all day long. The bottom line is we buy what we like and looks play a big part in the buying decisions we make. If taking the "safe approach" means sticking to internal cam V-8's vs OHC's and turbos on their trucks, I'm fine with that. I don't believe GM set back and watched what the competition did when building the C-5, C-6, and the new C-7 Corvette. It has acquired "super car" status and has stood alone for decades as the "All American sports car".
I do like the GM bumper step, it's smart. It is better than Fords solution.
To date my 08 Titan has 89,000 miles. 1 repair, a light bulb at $3. It's been a fine vehicle that gets horrible mpg. 14 is what it does but 9700# on the back it gets 9. It's a power house. My best tank was 16.4 mpg. I pulled 2 cars and a plow truck out yesterday. I used it, not my diesel F350. Factory Detroit Lockers and 4 low make it untouchable. Take a hard look at them on a dealers lot some day then remember it's unchanged since 2004. Back then till about 2010 it was the class leader. Factory Detroit Lockers, factory sprayed in bed liner, factory navigation and backup camera, factory bed tie down system that was movable. Remember, 2004 on it has these systems.
As for sales numbers Nissan can only build 2000 a month, 24,000 a year. I don't know why but this is unchanged since 2004 so they never will be a competitor, just a great secret.
Comparing a Corvette and GM trucks is not fair. The team at Corvette and the team at GM trucks have totally different business practices. Corvette, world class. GM trucks, safe and so so.
I am not a 6.0 lover. It's just a good match in the GM trucks and has proven reliable with good power for what it is. Just a little thirsty.
Chris
/ Eco Boost vs V8 #103
Nissan puts them on the Titan Factory.
Chris
Must be an option, we have a loaded 2004 Titan extended cab 4x4 at work with only 60,000 miles and i just went out and looked at it and be damned if I can find a bed step, just those stupid running boards I don't like. They been trying to trade it for a new Tundra but no luck yet.
/ Eco Boost vs V8 #104
Yes, option.
Mine is actually off. I keep getting mud and snow stuck all over it.
Chris
/ Eco Boost vs V8 #106
Best 1/2 ton truck built from 04 till the Eco Boost.
About to be the best again late summer with the 5.0L Cummins
Chris
Yes, everyone has their opinion, and you sure have yours.
I just read Nissan will be selling with the Datsun name again in some countries.
I also just read the 2014 Titan is ranked #10 in full size pickup trucks. There's a reason for that.
/ Eco Boost vs V8 #107
That doesn't make much sense ... there are only six 1/2-ton trucks on the market.
Besides, like anything else, this might be a situation where you need to own one before you understand it's true value.
I drove only domestics, mainly Ford (Ford family) for years until I started buying and driving Toyota & Honda. The ownership experience of owning Toyota trucks vs the domestics I've owned are not even comparable. If not for my current need of a heavier duty truck, if still be in a Tundra. Shoot, my 04 Sequoia still runs like new with 138k miles. I've replaced the brakes, power antenna, battery, and an ABS sensor (wire chewed by an animal, not a faulty part) and that's it.
My hot rod Prius (yeah, I said Prius) might finally need it's first set of brake pads at 115,000 miles. It has not needed a single other thing expect 1 headlight bulb, and 1 tail light bulb.
I'm not sure if owning a Nissan is as easy as Toyota, but once you experience it, you'll have a hard time shopping Domestic "branded" vehicles again, especially if you've owned and dealt with domestics in the past.
/ Eco Boost vs V8 #110
Sequoia is an overpriced piece of crap in my opinion, I work on a few for a living. Frames rot out and the rear window mechanism in the tailgate rusts through and falls off leaving the rear wiper and window in a non-operating condition. You live is Michigan and don't have the same issue? Hard to believe because every one we work on over 6 years old has this problem.
I believe Toyota trucks are overpriced, overrated and generally a poor value in salt country. When is the last time you saw GM or Ford truck need a new frame? Now the Prius is a whole better animal.
