Quick Attach for subcompact tractors
/ Quick Attach for subcompact tractors #1
jmainel1
Member
2012 Massey Ferguson GC1710TLB
Anyone know of anyone who makes a quick attach setup for a Massey Ferguson GC2310TLB or similar?
/ Quick Attach for subcompact tractors #2
Have the same question regarding my GC2410 and disappointed to see that no one every replied to your post! Wondering if you ever found a quick attach for your tractor?
/ Quick Attach for subcompact tractors #3
If you are talking about a quick attach for your FEL, WR Long makes them. Here is a link to the page and if you scroll down to the bottom there is a link to a work sheet for measurements. Or you could call them and see if they have done one for your tractor.
Adaptor Plate
/ Quick Attach for subcompact tractors #5
Dave & Travis, thanks for your replies! I had looked at the WR Long Adapter but wasn't quite sure it would fit my loaders arms as I couldn't find any info specific to the GC2410 on their website. Good to know they make an adapter which should fit. Now to consider the details....
Obviously the GC2410 has limited FEL lift capacity already so I don't want to add anything too heavy. Quoting from the WR Long website description of the adapter plate, "...average weight is approximately 130 pounds".
@Travis, do you know the weight of the adapter designed for the DL100 loader? I looked at the link you sent and watched Ted's video but there are no specs listed. I assume that's because the adaptor specs are different for each loader.
/ Quick Attach for subcompact tractors #6
According to WR Long, the adapter for a DL100 will weigh really close to 110 pounds.
I hope this helps.
Travis
/ Quick Attach for subcompact tractors #8
/ Quick Attach for subcompact tractors #9
I hope this helps.
Travis
I looked at that WR Long stuff back when I had my BX23 - and it weighed in heavy. I wouldn't want to add that much extra weight to the FEL - it would seriously impact the lift capacity on that sub-compact tractor.
/ Quick Attach for subcompact tractors #11
Looks like the Tach-n-Go might be a good option for my small tractor. Sent Jery a message to get a few more details. Thanks for all the suggestions!
/ Quick Attach for subcompact tractors #12
Did you ever get the Tach N Go set up? if so, how do you like it? and how much did it cost? I've been looking for something for my GC2410 with the DL100 FEL and I like this set up better than the standard Skid Steer Quick Attach. I only use my bucket and another attachment I made to raise and lower my snow plow (an older 7.5' plow for a truck) and I also use a reese hitch for moving trailers around the yard, so this Tach N Go looks like it would work great for what I need. Thanks.
/ Quick Attach for subcompact tractors #13
I have a subcompact kubota bx2200. I used the titan quick attach weld on kit. Cut the back of the bucket off leaving the pins and everything alone. Then used a 3 inch piece of square tubing for a spacer between the back of the bucket and the titan quick attach setup. Then you have to weld on a plate on the bucket. I used the quick attach plate from titan. I have pictures I showed on another post regarding the same thing. If you can't find it let me know I will post them on this post. I will try to answer any questions you might have as well.
/ Quick Attach for subcompact tractors #14
/ Quick Attach for subcompact tractors #16
My "Worksaver" SSQA is a nice unit on my GC, I paid $600.00 for it..
/ Quick Attach for subcompact tractors #17
Yes I have Jery Dunn's Tach-N-Go system on my BX2230 and his fixed forks. Doesn't weigh a lot and works great. Jon
2003 NV FLATBED CURTAIN SIDE (A67714)
2003 NV FLATBED...
2015 HORSE CREEK MFG. FLAT BED TRAILER (A67714)
2015 HORSE CREEK...
1999 Peterbilt 330 Truck (A66736)
1999 Peterbilt 330...
2015 Bombardier Evinrude 200HP Outboard Boat Motor (A66738)
2015 Bombardier...
CAT 631C Lift Cylinder (A68134)
CAT 631C Lift...
2012 INTERSTATE TRAILER 28 T/A GOOSENECK TRAILER (A67714)
2012 INTERSTATE...
