7.3 role call
/ 7.3 role call #61
Thanks guys ALL the information you have posted is helpful.
Was going to start on it this morning - but a family members 1997 S10 showed up dumping coolant and it appears to be a failed gasket at the pump/ block interface, it's their only transportation , so I have to fix it first.. Hopefully get back to the Ford 7.3 in the next few days
Thanks again, I do appreciate it:thumbsup:
/ 7.3 role call #62
Here is my 03...
I purchased her in 04 with 38K 1 owner miles...
The truck now has 106K miles and running stronger than ever...
Last of the 7.3's...
Mods are Edge programmer, ATS stainless 4" exhaust, high flow intake, and gauges...
Used to pull my fifth wheel camper...
View attachment 340241View attachment 340242
/ 7.3 role call #63
Seems to me I remember wiring harnesses and relays associated to injectors and glow plugs along with the glow plug timer.
Chris
The g plugs are easy to test and replace, bar any rusted in problems. I think that if you get a test light to ground (-) on the wire connection on the g.p. it is bad, but check that out, it's out of my memory guaranty period.:laughing: I believe that the fuel system is 100% mechanical and not involved electrically at all. (other than the fuel solenoid)
/ 7.3 role call #64
Yep that is one test method that I saw online, making sure to disconnect the one being tested..
hopefully get to the 7.3 in the next couple days Thanks again for the info
OK- got the F-250 pulled up to the garage and powered up the electrical system the wait to start light is not coming on with the Key switch turned to the ON position, and no voltage is present at the glow plugs (temperature is low 50s today).
Anyone know where the solid state glow plug controller is mounted ??
/ 7.3 role call #65
Back in '04 I bought my '99 F350 with 7.3, I think it had around 40k miles on it when I bought it, if I remember correctly.
After a few years, my father started realizing how much nicer it was to plow his parking lot contracts with my heavy diesel truck and 9' plow vs his older half ton and 8' plow. He slowly started "stealing" my truck from me, it took a few years, but I eventually officially sold it to him a couple years ago.
Here is what it looked like for the first few years that I owned it...
Then a few pics during the "transition years" of when my father was stealing it from me....
And what it looks like as of last week....
I mostly only use it now for towing the tractor when needed, and since we live so close together, we still sort of "share" the truck. If he ever wants to get rid of it, which I doubt he will, I'll buy it back from him. I keep thinking that someday when it's all rusted out, maybe I'll want to restore it. As much as I did love the truck when I owned it, I don't miss the harsh ride. I could barely drink a cup of coffee when driving that truck, without spilling the entire thing all over the place.
Here is a pic of it with around 3k lbs in the bed, it's the only time it looked pretty level.
/ 7.3 role call #67
'97 that dad bought new. I bought it from him in '10 with 110k miles and stock. Dumped the D50 for a D60 with a True Trac diff. Then installed a BTS trans (look it up, best e40D / 4R100 trans money can buy, Banks Intercooler and chip with Tony Wildman tunes. Also did a custom e-fuel.
Next step will be injectors, if I keep it. With a new grand baby really need a crew cab.
/ 7.3 role call #68
Thats what I have been planning on, It's expensive but more than likely the last trans I would ever have to buy.
/ 7.3 role call #69
To be honest it really is not that expensive. Ford reman is in the 3k+ range and it is NOTHING like a BTS. If you go there Brian and his crew will do the install for basically nothing and it will be right. He builds the trans in front of you and in my case entertained alot of questions. This trans cannot be called a rebuild because it is all new and custom parts except for the case. He takes about half of the new Ford pump parts and throws them out in favor of custom parts. And he will more than likely buy you lunch. Brian and Patti [his wife] are great people. As far as his warranty, I was one of the few that had a problem. His first question was "are you still running" and the truck was just the converter [not his parts] was messed up [dragging] so he sent me a new trans/converter/oil cooler and oil on his dime with no confirmation other than my word. THEN wanted to pay for my time to install it. So no worry about him standing behind his work. CJ
/ 7.3 role call #70
I have used a couple.... All '00-'01. The '01 was a F450, the '00 was a F250. The F250 was nice. Stock, and I only drove it empty.
The F450 was great; had 12' flatbed with dump. It was construction truck for buddy I worked for, for a couple years. Towed Bobcat with it, hauled light to maxxed out load in bed. He sold it due to change in business.
He has a '01 F350 SRW now. He beats the snot out of that truck. Broke fron springs, had to replace whole front axle(bbad bearing took out case), is on 2nd replacement bed(loads the snot out of the lumber rack; sheet metal aint like it was decades ago...), and replace the tranny(yes, Ford tranny's go out too, not just Dodge).
The 7.3 in that truck keeps humming though; he is over 375,000 miles. He got it with over 125,000.
For as much as I liked that '01 F450 flatbed, I still like the power band of the inline motors. Same in fire engines; I have driven inline with the newer rigs we have, and V8's in the older(CAT and Detroit). Just like the way the inline motor pulls.
Will give 7.3 credit though, I know my construction buddy noted above, drives the snot out of his(he does keep filters, fluids changed regularily though). It keeps on running.
/ 7.3 role call #72
I have read a lot on line about BTS and never read anything bad. Outstanding warranty and stands behind his work even after warranty has ended. If I ever have another problem with mine I will be a BTS customer for sure. From all I hear they are the BEST!!
John
/ 7.3 role call #74
On the back of the intake manifold.
Thanks , checked all of the glow plugs ,and all check good , power at controller but no trigger signal.
checked the dash closer and the truck has a momentary contact switch , that had no power to it , fixed that and it's a running 7.3:thumbsup:
The charging system still has a problem, found an open in the main output wire from the ALT to main start solenoid -fixed that but still no charge ( owner probably ran it that way and damaged it...) will have it tested and go from there (could still need a regulator)
Thanks again at least she starts and runs now...
/ 7.3 role call #75
I have done that a few times, after spending a couple of hundred $$$ for that stupid controller a pushbutton switch and solenoid your good to go. CJ
/ 7.3 role call #76
Yep the owner says he's happy with a working push button for the glow plugs...
a new $16 regulator and the 7.3 running and charging fine...
Thanks for all the help
/ 7.3 role call #77
I have a 2001 crew cab six speed with about 170k miles I bought new. I started cutting wood a few years ago and that's taken a toll on the bed, along with rusting at the rear fenders. It used to get 18-20 mph empty but the last couple of years it's been more like 12. It's hard to start when cold, tested all the glow plugs and related parts good and I'm starting to wonder if I have some weak injectors. I was thinking of getting a new gas super duty but am not convinced I want to spend that kind of money and get rid of this truck.
/ 7.3 role call
Put some fresh injectors in and fresh glow plugs while your there.
/ 7.3 role call #79
I love mine too!
/ 7.3 role call #80
I replaced the glow plugs already although it was kind of silly since the originals still tested good. I'll probably pull the injectors and get them flow tested before I replace any.
(1) UNUSED 9.5-24 TIRE W/ 8 LUG RIM (A64280)
(1) UNUSED 9.5-24...
2016 JOHN DEERE 655K CRAWLER LOADER (A64279)
2016 JOHN DEERE...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
2014 FORD F350 4X2 S/A DUMP TRUCK (A59914)
2014 FORD F350 4X2...
2023 Kubota M7-174P (Premium) 4WD Tractor - 400 Hours (A63688)
2023 Kubota...
2015 Teupen TL54J Crawler Articulating Boom Lift (A61572)
2015 Teupen TL54J...