Fred, entitled to my opinion.
/ Eco Boost vs V8 #111
Lol. Nice opinion. Actually, I got the recall letter from Toyota. Did you know that if the frame rust is bad on the Tundra out Sequoia, they will replace it? That includes all mounts & everything! Luckily mine wasn't bad, and I use FluidFilm undercoat and that keeps things in shape. I also keep my tailgate internals lubed every year, maybe that's why they stay clean and working.
I'm not sure how they are "over priced" ... pricing seemed to be in line and comparable to other new trucks when I was shopping. They don't offer crazy incentives like the others though...
Now granted, they do sell higher USED because they typically retain their value so much better. Is that what you're speaking of?
We all have our own opinions of course. I've owned lots of vehicles, my family too. All I can say is that, FACTUALLY, while I like my current Ford (and liked all my past domestics), the overall quality and low cost of ownership has been night & day compared to my domestics.
/ Eco Boost vs V8 #112
The dealer techs here are very good at doing the frames. They bank many hours flat rate because Toyota was very generous about the time units allowed (I forget the number). I have at least 10 customers who have newly found Tacomas (frame changers).
You are right about the resale value and I wish I knew why a 10 year old Toyota still retains a high resale when guys like me are afraid to place these vehicles on the hoist :( because of the frame problem. Late model Toyota parts are becoming VERY expensive (except for OEM filters that stay cheap).
There's a stigma with Toyotas (and Subarus) in this part of the country. I work on both but don't like either. Toyota owners are die hards.
Not to jack, back to the battle at hand! Fred
/ Eco Boost vs V8 #113
I'm making a road trip today in my ecoboost. I will post my mileage numbers. It is the first trip I've had in awhile and it'll be interesting to see how it does on the highway with this winter gas. I'm going to be driving from Evansville Indiana to Columbus Indiana which is about a three hour trip each direction.
/ Eco Boost vs V8 #114
1 hour on the interstate with the cruise control set at exactly 75 miles per hour. I was on a slight uphill section of the road. Normally the boost would be about the same place but below the zero. I have a super crew 2 wheel drive with the max tow package which includes a 3.73 rear end.
/ Eco Boost vs V8 #116
Depends on what you will use it for. I have lots of friends that have both the Eco Boost and the 5.0L. By all accounts, the 5.0L gets better every day mileage while the Eco Boost town and hauls better with similar mileage. Remember that no matter the engine, it takes fuel to make power, so when using power, you use fuel. But, neither gets any better highway mileage at 75mpg than my '13 Ram Laramie Longhorn 4x4 with the 6spd tyranny & air suspension (which is really, really sweet!) which is about 16-16.5mpg.
/ Eco Boost vs V8 #118
Flipped them and still coming in upside down.
/ Eco Boost vs V8 #119
Thanks for posting
Sorry to say but Really not impressed!
You consumed 12.56Litres/100km (converted to metric)
My 2006 4.8l 4x4 sierra extended cab eats 2.44litres more than your new 2wd truck and that's with 31" procomp A/T 4 speed auto and 224000km.
Not worth it!
/ Eco Boost vs V8 #120
Thanks for posting
Not worth it!
It also has 100 less HP and 150 FT less TO and struggles to tow 6000#.
His truck makes 365 HP and 420 FT TQ and has tires as large or bigger stock. Oh yea, it can tow 11,000# plus with ease.
Chris
2019 Chevrolet Malibu Sedan (A64557)
2019 Chevrolet...
2015 Ford Fusion Sedan (A64557)
2015 Ford Fusion...
2018 JOHN DEERE 310L EP BACKHOE (A65053)
2018 JOHN DEERE...
2023 NISSAN ALTIMA SEDAN (A59914)
2023 NISSAN ALTIMA...
2022 SANY SY155U EXCAVATOR (A63276)
2022 SANY SY155U...
John Deere Bird House (A64557)
John Deere Bird...
