Cannot Find Part Number For JD3520 Grease Fitting
/ Cannot Find Part Number For JD3520 Grease Fitting #1
Vic_N
Upstate NY
JD 4044R
I broke a zerk on one of the u-joints on my front PTO drive shaft that I use for my 59" front-mounted snowblower. My grease gun pulled off the piece with the spring and ball bearing...who knows where it went. I got the base of the zerk out and went to my dealer; he gave me part number JD7760. This is a 1/8", 65 degree angle fitting. Unfortunately, it's close but not a good fit...its shank is a tad too long so I cannot fully insert it. I've looked through all the JD zerks on JD Parts I can find but I just can't seem to locate the one I need. I'm obviously not looking in the right place. Anyone have any thoughts? Thanks!
/ Cannot Find Part Number For JD3520 Grease Fitting #2
I have found Zerks of all sizes and shapes at a Ace Hardware.
I visited Ace yesterday and they didn't have what I needed. Tried a True Value and an Aubuchon as well. Found lots of zerks that were close but no match. Thanks for the suggestion though.
/ Cannot Find Part Number For JD3520 Grease Fitting #4
What's the model # of your snow blower??
Snow blower is OMLVU17390.
/ Cannot Find Part Number For JD3520 Grease Fitting #6
JD7760 is what JDparts shows for a 59" snow blower. If this is not right, what kind/type of fitting do you need?
Possibly you got a fitting from a different supplier to JD. JD7760 crosses to Alemitle 1612B
Can you post a picture of the fitting you have? Is the fitting the same in other end of the PTO shaft? Can you post a picture of it?
/ Cannot Find Part Number For JD3520 Grease Fitting #7
Zebrafive
What''s the parts catalog # of the 59" snowblower? I failed to find it when searching JDparts.com.
/ Cannot Find Part Number For JD3520 Grease Fitting #8
Zebrafive
Go to the 3520 parts catalog, then Implements, then 2108 59" two stage snow blower
Zebrafive
OK. My bad. I obviously did not explain my problem well enough in my initial post and for that I apologize. This darn English language! I am talking about a zerk on the front PTO drive shaft, not the snowblower drive shaft. When the questions began about the sb I was puzzled but not intelligent enough to realize I had screwed up.
IMG_0962.jpgIMG_0961.jpgHere are 2 photos with the JD7760 zerk on the left and the base of the zerk (with top missing that I removed from the PTO drive shaft) on the right.
/ Cannot Find Part Number For JD3520 Grease Fitting #11
i bet jd doesn't make zerks but uses off the shelf fittings
/ Cannot Find Part Number For JD3520 Grease Fitting #13
You still need to look in the snow blower catalog. Only they do not show a breakdown of the drive shaft. Key #10 is the drive shaft, LVA14109 $405. Not keyed is AN278257 cross and bearing assembly $72. I am not sure what you get with that.
Understood. We're speaking the same language now. All the diagrams I see for AN278257 do not show a lube fitting. I'll figure something out. Thanks for all your time.
/ Cannot Find Part Number For JD3520 Grease Fitting #15
Thanks for the heads up. I was unaware to access some equipment one had to first access the tractor parts catalog. Thanks again,Jim
2016 Isuzu NRR Trash Truck, VIN # JALE5W162G7300782 (A65563)
2016 Isuzu NRR...
2009 PALFINGER 11 FT SERVICE BODY (A62613)
2009 PALFINGER 11...
JOHN DEERE 5075M TRACTOR (A63291)
JOHN DEERE 5075M...
1987 Asphalt Tanker Trailer (A65563)
1987 Asphalt...
2009 IC Corporation School Bus, VIN # 4DRBUAAN19B694286 (A65563)
2009 IC...
12ft. Field Cultivator (A65640)
12ft. Field...
